Sorry it should have been MAF, getting late. It will only draw fuel (if saturated) or vapors when the purge activates.
Chasing intermittent issues is hard to do and you never know what your going to find, sometimes its textbook other times it can be unusual. You know like when the cow died and the farmer said strange it never did that before.
Clean the TB and MAF, make sure there are no cracks in any hoses after the MAF to the TB. Clear the codes and see what happens.
If the canister isn't too expensive change it and check all that system. The whole job will be less than having it scanned and I am optimistic about the canister being the issue.
