Originally Posted By: Papa Bear
Originally Posted By: sleddriver
Watched a guy recap a dead inverter ckt that brought it back to life.
I worked on a lot of SMPSs as a tech in the 70,80/90s
The good ones had great overvoltage/overcurrent protection circuits.
I remember TVs coming into the shop "squealing" from the chassis and NP/NS. The horizontal output transistor would be shorted and the power supply would be trying to feed 140V into a dead short. It would switch on/off so fast it squealed high pitch. Replace the shorted h/out transistor plus any other failed components and the power supply worked great.
Other SMPS designs blew up almost instantaneously if you had a fault. They were great regulators but poor "forgivers'
Reminds me of the fax machine at home that would not start up after I unplugged it and moved it. I thought the MOSFET transistors
may be blown or the switching diodes went bad, but it was not that at all.
The PS board had lots of small electrolytic caps, 50uF 25V, etc, these were non low_ESR caps, turned out from being left on
for 15 yrs, the little bit of heat generated in the machine slowly dried out the caps and their capacitance dropped from 50uF to
5 to 10uF and the PS would not restart when plugged back in! $2 of parts and I was good for another 15 yrs!
None of the bad caps were bulged though !! The big caps looked OK!
There's just no repair shops you can pay to catch that kind of thing!
