Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
67 registered members (4WD, 2015_PSD, 2003f7, 69Torino, 4 invisible), 1,310 guests, and 62 spiders.
Topics286,367
Posts4,907,122
Members67,613
Most Online2,967
Mar 10th, 2019
ABS and Traction lights on? 2015 Charger #4670812
02/19/18 12:52 PM
02/19/18 12:52 PM
New Hampsha
Blue_Goose Offline OP
New Hampsha
Well after a few nice days of driving the Charger, my last startup presented this issue. 2 chimes and the ABS and Traction lights lit up on my dash. Doing some googling the most likely culprit is perhaps a ABS wheel sensor.
None of the parts stores have a scanner that can determine what the issue is or which sensor is causing the issue so it looks like a trip to the dealer is in order. Iím just a couple hundred miles over the 36k warranty. Figures right?
Any idea what Iím looking at $$ wise if it is indeed a sensor?
2018 Honda Civic EX Hatchback 1.5T
2003 Honda Accord EX-L 2.4L 5MT
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4670816
02/19/18 12:58 PM
02/19/18 12:58 PM
WI
HoosierJeeper Offline
WI
Not much, probably $100-200. If you complain enough they'll warranty it, the dealer has some leeway.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4670828
02/19/18 01:02 PM
02/19/18 01:02 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If you have time , jack up each wheel , one at a time . Do a visual of the wheel sensor and wiring . You may discover the defect yourself .
Also , look for leaks .
I would still try to get it fixed under warranty .
As for as ABS codes , I do not know if they persist , once you turn off the ignition switch .
But , first , check to determine if you are low on brake fluid .
Wyr
God bless
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4670854
02/19/18 01:27 PM
02/19/18 01:27 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
How's your battery?
Re: ABS and Traction lights on? 2015 Charger [Re: JHZR2] #4670950
02/19/18 03:11 PM
02/19/18 03:11 PM
New Hampsha
New Hampsha
Originally Posted By: JHZR2
How's your battery?
Seems ok. No issues starting or cranking
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4670964
02/19/18 03:20 PM
02/19/18 03:20 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
If you're just barely past the warranty, they might be nice and cover it.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4670965
02/19/18 03:20 PM
02/19/18 03:20 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Surprisingly the rear uses very inexpensive external sensors the front are built into the hub, an SKF front hub is about $160 at rock.
For some reason many ABS tools have a tough time reading Chrysler products. Do you know anyone with a real scan tool? You could always pull each wheel and check the resistance. Ask the dealer first they might take care of it under goodwill.
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671031
02/19/18 04:38 PM
02/19/18 04:38 PM
New Hampsha
New Hampsha
Well I went to the shop that I usually have all my work done at to see if he could pull the code:
It came back with this:
C003462 Right Front Wheel Speed Sensor Signal Compare Failure
He told me to check with Dodge to see if they will cover it, if not check back with him. I'm wondering what my odds are with the dealer believing me that is what the problem is. I know they will probably want to do their own scan and get that diagnostic fee.
Anyone familiar with this code? I'm not to warm and fuzzy about the Dodge service departments in my area but....I did find a TSB for incorrectly mounted front sensor wires but my car has a build date of 3-15 so not sure if this applies or not. Looks like I may be able to turn the tires and take a look
https://chrysler.oemdtc.com/587/incorrec...5-dodge-charger
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671033
02/19/18 04:41 PM
02/19/18 04:41 PM
New Hampsha
New Hampsha
Then again I have no idea why the way it is mounted would cause a code to be thrown. That probably isn't it
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671042
02/19/18 04:47 PM
02/19/18 04:47 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Sounds like you've found your culprit. I'd definitely pressure your dealer to cover it given the age of the vehicle.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671070
02/19/18 05:07 PM
02/19/18 05:07 PM
USA
mk378 Offline
mk378  Offline
USA
Did you look at the wire? Seems that it could be seen with the car on the ground by turning the wheels all the way to one side.
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671072
02/19/18 05:08 PM
02/19/18 05:08 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Just take off the wheel and take a look at it. A simple problem would be a wiring problem or the sensor is loose/dirty or maybe it's just broken.
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671086
02/19/18 05:16 PM
02/19/18 05:16 PM
USA
mk378 Offline
mk378  Offline
USA
My guess is if improperly mounted, there is stress or water incursion and it breaks the connection, requiring a new sensor. Which really should be covered.
If you find it is wrong, don't touch it, go directly to the dealer.
Re: ABS and Traction lights on? 2015 Charger [Re: mk378] #4671107
02/19/18 05:26 PM
02/19/18 05:26 PM
New Hampsha
New Hampsha
I did pop it off to see if I could get it to sit like the correct way but it didn't look right so I put it back.
I took a pic to show you guys how it looks and in looking at the pic I can see a little split in the sheathing (at least it looks that way to me) I wonder if this is the issue? The moisture you see is probably from the roadway as I was out driving just before I took the picture
Also I'm not sure it that if that link applies to me now that I re-read it. It mentions AWD Police vehicles which is not mine
Re: ABS and Traction lights on? 2015 Charger [Re: Blue_Goose] #4671110
02/19/18 05:28 PM
02/19/18 05:28 PM
USA
mk378 Offline
mk378  Offline
USA
That is indeed wrong, and the sensor cable is damaged because of it. You deserve a free replacement from Dodge.
Yes it sort of doesn't look right with the wheel side facing up, but the engineers wanted it that way for a reason and the assembly line people ignored them.
