New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
107 registered members (53' Stude, Audios, AZjeff, 69GTX, Al, 9 invisible), 1,922 guests, and 35 spiders.
Topics294,989
Posts4,925,528
Members66,660
Most Online2,553
Oct 27th, 2018
07 K24 - valve adjustment interval #4671673
02/20/18 08:46 AM
02/20/18 08:46 AM
Wishin' I was in Wi
mjk Offline OP
mjk  Offline OP
Wishin' I was in Wi
Hello,
Picked up a 07 Accord with 160k on it this winter. I haven't owned a Honda in decades, but have read that they like their valves to be adjusted periodically.
What is the normal interval, and from a driving perspective, what would I be encountering if the valves were out of adjustment?
Thanks.
Re: 07 K24 - valve adjustment interval [Re: mjk] #4671682
02/20/18 09:00 AM
02/20/18 09:00 AM
Senoia, GA
thooks Offline
thooks  Offline
Senoia, GA
I think Honda used to want them checked every 100k miles.
Not sure what you'd be encountering, I imagine the ECU is making some adjustments somewhere to compensate for the lash being out. If you have the knowhow, time and tools, I'd do it.
IME, the valve cover gaskets on the Hondas are very durable. I don't know that I'd replace it, but I'd go ahead and order a kit (with the tube seals) and have it on hand just in case.
Re: 07 K24 - valve adjustment interval [Re: mjk] #4671683
02/20/18 09:01 AM
02/20/18 09:01 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Does the owners manual have a recommendation? If the valves were out of adjustment they would have to be adjusted.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 07 K24 - valve adjustment interval [Re: CT8] #4671693
02/20/18 09:12 AM
02/20/18 09:12 AM
wv
krismoriah72 Online content
krismoriah72  Online Content
wv
I have had a couple with over 250K and worked on some with many more miles..never had adjustment.
Since its new to you..keep an eye on oil consumption..i think yours is one of the possible oil burners.
Re: 07 K24 - valve adjustment interval [Re: mjk] #4671699
02/20/18 09:15 AM
02/20/18 09:15 AM
Florida
Artem Offline
Artem  Offline
Florida
There's no specific set interval in the service manual for the Honda K Series engines.
Lucky for you, the valves are relatively easy to get too. Have you tried searching the Accord forums to see what other owners are doing with similar mileage and age as yours?
One thing I know, if the engine is running smoothly, why touch anything?
Call around for a Honda tech and have him check the clearances and adjust if needed.
If the car is in good shape and you plan to own it long term and you want the best performance outta the engine, go thru the engine bay and service whatever needs attention.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 07 K24 - valve adjustment interval [Re: Artem] #4671713
02/20/18 09:35 AM
02/20/18 09:35 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Like CT8 asked though, what about the owner's manual? My old Accord lists every 30,000 miles in the maintenance section.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: 07 K24 - valve adjustment interval [Re: mjk] #4671722
02/20/18 09:41 AM
02/20/18 09:41 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I had the CRV's checked at about that mileage and they didn't require much adjustment at all. They sounded fine, and probably I could've left them. They are easy to adjust anyways so if you're planning on keeping it for a while and feel nervous about leaving them, you might as well get them checked.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: 07 K24 - valve adjustment interval [Re: mjk] #4671807
02/20/18 11:26 AM
02/20/18 11:26 AM
Ohio
Dave Sherman Offline
Ohio
The K24 isn't too bad about valves getting out of adjustment. When I checked my '08 CR-V at 100,000 I think one intake valve was slightly loose, that was all. The B20 is the one that is known for valves tightening up and burning, which happened often on the 2001 and earler CR-Vs that used that engine.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 07 K24 - valve adjustment interval [Re: mjk] #4672023
02/20/18 02:47 PM
02/20/18 02:47 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Replace the pcv valve every 60k miles with an oem one. Usually the internal spring breaks around that mileage and can result in oil burning. The one you bought could still have the original in there.
Drain and fill only for the trans on these per Honda. You can do three in a row, spaced out 500+ miles each. Prob do the plugs, drive belt etc. You can also change the oil filter every other oil change, another Honda statement. I'm a moderator on www.driveaccord.net but not very active on there any longer. Too many ads imo since the site was sold to a large conglomerate. But still some good info over there. I found out about this site from over there.
Overall a very reliable unit. A guy on here bought an 06 or 07 Accord K24 with 567k miles on it and in mint condition. Plus it's in MI, the rust belt. The 07 Accords and prior are kind of my favorites. These are also known as the 7th generation Accord. The fourth through the seventh gens are my favorites.
Re: 07 K24 - valve adjustment interval [Re: mjk] #4672217
02/20/18 05:22 PM
02/20/18 05:22 PM
Wishin' I was in Wi
mjk Offline OP
mjk  Offline OP
Wishin' I was in Wi
Thanks for the info. No oil burning, and the first thing I did (other than an oil change), was the PCV valve.
Will wait till spring, and take it down to my mechanic.....running nice and smooth right now.
Re: 07 K24 - valve adjustment interval [Re: mjk] #4672362
02/20/18 07:29 PM
02/20/18 07:29 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Valves only need adjusting if they are excessively noisy. If it's not broke, don't fix it.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
