paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Geardaddies, tedonom, 01ws666, ariefnrst, tcoffin014
66658 Registered Users
112 registered members (2004tdigls, 4WD, 28oz, 2008wrx, 69GTX, aba4430, 13 invisible), 1,848 guests, and 41 spiders.
Topics294,978
Posts4,925,290
Members66,658
Most Online2,553
Oct 27th, 2018
AR-15 vs. M-16 Bolt Carrier Group ?? #4671789
02/20/18 11:07 AM
02/20/18 11:07 AM
Glendale, Arizona
billt460 Offline OP
billt460  Offline OP
Glendale, Arizona
Got a question for you AR guys. With all other things equal, (Buffer tube, and buffer tube spring), is running an M-16 bolt carrier group easier on the gun than an AR-15 bolt carrier group is? What I mean is, I swapped out the stock AR-15 bolt carrier group from one of my Bushmaster M-4's, and installed a Nickel Boron Coated M-16 bolt carrier group from Aries Armor. The gun runs fine. Both feeds and ejects beautifully. I'm thinking with the added mass of the M-16 BCG, it will be somewhat easier on the gun because it will slow down the cycle time.
Am I right or wrong? I'm asking because I have another BCM, M-16 BCG I'm thinking of putting in my other Bushmaster 20" rifle. I figure since I have the thing, why not use it? I bought it for an "emergency" spare. But I figure I'll run it and keep the original as a spare. I would rather not start switching buffer tubes and springs. Especially since what I've got already in there is working fine. What do you guys think? This is the M-4, and the 20" rifle I want to put the BCM, M-16 BCG in.
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: billt460] #4671796
02/20/18 11:16 AM
02/20/18 11:16 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
That's rifle length gas right? I suppose you added some cyclic mass with the M16 carrier, but your gas system should already be optimized.
On the other hand if you ever buy yourself a pre-86 full auto lower, then you're all set for FA fire. Other than that, it's just minor differences.
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: billt460] #4671972
02/20/18 02:02 PM
02/20/18 02:02 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
I will only use M16 BCG's in my AR's. And yes, it does slow it down a bit. I could actually tell the difference with the very 1st one I replaced. I use ToolCraft or PSA. And, I think ToolCraft makes BCG's for PSA.
http://www.monmouthreloading.com/shop/toolcraft-5-56-nato-black-nitride-bolt-carrier-group/
http://palmettostatearmory.com/psa-5-56-...logo-39339.html
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: billt460] #4671986
02/20/18 02:15 PM
02/20/18 02:15 PM
Canada
i_hate_autofraud Offline
Canada
Did you use go / no-go chamber gages to be sure clearances with a changed bolt is OK?
I understand the internal anti-bounce weight is different then the semi!
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: billt460] #4672007
02/20/18 02:32 PM
02/20/18 02:32 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Yes the added mass is a good thing. Basically the same thing as adding an H-buffer. The additional mass slows cycling down, which allows the brass to contract, and puts a little less strain on the extractor and other components.
As to buffer springs, they really only have a life span of about 3000 to 5000 ish rounds before they need replaced. The aftermarket space age springs work good, but I've always just replaced my buffer springs with a $2 G.I style replacement. They are cheap enough to just replace.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: i_hate_autofraud] #4672020
02/20/18 02:43 PM
02/20/18 02:43 PM
Reddy45 Offline
Reddy45  Offline
Headspace on an AR is set with the bolt head and the barrel extension. The bolt carrier has no impact on headspace.
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: bubbatime] #4672034
02/20/18 02:52 PM
02/20/18 02:52 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
Originally Posted By: bubbatime
....The additional mass slows cycling down, which allows the brass to contract.....
Interesting. Was wondering what benefit a heavier BCG could provide. Then I got to wondering if this would apply to steel casings as well? My Rock River AR hates steel cases. They will randomly stick solid in the breach forcing me to ram them out with a cleaning rod (it is flawless with brass cases). Of course, the lacquer or whatever polymer covering on the steel cases contributes to this sticking, I'm sure.
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: bubbatime] #4672073
02/20/18 03:38 PM
02/20/18 03:38 PM
Glendale, Arizona
billt460 Offline OP
billt460  Offline OP
Glendale, Arizona
Thanks Bubba. That's pretty much the information I've read, and why I went to them. And when it comes time to change out buffer springs, I'll use the G.I. style as well. They work well and have a fairly good service life. And you can't beat the price.
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: 28oz] #4672336
02/20/18 07:05 PM
02/20/18 07:05 PM
Cajun Country, La.
Cajun Country, La.
Add a BCM extractor spring upgrade kit and this will cure the problem. BCM states that the o-ring is not needed. I tried without/with. It extracted the steel casing much better with the o-ring.
https://www.bravocompanyusa.com/BCM-Extractor-Spring-Uprade-Kit-p/bcm-exspring-1.htm
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: billt460] #4672618
02/21/18 12:01 AM
02/21/18 12:01 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
You want the Colt Gold spring for the AR extractor. There was a high dollar spring comparison done and the Colt was the winner. It was found to be the most durable, with the proper spring tension (you can have too much, or too little). Just the spring and black insert by itself, no o-ring needed (or desired)
All of my rifles have these and I can confirm that they are on the money.
https://www.brownells.com/rifle-parts/bo...y-prod4840.aspx
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: bubbatime] #4672639
02/21/18 01:11 AM
02/21/18 01:11 AM
Cajun Country, La.
Cajun Country, La.
BT, what makes this spring better than the BCM spring kit?
Re: AR-15 vs. M-16 Bolt Carrier Group ?? [Re: BlueOvalFitter] #4673052
02/21/18 10:44 AM
02/21/18 10:44 AM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
Thank you both for that info. I will look into them. Thanks!
