Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
50 registered members (4WD, 1foxracing, 53' Stude, BeerCan, 4 invisible), 1,235 guests, and 34 spiders.
Topics295,095
Posts4,927,734
Members66,684
Most Online2,553
Oct 27th, 2018
Ford specifications on front and rear lube #4672070
02/20/18 03:35 PM
02/20/18 03:35 PM
Northeastern Vermont
littleant Offline OP
Hi folks. On my 2010 mountaineer 4.0 AWD ford spec the rear diff 75w140 Synthetic and for the front 75w90 conventional. Gear ratio is 3.55 open front and rear. What is your opinion on why ford would spec two different weight lubes. Thank you.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Ford specifications on front and rear lube [Re: littleant] #4672082
02/20/18 03:44 PM
02/20/18 03:44 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
My only guess would be a class 3/4 tow package. No other reasons come to mind why a heavy lube like that would be needed in a grocery hauler.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 103K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 35k PP MIX, NG7047
Re: Ford specifications on front and rear lube [Re: littleant] #4672085
02/20/18 03:48 PM
02/20/18 03:48 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Replacement fluids could be:
Rear Amsoil SVG 75W140
https://www.amsoil.com/lit/databulletins/g2043.pdf
Front Amsoil LL 75W90
https://www.amsoil.com/lit/databulletins/g2042.pdf
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Ford specifications on front and rear lube [Re: MolaKule] #4672089
02/20/18 03:51 PM
02/20/18 03:51 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Front Amsoil SVG 75W90
Yes; and if I may suggest 75W-110 for the front axle smile
Re: Ford specifications on front and rear lube [Re: littleant] #4672252
02/20/18 05:56 PM
02/20/18 05:56 PM
New Jersey
Ursatdx Offline
Ursatdx  Offline
New Jersey
Sport Trac rear differential?
Take a peek at the rear axle. The Sport Trac (Limited Slip?)
will have a tag on it stating Syn 75w140.
Some have a 1/2" drive fill/drain plug vs 3/8" and no drain.
If it's a Sport Trac diff, change the fluid.
I'd bet it's black in color.
Re: Ford specifications on front and rear lube [Re: littleant] #4672434
02/20/18 08:26 PM
02/20/18 08:26 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Are you certain other models require the same fluid for front and rear? Maybe this is normal.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Ford specifications on front and rear lube [Re: littleant] #4672444
02/20/18 08:35 PM
02/20/18 08:35 PM
I believe ford has this split spec for the front and rear diff on most SUV AWD. Dyusik yes it does have tow package with the small receiver hitch (1 1/4 or 1 1/2
Re: Ford specifications on front and rear lube [Re: littleant] #4672484
02/20/18 09:04 PM
02/20/18 09:04 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Rear axle typically carries higher load than front axle.
Ford engineer specifies 75W140 for rear axle stronger wear protection ....... and had his way ...
over fellow finance guy albeit at the 'expense' of CAFE credit, where applicable.
Re: Ford specifications on front and rear lube [Re: littleant] #4672486
02/20/18 09:07 PM
02/20/18 09:07 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Itís such a small quantity and you donít change very often, so just get what they recommend. Itís been too many years since I worked with Ford AWDs, but there may be a couple reasons for the lighter weight. If the system is on-demand or significantly rear-biased, the front axle will not produce as much heat. If it is demand-based, likely the only time it will truly be working all the time is in the snow, and the temps are cold enough the lower weight wonít impede fluid life. The rear axle may be doing the brunt of the work all the time, including high temp summers. Thatís my take. Itís much easier when your AWD is 50/50 all the time, rain sleet or snow. Both my AWD transaxle and rear axle take 75w90. Easy peasy!
Re: Ford specifications on front and rear lube [Re: littleant] #4672714
02/21/18 06:39 AM
02/21/18 06:39 AM
Oh I plan on following the Ford spec. I believe the AWD drive on this vehicle is a 70-30 split but can reach 50-50. Thanks everyone good points.
Re: Ford specifications on front and rear lube [Re: littleant] #4676342
02/24/18 10:28 AM
02/24/18 10:28 AM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
Also be aware there is nothing like a 75w90 conventional. Don't lose sleep and use synthetic.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Ford specifications on front and rear lube [Re: MolaKule] #4678680
02/26/18 12:13 PM
02/26/18 12:13 PM
London, UK
Izb Offline
Izb  Offline
London, UK
Why Amsoil LL 75W90 (not Amsoil Severe gear 75W90) in front axle?
