Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
41 registered members (Bjornviken, Ablebody, andyd, 6 invisible), 954 guests, and 39 spiders.
Topics290,743
Posts4,849,426
Members66,033
Most Online3,590
Jan 24th, 2017
Best method to clean carpets and upholstery #4673011
02/21/18 11:24 AM
02/21/18 11:24 AM
Rural Virginia
RF4guy Offline OP
RF4guy  Offline OP
Rural Virginia
I recently acquired a 2004 SAturn Ion that was garge kept and the exterior is great. Previous owner was a smoker and pretty sloppy also. I've been able to clean/vacuum most of the interior surfaces pretty well, but the floor mats are pretty bad with stains and all. Same with the seats. Any ideas how best to get them clean? I have a power washer for use on the mats. Thanks in advance!
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673030
02/21/18 11:35 AM
02/21/18 11:35 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
A professional carpet/Upholstery cleaner.
2004 Corolla 124770
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673045
02/21/18 11:42 AM
02/21/18 11:42 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I have a Bissell portable carpet cleaner and I haven't had a stain it wouldn't take care of.
"Zed's dead baby, Zed's dead."
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673051
02/21/18 11:44 AM
02/21/18 11:44 AM
Rural Virginia
RF4guy Offline OP
RF4guy  Offline OP
Rural Virginia
I was hoping to do them myself if possible.
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673059
02/21/18 11:51 AM
02/21/18 11:51 AM
Rural Virginia
RF4guy Offline OP
RF4guy  Offline OP
Rural Virginia
I was thinking a portable steam cleaner might be an option....how much do they normally go for?
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673061
02/21/18 11:54 AM
02/21/18 11:54 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Go to Lowes or some other place that rents the Bissel Big Green Machine and get the upholstery attachments($30). Use hot water to fill the tank. Then go to Home Depot and get some Folex spot remover($7) and some Zep Premium carpet cleaner($12). Here's a $5 off COUPON .
Rental Locations
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673080
02/21/18 12:07 PM
02/21/18 12:07 PM
Minnesota
bruckus Offline
bruckus  Offline
Minnesota
Really like The Big Green Machine. I have also used the Rug Doctor but like the green machine better.
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673145
02/21/18 12:53 PM
02/21/18 12:53 PM
CA
raytseng Offline
raytseng  Offline
CA
if the floormats are also worn, it is way easier to just bite the bullet and just to get new floormats.
the upholstery if it is fabric just follow the usage instructions od any cqrpet cleaner with upholstety attschment. you must work sny stains with a brush.
Re: Best method to clean carpets and upholstery [Re: raytseng] #4673151
02/21/18 12:56 PM
02/21/18 12:56 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Per the Folex spot remover instructions, spray the spot and work the solution in with your fingers. Of course vacuum everything prior to spraying.
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673197
02/21/18 01:33 PM
02/21/18 01:33 PM
Los Angeles, CA
razel Offline
razel  Offline
Los Angeles, CA
Per others you'll need to rent an upholstery cleaner (extractor). They often will want you to use their cleaner products for the machine. Afterwards, I'd follow up with a degreaser diluted per instructions (SuperClean, Purple Power), agitate, then use extractor again without the cleaners, just water to rinse and wet vac. Then drive it to DIY car wash place with compressed air and blow it. That last part is shockingly good at removing smells... well actually it will distribute the smell into the air where it'll leave your car. You will need to dust your interior afterwards.
You still may get the smell in the air con. You can use a weaker air compressor with a pipe cleaner through the vents to get the dust out.
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673433
02/21/18 04:31 PM
02/21/18 04:31 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
The mats can just be soaked in a tub of warm water with a degreaser/ cleaner and then line dried.
'95 Chevy 1/2t 305 205k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4673434
02/21/18 04:32 PM
02/21/18 04:32 PM
VA
Gebo Offline
Gebo  Offline
VA
The Big Green Machine. There are quite a few home made carpet cleaning recipes on line.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Best method to clean carpets and upholstery [Re: rooflessVW] #4674282
02/22/18 12:24 PM
02/22/18 12:24 PM
co
NissanMaxima Offline
co
Is this what you have rooflessVW? I've always wanted one and Bissel is a quality company. Could be just the ticket for this job and probably about as much as renting a cleaner or other options. Looks like it would be particularly great for seat upholstery but not sure how powerful it would be to extract water from carpeting.
https://www.walmart.com/ip/BISSELL-Little-Green-Portable-Spot-and-Stain-Cleaner-1400M/35702152
Re: Best method to clean carpets and upholstery [Re: NissanMaxima] #4674755
02/22/18 08:11 PM
02/22/18 08:11 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Mine's a step up from that.
Linky
The heat is nice so you don't have to make a new batch of cleaner with hot water each time you use it.
Re: Best method to clean carpets and upholstery [Re: RF4guy] #4674878
02/22/18 10:37 PM
02/22/18 10:37 PM
The 805, CA.
FastEddie Offline
FastEddie  Offline
The 805, CA.
If the seats and carpets are fairly dirty, this is going to be a long painful job with a small spot home based carpet cleaner. Some carpet cleaning companies will do this for a fair price, but they only do the upholstery and carpets. I have a larger Mytee portable carpet extractor and you would be amazed at how much more dirt and grime a pro grade machine pulls out of the upholstery vs. the little machines.
