Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
drnc, blackseven, EdK, guru2019, MBhuntington
68685 Registered Users
97 registered members (1978elcamino, 2015_PSD, ad244, alchargo, Alfred_B, 14Accent, 6 invisible), 2,162 guests, and 30 spiders.
Topics291,984
Posts5,014,596
Members68,685
Most Online2,967
Mar 10th, 2019
'02 Accord V6 Timing Belt Job ? #4672122
02/20/18 05:12 PM
02/20/18 05:12 PM
northern Alabama
benjamming Offline OP
northern Alabama
About to do the timing belt for the 2nd time on my J30A1 V6 engine at 240k miles & almost 18 years old. It was previously changed at 140k miles in 2010-May. Two pictures - one of the crankshaft white mark almost aligned (need slightly more clockwise rotation to be perfect) with the pointer & another picture of the rear camshaft pulley mark aligned (very well I think) with the rear upper cover mark. Am I good to proceed with removing the belt (and water pump, etc.)? In other words, which one rules? Is the crankshaft white mark to get you close & then the rear camshaft pulley mark the more precise locator, vice versa, or is something wrong?
Thanks.
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672165
02/20/18 05:39 PM
02/20/18 05:39 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The cam mark is not aligned either from the picture, move the crank a hair then look again.
Edit: The black pointer on the cam should fill the V cutout. See it?
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672178
02/20/18 05:48 PM
02/20/18 05:48 PM
MN
14Accent Online content
14Accent  Online Content
MN
Why are you trying to align it with the covers on? Take it apart so you can see.
I never line up a J-series before removing the balancer and covers. Once I can see the ACTUAL mark on the crank and cams is when I remove the belt.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672224
02/20/18 06:30 PM
02/20/18 06:30 PM
Virginia
GlazeB Offline
GlazeB  Offline
Virginia
Line the crank mark then remove the 2 upper timing belt covers. There's a line cast into the backside of the timing covers.
2006 Toyota Corolla 270k
2005 Toyota Tacoma 137k
2008 Honda Pilot 101k
1978 Jeep Cj7
