2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (alphadog, Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,422 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Where are the ANs? #4671138
02/19/18 05:50 PM
02/19/18 05:50 PM
Toronto
PeterPolyol Offline OP
Toronto
Not much talk about ANs as there is about POE and PAO, who's blending with the ANs as base oil these days? I'd guess Mobil carried some of it over from their xxxxSyn days, but still not sure if it was used as a significant part of the base blend, an AN surfactant or both? Also from casual reading, I don't really associate ANs with other consumer brands than Mobil, but surely ANs must be widely used across the industry and in the consumer engine oil market, even if just as an additive. Has anyone heard or know of what other products use AN adds and/or base oils? Do ANs even have any disadvantages for engine oils?
There's no replacement...'scosity for natural viscosity
Re: Where are the ANs? [Re: PeterPolyol] #4671183
02/19/18 06:34 PM
02/19/18 06:34 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
ExxonMobil makes them, sells them, and was using them in their Mobil 1 blends. They generally recommend them as a blending stock at low levels (up to 20%), to enhance other base oils such as PAOs and POEs. Back when they introduced them they were quite expensive, around POE levels. Don't know the current status or who else is using them.
I compared them to POEs in high temperature tests some 14 years ago with identical simple additive packages. In a bulk oxidation test at 218C they showed much higher viscosity and TAN increases and sludge formation than equivalent viscosity POEs. In a coking test at 282C they produced more deposits. Mind you these are very high temperatures where I always evaluated POEs, but I believe at more typical oxidation test temperatures they would have performed better than PAOs and Group IIIs, and would do very well in motor oils. Also the Noack volatilities were much higher than POEs.
The principal disadvantage is low VIs, and the pour points aren't so great.
Re: Where are the ANs? [Re: PeterPolyol] #4671307
02/19/18 08:24 PM
02/19/18 08:24 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Where are the ANs? [Re: PeterPolyol] #4671309
02/19/18 08:27 PM
02/19/18 08:27 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I can't speak for others but I abandoned AN's years ago for various reasons.
Re: Where are the ANs? [Re: PeterPolyol] #4671459
02/20/18 12:14 AM
02/20/18 12:14 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Nulon full synthetic Race Oils in Australia
Quote:
Designed to protect at extreme temperatures and sustained high RPM, Nulon Racing Oils were developed from high quality Group IV Poly Alpha Olefin (PAO) and Group V Alkylated Naphthalene (AN) base oil stocks. The PAO and AN formulation offers a range of advantages over Ester based oils in high performance engines.
https://www.nulon.com.au/products/race-oils
Quote:
5W-30 Racing Oil
High anti-wear protection package (Zinc + Moly DTc = 2300PPM)
Suitable for race and highly modified street engines
Durable shear stable formula
High temperature protection
Advanced Group IV Poly Alpha Olefin (PAO)
Advanced Group V Alkylated Naphthalene (AN)
They make 0W20, 5W30, 5W40, 5W50 and 10w60
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Where are the ANs? [Re: PeterPolyol] #4671467
02/20/18 12:44 AM
02/20/18 12:44 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Racing oil is good for the duration of a race......... but will it last 5,000 miles in varied driving conditions without going sour?
Re: Where are the ANs? [Re: Linctex] #4671557
02/20/18 06:37 AM
02/20/18 06:37 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Not too sure about the Nulon as it's new to the market, but the Penrite 10-Tenths racing oil (100% PAO & Ester) is also made to be used in highly modified street cars as well as race engines, so it carries real specs (e.g. 10W40 racing is still API SN & ACEA A3/B3 with a TBN of 9.8) I've used this oil before in my motorcycles that I take to 6k miles OCI.
The same oil was used in the V8 race car that won the most recent Bathurst endurance race, that's the big one in Australia.
Aussie performance heads, want race oils that they can run in their street cars. So that is what Penrite, and now Nulon I assume, make for them. They are very good sellers.
Re: Where are the ANs? [Re: PeterPolyol] #4671559
02/20/18 06:40 AM
02/20/18 06:40 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Agree...Penrite have everything needed to get the manufacturer's OCI with the addition of the elevated additives.
I haven't researched the Nulon products enough to say yay/nay.
Re: Where are the ANs? [Re: SR5] #4671561
02/20/18 06:44 AM
02/20/18 06:44 AM
Texas
4WD Offline
4WD  Offline
Texas
That Nulon looks like a cat killer
Im surprised there have not been more environmental folks in the middle of this
Maybe they are fully focused on causing black outs wink
Re: Where are the ANs? [Re: 4WD] #4671562
02/20/18 06:47 AM
02/20/18 06:47 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Nulon does say:
Quote:
NOTE: Not recommended for vehicles fitted with catalytic converters.
Re: Where are the ANs? [Re: 4WD] #4671572
02/20/18 07:06 AM
02/20/18 07:06 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
But great for preventing LSPI as Moly & Zinc both reduce LSPI events.
But yeah....it's not for the average grocery getter.
Re: Where are the ANs? [Re: PeterPolyol] #4672381
02/20/18 08:49 PM
02/20/18 08:49 PM
Toronto
Toronto
Interesting bit about the high temp oxidation and coking tests test, Tom. 218-282 Celcius is pretty extreme but lines right up with how well POEs perform in turbos and the roastiest parts of an engine.
Mola, that was the thread I stumbled across again which got me asking about AN use in today's market. Any specific reasons why you guys don't really bother with ANs anymore- price:performance just not there?
As for finished engine oils, google only pulled up the Aussie blends SR5 posted that are clearly stating AN use outright, the rest of the results were mostly sales literature from base oil suppliers. The 'pros' seemed to outweigh the cons as I was specifically looking out for the disadvantages.. but not much talk about that. There were also a few resources comparing the cleanliness and deposit fighting properties of the ANs, so I had to ask.
I don't doubt Nulon and Penrite have their stuff sorted out with those race oils, there have got to be more engine oils out there with AN or even ABs, though they seem to be more popular in manufacturing industry and hydraulics than engine oils
https://www.stle.org/images/pdf/STLE_ORG...pplications.pdf
