https://www.princessauto.com/en/detail/paint-spray-gun-only/A-p8006583e
This gun has a 2mm nozzle. Will this gun work with thick dripless rustproofing? I have been using a suction feed gun and find that I cannot get enough volume of flow. So it takes a long time to spray a truck. I have come to the conclusion that to speed up the process I need a pressure fed gun.
The pressure pot I am thinking of using is this 10l pot
https://www.princessauto.com/en/detail/10-litre-paint-tank/A-p8006581e
I will also need to use a spray hose. Can a hose be attached to the outlet of the above gun?
