Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on ‚Äúclearance‚ÄĚ at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
Anti seize or brake grease on brake pads #4671194
02/19/18 06:47 PM
02/19/18 06:47 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
I understand using silicone base lubricant for slide pins but there seems to be some debate between using copper anti seize or brake grease on the pad ears and possibly backing. Iíve searched the forum and it seems the last discussion of this was 5 or so years ago. Iíve seen YouTube videos where Chrisfix and ericthecarguy are using copper anti seize. I trust their opinion but I always thought you want to use grease like permatex green or purple. Wondering if the general consensus has changed. Also Iím wondering if it would be wise to use anti seize on the wheel hub to rotor contact point. Long story short, do I need to find some copper anti seize, I have aluminum already.
‚Äė19 Grand Caravan- factory fill
'13 Toyota Tundra 5.7-Idemitsu 0w-20/OEM
'08 Hyundai Elantra-Havoline 5w-30/Fram 9688
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
‚Äė01 Kawasaki KDX 220r
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671202
02/19/18 06:55 PM
02/19/18 06:55 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I spray the back of the pads with the Permatex 80077, and use their green grease for the pad ears. Sil Glyde goes on the pins. No problems to report.
God Bless Our Troops
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671206
02/19/18 06:59 PM
02/19/18 06:59 PM
ME
eljefino Offline
eljefino  Offline
ME
I use a smidge of permatex grey goo. Might not be perfect-right but it's what I have on hand.
More importantly I grind new ears that are too big so they fit the abutment clips without forcing them in.
Re: Anti seize or brake grease on brake pads [Re: eljefino] #4671217
02/19/18 07:16 PM
02/19/18 07:16 PM
wv
krismoriah72 Offline
wv
Sil Glyde-
ē Back side plate of disc brake pads
ē Anti-squeal shims
ē Caliper slides, bushings, boots, and seals
I have also used antiseize.
I file all ears that dont slide smoothly and snugly.. Usually there is excess paint or burs on the cheaper pads.
To be honest the lubes dont make it the life of the pad..with people washing their car and driving thru rain most if not all washes off eventually. If you were in the desert i would say it would last alot longer.
I wouldnt put anything near the hubs, nor overdo any of the lubes...due to slinging on the rotor and bedding in the pads.
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671226
02/19/18 07:26 PM
02/19/18 07:26 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Nothing ever seems text book regarding brake lubes. There have been numerous threads about some vehicle brand brake rubber swelling if one is not exceedingly particular about using a specific product on pins/bushings. Not gonna go there now.
It seems that it is preached to keep petroleum solvent lubes away from brakes entirely. Obviously it can affect the internal caliper seals and other internal rubber components if it makes its way into the fluid exposed areas. But what about the exterior?
3M has a copper anti-seize labeled for brake use. It purports to be water washout resistant and for metal to metal contact areas. Is it better than any other type of anti seize for this application? I don't know. It DOES contain petroleum solvents AND I have seen shops use it not only on exterior exposed parts, but also on the rubber bushed pins. This goes against the preaching to keep petroleum solvents away from brakes.
https://multimedia.3m.com/mws/media/1080858O/3mbrake-jobs-made-better-bulletin.pdf They show silicone for the pins/bushings and the copper for exposed metal to metal areas.
I prefer to use a silicone type brake lube for the pins and a high solids non petroleum product for the water exposed metal to metal areas. Two examples are: Honda(Dow) m77
https://www.walmart.com/ip/Honda-08734-0...13=&veh=sem
or
Pastelub https://goodson.com/products/bpl-2400-pastelub-brake-lubricant This is a Swiss made product that is impervious to water wash off and I LOVE it. Inexpensive, tenacious, and stops rust excellent. I use it on brake metal to metal areas(pad ears/back) , rotor hats, and hubs. I "think" my high solids pastes are more water washout proof, have less oils to migrate on to unwanted areas, AND leave some boundary lube (marbles) when the oil eventually dissipates.
Yes, use something on the hubs, pad ears, etc. to prevent rust. Just a paper thin layer. Good luck making your decision.
