Omnia - the band
by Shannow
Today at 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
Today at 12:54 AM
Battery stuck in flashlight.
by Chris142
Yesterday at 11:53 PM
Must read for everyone watching their diet
by JLTD
Yesterday at 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
Yesterday at 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
Yesterday at 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
Yesterday at 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
Yesterday at 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
Yesterday at 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
Yesterday at 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
Yesterday at 09:32 PM
Another thick/thin article to discuss
by JLTD
Yesterday at 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
Yesterday at 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
Yesterday at 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
Yesterday at 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
Yesterday at 08:32 PM
VWs at Pick n Pull
by Eric Smith
Yesterday at 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
Yesterday at 08:12 PM
Breaking in new short block
by Bub
Yesterday at 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
Yesterday at 06:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
24 registered (dishdude, billt460, Bjornviken, dlundblad, cven, 2 invisible), 846 Guests and 55 Spiders online.
65299 Members
67 Forums
285816 Topics
Page 1 of 2 1 2 >
#4671576 - 02/20/18 06:25 AM Used oil analisys on Volkswagen Sharan 2.0 170 HP
JorgeMartins Offline
Loc: Portugal
I need some help to interpretate the analisys of the used engine oil from my Used oil analisys on Volkswagen Sharan 2.0 170 HP from 2007. Diesel engine:
I bought this used car with about 142 000 Km.
KM on Engine: 152 388 Km
I donít know the oil brand.
The original engine has 140 HP (103 Kw) but in 2014 the ECU has been reprogrammed to 170 HP.
#4671600 - 02/20/18 07:12 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
CleverUserName Offline
Loc: California
Yikes that is worse than the 10k UOA on my '09 TDI. I now only do 7-7.5K OCI now due to TBN depletion and high wear metals.
Did you really need to add 5L of make-up oil? That is bad. My '09 has 120K miles and still uses zero oil between changes.
Maybe that engine has been abused or it has more miles than you think. I'd do a compression check first.
#4671643 - 02/20/18 08:20 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
Trav Offline
Loc: MA, Mittelfranken.de
Do or have a leak down test done on this engine, I suspect the rings have had it given the high iron and oil consumption. 500cl or 500ml?
Don't be surprised if the engine needs a rebuild, in which case go with a good low km used one and ditch the tune.
Is the turbo okay? How much did they increase the boost with the tune?
Edited by Trav (02/20/18 08:22 AM)
#4671661 - 02/20/18 08:38 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: Trav]
Loc: California
It says 500cL in the Notes and 5L in the description. Since they are the same volume I'm guessing 5L.
#4671685 - 02/20/18 09:03 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
CT8 Offline
Loc: Idaho
Would the tune increase the iron?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4671703 - 02/20/18 09:19 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
Artem Offline
Loc: Florida
oilburner
Jump ship while you still can.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart.
#4671705 - 02/20/18 09:21 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: CT8]
Trav Offline
It could lead to increased engine cylinder wear depending on what they did it.
#4671708 - 02/20/18 09:26 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: CleverUserName]
Trav Offline
I don't see 5L in the description only 500cl in the report, maybe I just don't see it on this small screen, but no matter.
I know 500cl is 5L but 5L would be the more common way of writing it that's why I was wondering if cl was a error for ml.
#4671723 - 02/20/18 09:44 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: Trav]
Loc: California
There a a box titled ďmake up oil addedĒ below the comments section. Itís says 5Ltr was added.
I didnít realize at first this was a 2.0 PD engine? These are kind of rare in USA, 2.0 PD only used in the Passat for 1 or 2 years. I suppose the iron could be from the camshaft as the PDs cam was known to fail with 5w30. However given the ridiculous oil consumption itís not likely IMO.
Edited by CleverUserName (02/20/18 09:51 AM)
#4671746 - 02/20/18 10:07 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
dustyroads Offline
Loc: upstate NY
Whoops...see below. blush
Edited by dustyroads (02/20/18 10:11 AM)
2013 F150 XLT 5.0 4X4 96k+
Edge 5W-30 / Fram 10575
#4671748 - 02/20/18 10:10 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
dustyroads Offline
Loc: upstate NY
Regarding the make-up oil, some people have posted Blackstone reports here and listed the sump capacity in the top off section of their slip. It's possible that the OP did that here...don't know. Then again, maybe it really needed 5 liters of make-up oil.
Edit- if it did require 5 liters of make-up oil, that makes the report even uglier. The wear metals would be more diluted with all of the oil added.
#4671763 - 02/20/18 10:23 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
JohnnyJohnson Offline
Loc: Wet side WA
That is the worst Iron reading I have ever seen in a UOA.
But at least Blackstone didn't tell him to try 12,000 next.
Edited by JohnnyJohnson (02/20/18 10:25 AM)
2004 Toyota Corolla 121758
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4671782 - 02/20/18 11:00 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: JorgeMartins]
Kamele0N Online   sick
Loc: Slovenia
I would aim towards failed injector...wich has transformed itself into blow torch and is now melting your piston and cyl. wall (aluminium&iron)
Put out all glow plugs and have a look inside with a borescope...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4671811 - 02/20/18 11:29 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: Kamele0N]
Loc: Slovenia
Sorry thats for commonrail diesels...
Have a look under valvecover how is your injector/valve (its one camshaft for both) camshaft doing smile
#4671830 - 02/20/18 11:44 AM Re: Used oil analisys on Volkswagen Sharan 2.0 170 HP [Re: CleverUserName]
Loc: Portugal
Sorry, my mistake, added 50cl, half liter
Edited by JorgeMartins (02/20/18 11:56 AM)
Page 1 of 2 1 2 >
