One of the sensors is bad on the Silverado. The "Service Tire pressure monitor system" message came across the message center.
I'm going to assume that it is best to replace all four since if one is bad then the others probably aren't to far behind.
Question is, is there a any good aftermarket brands for this vehicle. I'm finding prices ranging from $50 to $150 for a set of 4 online. Are all the brands able to be programmed by the local tire shop?
Thanks!
Thanks!