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671231
02/19/18 07:34 PM
02/19/18 07:34 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Throughout the years, peoples opinions varied. At some dealers it was all silver anti seize, some used the pink brake paste, and the BG additive that you let soak into the pads. BMW said nothing on the pads at all, only the slide pins. Its all what works best for you. Ive been going with lubing slide pins, under ears, and in the channel for the ears on the caliper bracket
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671236
02/19/18 07:36 PM
02/19/18 07:36 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
My neighbor had a brand new hyundai sante fe, you could see the copper anti seize on the pad ears. That ended the debate for me. If there is copper anti sieze on the pad ears on a car from the factory, I would assume that it is ok to use it on the back of the pads, too. Silicone washes off quickly, anti seize sticks like glue.
Also, I'm pretty sure sil glide (I got sil-eze from napa here in canada) is only like 5% silicone. When I kill my tube, I am going to get the 3M silicone paste.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671266
02/19/18 07:51 PM
02/19/18 07:51 PM
Washington, DC
CapitalTruck Offline
Washington, DC
GM brush-on silicone brake lube for pins and ears. Nothing on rear of oem shimmed brake pads. Only OEM pads used. (I once got Carquest Blue pads and the things stopped NOTICEABLY worse. That was the end of the non-OEM pad experiment).
2013 Silverado 4.8L VVT 4x4 97k mi - ACDelco Dexos Full Synthetic 5w30 (ExxonMobil variant), ACDelco PF48E
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671292
02/19/18 08:08 PM
02/19/18 08:08 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Here is a picture of a Pastelub protected hub with 5 years of salt bath exposure and a similar aged hub with no protection:
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671293
02/19/18 08:10 PM
02/19/18 08:10 PM
NC
BigD1 Offline
BigD1  Offline
NC
M77 is good stuff for the metal parts that's for sure. The high moly content actually burnishes the metal surfaces.
On non-shimmed pads, CRC Disc Brake Quiet is a winner in my book. Some times it's the shims that causes the noise. That's when I throw the shims in the trash, and use the CRC.
http://www.crcindustries.com/products/disc-brake-quiet-4-fl-oz-05016.html
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671295
02/19/18 08:11 PM
02/19/18 08:11 PM
CA
The Critic Offline
The Critic  Offline
CA
Toyota soap-based grease on the slide pins and M77 or AS880N for the shim kits and pad ears.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671299
02/19/18 08:16 PM
02/19/18 08:16 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Hee hee. You said "consensus" You can't get any of this stuff here, so I would bet Taiwanese mechanics use general purpose lithium petroleum base grease on everything, not unknown with British mechanics.
It's a good life rule to do whatever Taiwanese mechanics don't, so I use silicon grease (bought in Japan) on the slide pins with a wrap of PTFE tape. The latter is perhaps not good if the brakes ever get very hot and I probably wouldnt do it again
I use a trace of Aluslip on the pad ears
I can't think of any reason copper would be better but I can think of a reason it would be worse, so i wouldnt buy it if I could. I think grease on the hub would probably be ok but it could theoretically get slung off with heat and centrifugal forces
I use a thin sheet of polythene
In the past I've used aluminium foil.
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671456
02/19/18 11:57 PM
02/19/18 11:57 PM
Illinois, U.S.A
RamFan Offline
RamFan  Offline
Illinois, U.S.A
This is what I used on my last brake job. Seemed to work well on the pins and pads.
18 Giulia Ti Sport Q4
+2.0l turbo - 8k - PP Euro LX 0w30 - Mopar - 10k/1yr
16.5 CX-5 Touring AWD
+2.5l - 54k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: Anti seize or brake grease on brake pads [Re: Audios] #4671481
02/20/18 12:58 AM
02/20/18 12:58 AM
Georgia
AVB Offline
AVB  Offline
Georgia
The last brake class I attended with Chrysler recommended not using any lube. On the other hand We have a Mopar branded lube in a tube similar to the pic above, it looks and feels like gray anti seize.
Re: Anti seize or brake grease on brake pads [Re: pda1122] #4671534
02/20/18 04:55 AM
02/20/18 04:55 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
per the Nissan maintenance manual, I use Molykote 7439 (copper based anti-seize) on the pads where they slide in the pad retainer shim and I use Sil-Glyde on the pins and other areas that float. This is all per the repair manual.
