I bought the brand of oil I typically use in my vehicles and then a Fram Ultra Synthetic filter based on recommendations from this forum. I usually run Napa Gold or OE but this filter was a good deal and I bought it.
The first change was due but I hurt my back so I decided to take it in to a friend who is an old school Honda master tech at the local dealer to do the change and rotation. A few days later, I noticed that there were several small puddles of oil in our otherwise pristine driveway. The only vehicle that parks there is this Pilot. I took it back and my friend put it up on the lift and said the filter was leaking. At first he was sure it was simply residual mess from the change, given the rail that is so close to the filter, but nope, once he got the truck up in the air, it definitely appeared to be the filter. He put a new Honda filter on, sprayed the [censored] out of the rail and area around the filter with solvent, we checked the level (between the two marks) and he sent me on my way. There are drips coming off the rail bolts and in the driveway again, minutes after parking once I arrived home. There is no way in [censored] that it could be the filter again so I'm just going to wait a week or so and make sure it stops. My guess is that there is a mess of oil and solvent mixed sitting in that rail near the filter.
I will admit Fram was gracious when I called them but I will be very wary about using these filters again.
