Originally Posted By: muddawgs
Your best bet is to go on the f150 forums and research the EB's for failure trends of the stretched timing chain, phasers, internal water pump leak into the oil pan, thrown rods from slighlty overfilled oil, cac filling up with water, carbon etc.. Some of those maybe fixed now but it seems very hit and miss from some. From the issues my f inlaw has had on his 16 3.5, i would pass on the EB if it was a long term keeper vehicle. If it's a lease then have fun.
EB 3.5 in the F150 does not have an internal water pump. I do hang out in the F150 forums and yes there have been issues, they should be fixed by now. I believe the timing chain stretch was fixed by 2015 - IIRC it was a combination of phasers and casting debris. Same with the CAC - fixed by 13 and the TSB fixes for most. The rest don't seem to be trends.
