My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
89 registered members (4WD, 2009Edge, 10ecfarmer, -SyN-, ad244, ammolab, 6 invisible), 1,950 guests, and 38 spiders.
Topics290,949
Posts4,853,020
Members66,062
Most Online3,590
Jan 24th, 2017
Grease for Telescopic/Tilt Screws Lexus LS430? #4672754
02/21/18 08:34 AM
02/21/18 08:34 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
My Tilt/Telescopic Motors are acting up on my '05 LS430. This is a problem area for this particular model. It appears a very inexpensive bushing (45768) will help with the tilt so I am gonna give it a try. I read in a bunch of write-ups where they are simply spraying white lithium grease on the gears for lubrication. I also read where the correct grease to use is "Lexus Lithium Disulfide Body Grease." Do any of you know what I should use to lubricate these gears?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Grease for Telescopic/Tilt Screws Lexus LS430? [Re: Gebo] #4672772
02/21/18 08:58 AM
02/21/18 08:58 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
If they have a specific grease, they probably have a good reason.
Otherwise I'd consider the Dow Molykote range.
Re: Grease for Telescopic/Tilt Screws Lexus LS430? [Re: Gebo] #4673235
02/21/18 02:04 PM
02/21/18 02:04 PM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Are the gears metal or plastic?
I imagine any No2 grease will likely do fine... lithium, aluminum, calcium, polyurea, etc... I'd probably only avoid moly or silicone.
Re: Grease for Telescopic/Tilt Screws Lexus LS430? [Re: Gebo] #4673243
02/21/18 02:09 PM
02/21/18 02:09 PM
California
nthach Offline
nthach  Offline
California
The tilt/telescope gears use Toyota Body Grease W aka Molykote YM-103 grease which is $40-50 at the dealer for a 50g bottle. Appears to be a PAO-based grease thickened with PTFE. Molykote 33 is also used in plastic gears but that's a silicone-based lithium grease.
I'd feel better using the Molykote stuff. I used Tri-Flow PTFE bike grease when I did that repair on a older LS400 but that grease was too stiff for the job at hand.
https://www.chempoint.com/products/catalog/dow-corning/molykote-greases/molykote-pao-greases
Re: Grease for Telescopic/Tilt Screws Lexus LS430? [Re: Gebo] #4678785
02/26/18 03:21 PM
02/26/18 03:21 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Well, I just got my grease. Toyota part #08887-02007 or Molykote YM-102
$44 for 50 g. Only the finest of wheat....
FYI if you care as I realize most of you don't grin
Thanks nthach for steering me in the right direction!
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Grease for Telescopic/Tilt Screws Lexus LS430? [Re: nthach] #4678788
02/26/18 03:23 PM
02/26/18 03:23 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Thank you for pointing me in the right direction!
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
