Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
115 registered members (ABerns, 65convertible, ammolab, addyguy, 928, AdditiveOCD, 9 invisible), 2,262 guests, and 61 spiders.
Topics286,013
Posts4,900,707
Members67,545
Most Online2,967
Mar 10th, 2019
Another Brake Fluid Flush Question #4673571
02/21/18 06:19 PM
02/21/18 06:19 PM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
Iíve lost track of how many one-man brake fluid flush videos and DIY tutorials Iíve watched and read. I always use my Vacula but wonder if there is a better, easier way. Eric the Car Guy has a video where he pumps the brake pedal while fluid is expelled through a plastic tube into a bottle. I always wondered why air isnít sucked into the system past the bleeder threads when the brake pedal is released. I certainly see a lot of air bubbles in the fluid when I use my Vacula. The way I learned as a kid was you have a partner who works the brake pedal. You open the bleeder on the down stroke but close the bleeder before the pedal is released. Question: can one person pump the brake pedal with the bleeder valve open? This would certainly make the job easier. Thanks.
Here is what I use although I rigged it to operate with a mechanical vacuum pump instead of an air compressor.
http://tool-xpress.com/store/product/vacula-air-canister-brake-bleeding-system-1-9-qt-vu18-0051/
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673593
02/21/18 06:38 PM
02/21/18 06:38 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Yes, it can be done. I routinely do one-man bleeding. You crack open the bleeder screw about a half turn. This allows fluid to flow out under pressure and releasing the brake pedal lets only a tiny amount to be slurped back in... kind of a poor man`s one-way valve. Keeping a tube on the bleeder screw makes sure no air is slurped back in.
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673594
02/21/18 06:40 PM
02/21/18 06:40 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Gravity bleeding can work, too.
Plain, simple Garak.
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673610
02/21/18 06:56 PM
02/21/18 06:56 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
https://images-na.ssl-images-amazon.com/images/I/71Z5x4eszIL._SL1500_.jpg
(Embedded images preview isn't working for me lately)
Perhaps more versatile, and almost certainly more reliable than your Vacula, which is way overkill for non-pro use. Good name though.
But its only 0.5% of the cost, so its not going to fly on bitog.
IF it sucks air (you can pull or push fluid, or cycle between them) if you hold the syringe higher then the bleed screw the bubbles will rise into it.
Re: Another Brake Fluid Flush Question [Re: Kestas] #4673619
02/21/18 07:05 PM
02/21/18 07:05 PM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
What about air sucked in past the bleeder threads?
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673623
02/21/18 07:07 PM
02/21/18 07:07 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
My own home made one man brake bleeder. I bought the 3/8" O.D. - 1/4" I.D hose at an ACE Hardware and used a quart drinking bottle.
Me: 13' VW GTI 3 door 6 speed manual
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673624
02/21/18 07:09 PM
02/21/18 07:09 PM
Boise, Idaho
MRtv Offline
MRtv  Offline
Boise, Idaho
Honestly I was skeptical of the one man bleeder system. So I decided to try it out. I made the bleeder as shown on youtube. Hooked it up and cracked open the bleeder valve. Pressed on the pedal several times and and checked the fluid level. Found on my vehicle I can pump the brake pedal a dozen times before needing to refill fluid level. It did work. I do it this way all the time now. Wife is much happier not having to be the brake buddy.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673644
02/21/18 07:28 PM
02/21/18 07:28 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Tip for first time bleeders: You will empty the brake fluid reservoir faster bleeding the front brakes vs the rear brakes on most vehicles.
Re: Another Brake Fluid Flush Question [Re: MRtv] #4673645
02/21/18 07:28 PM
02/21/18 07:28 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
No experience using wives for this, but I've tested Scottish and Taiwanese girlfriends in this role. Neither were very reliable, and they are probably also the most expensive solution on the market.
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673650
02/21/18 07:34 PM
02/21/18 07:34 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
You need two things for the 1 man bottle tool to work:
1) correct ID rubber hose. use a small hose clamp to seal if anal.
2) fluid present inside the bottle covering the lowest level of the hose
#1 helps minimize risk of air bubbles making it through the hose/nipple connection.
#2 makes it so there's no air, but rather fluid coming back up the hose when you let off the brake pedal. After a few cycles, any residual air in the tube from the start has been pushed through and the hose is pure fluid. The tiny bit of old fluid that gets pulled back up by letting off the pedal is nil and not enough to be a concern. Just keep cycling the fluid.
~Shade tree mechanic for friends and family.
Re: Another Brake Fluid Flush Question [Re: skyactiv] #4673653
02/21/18 07:36 PM
02/21/18 07:36 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
This is the machine that works. This is how I have been bleeding my brakes for decades
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Another Brake Fluid Flush Question [Re: Garak] #4673733
02/21/18 08:26 PM
02/21/18 08:26 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 It can and does, too easy right.
Re: Another Brake Fluid Flush Question [Re: Trav] #4673800
02/21/18 09:06 PM
02/21/18 09:06 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If a gravity bleed doesn't work. There is a leak sucking in air. It proves your work when replacing lines.
Thick oil is better grin2
Re: Another Brake Fluid Flush Question [Re: artbuc] #4673831
02/21/18 09:31 PM
02/21/18 09:31 PM
USA
slacktide_bitog Offline
USA
speed bleeders are awesome smile
Re: Another Brake Fluid Flush Question [Re: andyd] #4673882
02/21/18 10:22 PM
02/21/18 10:22 PM
Trav Offline
Trav  Offline
It doesn't really matter, the master cylinder is above the bleed screw, it has not option other than to drip out. You are right about it sometimes taking a longer time but eventually it will.
On those I usually just give the brake pedal a light touch to get it moving.
When installing new calipers I always remove the bleeders first and put a couple of turns of thread tape on them and put them back in without bottoming. This seals the threads and once bled and tightened prevents the screw for seizing later.
