Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
108 registered members (2015_PSD, Astro14, ABCarr, AandPDan, Al, 2004tdigls, 11 invisible), 2,203 guests, and 29 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
73 Corvette with unknown oil mileage report #4672841
02/21/18 09:51 AM
02/21/18 09:51 AM
Northern KY
Hawkfanatic Offline OP
Northern KY
Hello everyone, I need some interpretation on the oil report below.
This is a 73 Corvette that my uncle is considering buying. No one knows how many miles are actually on the oil, so I guessed at 1000. It could be as little as 500, it could be as many as 10,000. I have no way to know. I also do not know the brand or viscosity.
I know the oil was black when I pulled it. The car was warm, but had sat for about 30min, and that I sampled the first oil that came out of the drain. I basically just loosened the plug and let it dribble out.
I am curious if these numbers seem worse if there is only 1,000 miles on the oil than if there were 10,000 miles on the oil?
Thanks everyone.
2006 Toyota Tundra Double Cab TRD 4x4
1999 Pontiac Trans Am Firehawk
1991 Pontiac Firebird Formula
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4672891
02/21/18 10:18 AM
02/21/18 10:18 AM
Tn.
CourierDriver Offline
Tn.
I'll take one
https://images.search.yahoo.com/search/images;_ylt=A2KLfSK9jI1aWhEAONxXNyoA;_ylu=X3oDMTByMjB0aG5zBGNvbG8DYmYxBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=73+corvette&fr=dss_yset_chr
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4672898
02/21/18 10:22 AM
02/21/18 10:22 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Too bad they didn't do a TBN on the oil. That would have been a good marker of very old/tired oil vs. something only 1K-5K miles old.
Judging from the low calcium, moderate magnesium, phos/zinc, moly/boron mix, it resembles a 5w-30 Mobil 1 oil. If so it started out life around 11.1 viscosity. So that could mean a fairly used up oil to drop from 11 to 9.67. Certainly not 1K miles. Maybe 4K-8K? I don't think this is 1K mile oil as everything seems to point towards it being a Mobil 1 - 30 grade.
PQIA
Isn't this a flat tappet engine? And if that's the case, you'd want more zinc in there than M1 5w-30 could provide. Some Castrol oils also have higher magnesium though this doesn't look like one of them with that low a Calcium number and lower viscosity.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4672928
02/21/18 10:45 AM
02/21/18 10:45 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
OK, uncle buys Corvette. How many actual miles are on the chassis and engine? Auto or stick? What does the tranny fluid and power steering fluid look like? A lot of corrosion around the battery terminals? Is the rear end full?
Look critically at the whole, not just the oil.
Pull a valve cover. That will tell you more about the engine than a unknown mileage oil sample.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4672988
02/21/18 11:13 AM
02/21/18 11:13 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Perhaps the worst UOA I have ever seen on BITOG.
2004 Corolla 130858
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673016
02/21/18 11:27 AM
02/21/18 11:27 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Presence of Mo, Boron , Ca and Mg indicates it's a Mobil 1.
High metal wear rates of Fe, Cu, Pb etc indicates excessive long OCI of 15000-25000 miles of several years leading to extensive oil oxidation and viscosity thickening to 9.67 cSt [email protected]*C.
Thus, oil grade was likely a xW20 of virgin [email protected]*C of 8.5-8.8 cSt.
Suggest 2 short OCI's of 5000 miles each with a mineral/blend xW30 for cleaning, follow by any full synthetic xW20 of choice.
This engine should be good to go.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673083
02/21/18 12:09 PM
02/21/18 12:09 PM
Northern KY
Northern KY
Thanks everyone. To answer some questions and provide more info.. Car and engine have 35,000 miles. It is a 4spd manual. Car is in very good condition, but it sat for most of 20 years before being pulled from a garage. I am thinking some of this wear might be from dry metal parts.
Heres some pics of our inspection at my house on Sunday.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673106
02/21/18 12:26 PM
02/21/18 12:26 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
That car is pretty darn mint. Someone obviously cared well for it before it was put up. Not likely they'd park it with an OCI of 15K-25K miles. The recommended oil for that car was never a 20 grade. Why would anyone use that? And a 4 speed no less which is even more reason to use a 30 grade or higher. And OCI's for that car were originally around the 3K mark. Why would any caring owner push a 25K OCI on such a car, even with modern synthetics? It's a 4 barrel carb'd car which fouls up the oil a LOT sooner than today's FI/DI cars. More than likely it's a 30 grade oil in there and probably with average miles for OCI's of the 1990's to early 2000's. Only 2 engine choices for 1973 Vette....350 or 454.
There could be 10,000 miles on that oil. But probably more likely it's only 2K-6K miles.
1969 Ply GTX/RRs
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673107
02/21/18 12:27 PM
02/21/18 12:27 PM
SW Fla
dernp Offline
dernp  Offline
SW Fla
Very nice
2014 Honda Civic 1.8 28k TGMO 0w20
2016 Honda Civic 1.5T Mobil 1 0w20
2011 Tundra 5.7L 83k TGMO
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673152
02/21/18 12:56 PM
02/21/18 12:56 PM
Northern KY
Northern KY
From what I understand, the car was bought by a young guy in the late 70s/early 80s who had it for a few years, but then died unexpectedly. The car then went to his father who kept it as a sort of memorial to his son and never drove it. When he died roughly 20 years later, it was sold as part of the estate.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673182
02/21/18 01:15 PM
02/21/18 01:15 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Does it sound Okay?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673361
02/21/18 03:37 PM
02/21/18 03:37 PM
Northern KY
Northern KY
Yes, car is smooth and quiet. No smoke, no ticks. A strong car for what it is.
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673503
02/21/18 05:22 PM
02/21/18 05:22 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Wow, very nice. I have nothing else to contribute!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 73 Corvette with unknown oil mileage report [Re: Hawkfanatic] #4673527
02/21/18 05:47 PM
02/21/18 05:47 PM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Blackstone once wrote on one of my reports that old oil can turn acidic and cause these sort of readings. (search post started by me, its probably here, think it was the F100.)
SBC is not expensive to overhaul even if it needs it, Id buy the thing if he wants it, it looks like a nice car... Ill probably offend the purist but it needs a 383 with a roller cam anyway... cool
Robert
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 73 Corvette with unknown oil mileage report [Re: 69GTX] #4673620
02/21/18 07:05 PM
02/21/18 07:05 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I stand corrected.
You're probably right with a xW30 on 6-10k miles (with shear thinning being reversed,and onto thickening) AND many long years ..
Edit:None of fuel dilution btw.
