Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
12 registered (DRNJR, Gubkin, hank2, GMguy84, dlundblad, bbhero, 1 invisible), 798 Guests and 33 Spiders online.
65299 Members
67 Forums
285816 Topics
Page 1 of 3 1 2 3 >
#4670943 - 02/19/18 02:04 PM Walnut blasting dyno results
Tommiee Offline
Loc: The Netherlands
I work at a tuning company and also do some specialist things like DSG diagnosis/repairs, DPF cleaning( not the cheap way but the good way ), DPF removals, tranny flushes and intake cleaning.
Wanted to share this walnut blasting cleaning with you guys. I'ts my dads car, recently bought. '08 Mini clubman john cooper works 211hp. 1.6 direct injected turbocharged engine.
When i drove it i felt like it was holding back, hesitating and not delivering power.
I have put the car on our superflow 4x4 dyno and measured. Then cleaned the valves using our walnut blasting tool and after that used the tunap valve clean spray with running engine.
Let these results speak for themselves
Black lines stock before valve cleaning. Red lines after cleaning
Stock with dirty valves 191 hp
Stock with cleaned valves 211 hp ( exactly as per manufacterer! )
Testdrive after cleaning also confirmed a drive without hesitation and improved performance.
Edited by Tommiee (02/19/18 02:28 PM)
Seat Leon 2.0T FSI 2007 380HP / 370 lb ft
Petronas Syntium 7000 0W40 + LM Ceratec
Mahle Filter
Suzuki Alto 1.0 2011
Shell Helix Ultra 0W20
#4670980 - 02/19/18 02:32 PM Re: Walnut blasting dyno results [Re: Tommiee]
DriveHard Offline
Loc: Middle of Iowa
cool pics, some of the worst valves I have seen!!
Smile, it increases your face value
2011 Silverado Crew Cab LT 6.2L/6spd
2017 Jeep Renegade Trailhawk (wife's)
2007 Nissan Xterra (trail toy)
2013 Fiat 500 Abarth (my DD)
Elio...?
#4670981 - 02/19/18 02:33 PM Re: Walnut blasting dyno results [Re: Tommiee]
javacontour Offline
Loc: Illinois
Looks like about a 10% improvement in most of the plots. Not bad.
network down, IP packets delivered via UPS -BOFH
#4670983 - 02/19/18 02:34 PM Re: Walnut blasting dyno results [Re: Tommiee]
Tommiee Offline
Me too drive hard
Could not believe my eyes when i saw these with only 70k miles on the car..
Mahle Filter
#4670985 - 02/19/18 02:36 PM Re: Walnut blasting dyno results [Re: javacontour]
Tommiee Offline
@javacontour
Yes, and also notice the curve being more straight with a lot less pikes in the high rpm area.
Edited by Tommiee (02/19/18 02:37 PM)
Mahle Filter
#4670993 - 02/19/18 02:42 PM Re: Walnut blasting dyno results [Re: Tommiee]
Reddy45 Offline
Loc: USA
Does the blasting media get vacuumed out? Or what happens to it?
#4670994 - 02/19/18 02:42 PM Re: Walnut blasting dyno results [Re: Tommiee]
HemiHawk Offline
Loc: PA,US
Thanks for doing this and sharing the results! I've been worried about build up on my GTI. It looks like catch cans reduce the problem somewhat, but not all together. And good cans for some of these cars are so expensive you might as well just drive it until it needs a cleaning.
That power number is also great, seeing the rated number at the wheels is always good. Is that torque number ft/lbs?
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1997 Jeep GC 4.0
#4671001 - 02/19/18 02:48 PM Re: Walnut blasting dyno results [Re: Tommiee]
Tommiee Offline
@reddy45
Yes you vacuum it out during the blasting. Special adapters make you vacuum and clean during the same time.
@hemihawk
In europe we always talk about crank HP. These figures are crank hp and Nm. We first do a drivetrain loss measurement in the gear that we are going to use to measure te power ( 4th gear most of the times )
So its exactly 211 crank hp's and converter to lb ft its around 224 crank lb ft.
Mahle Filter
#4671012 - 02/19/18 03:05 PM Re: Walnut blasting dyno results [Re: Tommiee]
supton Offline
Loc: NH
Interesting. 20hp loss, or 9%. That's a lot of crud. I suspect 9% is a detectable seat of the pants measurement
I know every engine design is different. Is it a linear loss? as in, different engine with half that crud, is it 5% loss?
2011 Toyota Camry, base, 2.5L/6MT, 162k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 143k, ours
1999 Toyota Camry LE, 2.2L/4AT, 183k, his
#4671016 - 02/19/18 03:09 PM Re: Walnut blasting dyno results [Re: Tommiee]
Tommiee Offline
I dont think the loss is linear. I think it it doesnt lose much power in the first build up phase. But seeing the valves like this i think a little more buildup would cause the engine not to deliver any decent power anymore.
Mostly you can feel that the engine is running right. Pulling strong and linear without shocks and hesitation.
Ofcourse we have tuned the engine after all of this was done. 228 hp and 350 nm if the best we got out of this engine in complete stock form.
Edited by Tommiee (02/19/18 03:11 PM)
Mahle Filter
#4671030 - 02/19/18 03:37 PM Re: Walnut blasting dyno results [Re: Tommiee]
KGMtech Offline
Loc: SW Ontario Canada
Impressive solution. What would this cost a non-family customer?
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
#4671046 - 02/19/18 03:49 PM Re: Walnut blasting dyno results [Re: Tommiee]
OVERKILL Offline
Loc: Ontario, Canada
That's nuts (pardon the pun).
And this is why some people seem to have at least a somewhat rational concern about DI. Not a problem on port injection applications.
2016 Durango Limited
2016 Grand Cherokee SRT
#4671056 - 02/19/18 03:57 PM Re: Walnut blasting dyno results [Re: Tommiee]
WhizkidTN Offline
Loc: E. Tennessee
Another reason I like the dual systems that have both Port and Direct Injection (ECU moves between the two depending on load/mode, etc.).
At least in this type of engine, the use of fuel tank based cleaners (and just running good Top Tier Gas) can keep the intake valves decently clean.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (71K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (66K)
>EDGE 0W-20, Fram XG6607
#4671089 - 02/19/18 04:16 PM Re: Walnut blasting dyno results [Re: Tommiee]
Dylan1303 Offline
Loc: Washington
How many miles or km where on it before the cleaning?
12 chevy cruze 1.4t 6spd penz euro 0w40
09 ford fusion 2.3l auto royal purple 5w20
#4671095 - 02/19/18 04:19 PM Re: Walnut blasting dyno results [Re: Tommiee]
Trav Offline
Loc: MA, Mittelfranken.de
That's quite an improvement. A walnut blaster that incorporates a shop vac is fairly easy to make from cheap HF stuff, they even have the shells.
Page 1 of 3 1 2 3 >
