Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
108 registered members (53' Stude, A310, 08z06, Ablebody, antonmnster, 15 invisible), 1,559 guests, and 36 spiders.
Topics290,850
Posts4,851,433
Members66,044
Most Online3,590
Jan 24th, 2017
04 350z Mineral Oil only? (and rec. request) #4673049
02/21/18 11:44 AM
02/21/18 11:44 AM
Englewood, CO
funkymonkey1111 Offline OP
Englewood, CO
All,
I've owned a 2004 Nissan 350z since brand new (December 2003), and just now came across a blurb in the owner's manual that states "NISSAN recommends mineral based oils." Aside from the factory oil and one dealer change, this thing has had synthetics. Any ideas on why Nissan would say this? 2004 wasn't pre-synthetic days. Any thought if I should switch back to non-synthetic? It has 75,XXX miles.
The manual also says 5w30 preferred. In selecting an oil for another car (05 Legacy GT) with the help of this board, I've learned a bit about recommended oils (10w30 and 10w40 are ok if operating temps are above 0 degrees). This car has mostly had 5W30 Castrol Edge or Mobil 1, but I did try the 0w40 German Castrol years ago seemingly without issue. It generally has Wix filters.
Looking through other tests, it seems that Castrol Edge or the Pennzoil Platinum is the way to go. Is 5w30 fine, or would 10w30/10w40 (or back to 0w40) be better? (it would likely not be driven under 0 degrees)
Also, factory filters? I'm not wed to Wix, e.g., if for example, the Purolator Boss is the way to go, i'm happy to do that. (or, is a filter like a Purolator One better--i've read on here that for enthusiastically driven engines perhaps higher flow/less filtering filters would be a wiser choice)
Change intervals are approx 3500. This car is not driven much, but when it is, it is driven enthusiastically in the mountains and has been on tracks, but the local track is no longer allowing convertibles. Occasionally the car is driven on long road trips. It has not had any oil analysis done, but will shortly.
Thanks in advance.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673094
02/21/18 12:19 PM
02/21/18 12:19 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
I don't think you have done any damage using synthetics. I also have a Nissan that I use synthetics on because by 5,000 miles, the oil is really thin.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673137
02/21/18 12:45 PM
02/21/18 12:45 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Synthetic is okay in that engine. I would use the thicker euro stuff too, like 0w30,0w40 if possible and a fram ultra which has exceptional flow while having the best filtering rating around.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673153
02/21/18 12:56 PM
02/21/18 12:56 PM
CA
raytseng Offline
raytseng  Offline
CA
i think you just read it as they didn't bother to test a synthetic oil . It doesn't say synthetics not recommended, it just says mineral oil recommended.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: 901Memphis] #4673158
02/21/18 12:59 PM
02/21/18 12:59 PM
Englewood, CO
Englewood, CO
for my Legacy GT, seemingly the go-to oil is Rotella T6 5w40. Any idea if this would be a good choice?
Re: 04 350z Mineral Oil only? (and rec. request) [Re: 901Memphis] #4673161
02/21/18 12:59 PM
02/21/18 12:59 PM
Englewood, CO
Englewood, CO
thanks for the filter recommendation. I know fram filters are often [censored] on--I didn't know this was a good one.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673169
02/21/18 01:04 PM
02/21/18 01:04 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'd run Mobil 1 0W-40 and a Wix if it was mine.
"Zed's dead baby, Zed's dead."
Re: 04 350z Mineral Oil only? (and rec. request) [Re: rooflessVW] #4673183
02/21/18 01:19 PM
02/21/18 01:19 PM
Englewood, CO
Englewood, CO
Why Mobil 1 over Castrol?
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673263
02/21/18 02:24 PM
02/21/18 02:24 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'm on a Mobil kick right now.
Nothing wrong with the Castrol, it probably edges out the Mobil and Pennzoil by a bit.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673267
02/21/18 02:25 PM
02/21/18 02:25 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
RooflessVW doesn't know why he choose Mobil over Castrol either LOL
I am just kidding around there with that.
For your Nissan.. The floor is wide open in my opinion. I have essentially the same motor in my car. I have run 11 different full synthetic oils in my car. I have run 4 different conventional oils in it. All 5w30s. My car is at 220,000 miles and runs great. Hardly any oil loss between oil changes. I got the car when it had only 39k miles on it.
Absolutely nothing wrong with everyone's advice given so far. It is all very good.
I have liked how well the Castrol gold bottle 5w30 ran in my 3.5 VQ. If you are going to go on a long run either that or Mobil 1 0w40, Castrol 0w40 would be good. These VQ motors are known to shear oil out of grade a good bit. As far as filter goes... Fram Ultra is obviously great. But if you wanted to run a Fram orange can it would be just fine as well. I have a Fram orange 7317 on my Altima 3.5 VQ right now.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673484
02/21/18 05:00 PM
02/21/18 05:00 PM
Regina, Saskatchewan, Canada
Garak Online content
Garak  Online Content
I think they were just using that as an awkward way to state that conventional is the basic requirement. Similar wording has carried on afterwards, too, in the G37 manual, for instance.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673654
02/21/18 07:36 PM
02/21/18 07:36 PM
Taiwan
Ducked Online content
Ducked  Online Content
Taiwan
Maybe they are heretics.
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673660
02/21/18 07:43 PM
02/21/18 07:43 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
They are just trying to save you money....
They know that all Nissan 350Z owners change their oil far too soon and too often....
So they figure "why tell owners to use the expensive stuff, if they're just going to dump it out too soon, anyway"?
grin thumbsup grin2 LOL
Re: 04 350z Mineral Oil only? (and rec. request) [Re: funkymonkey1111] #4673662
02/21/18 07:45 PM
02/21/18 07:45 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
I have the same set up in my new to me 04 G35 coupe.
Previous owner had records of oil changes at quick lubes. Nothing special up to 123k.
I just changed it out with my stash of Maxlife 5w30 and Fram TG. Drove it for a summer before winter storage and noticed no oil consumption. For 3-5k OCI around town, not tracked, and no canyons cause MN, I personally don't see the need for fancy stuff.
VQ's have a notoriety for burning oil, but IMO it's nothing different than owning something like a revving Honda Vtec 4 banger like I've previous had. Improper new engine/car break in, driving it hard, hang RPM's in the upper band all equal oil consumption. Know how you drive, check the oil levels more than you think you should, and you'll be fine.
Side note #1 .. I hate the cock-eyed dip stick. C'mon Nissan.
Side note #2 .. the spec'd oil filters are tiny.
~Shade tree mechanic for friends and family.
