Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
66 registered members (alarmguy, Back40, arowbat, AndyB, Astro_Guy, avi1777, 9 invisible), 847 guests, and 53 spiders.
Topics286,106
Posts4,902,689
Members67,563
Most Online2,967
Mar 10th, 2019
Vibe; 1ZZ-FE, under vc, 265k miles #4670610
02/19/18 09:50 AM
02/19/18 09:50 AM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
Changed the original valve cover gasket, and timing chain tensioner over the weekend. The VC gasket around the spark plugs was very hard and brittle, cracked apart upon removal.
I'm the original owner. It's been very reliable. Only other non original parts on the car are intake gasket, and struts. Other than wear items of course; brake pads, battery, etc. Car has had all different types of oil. But the last couple years it's had Rural King synthetic, and cheap oil filters, changed at about 5-6k miles. Still drives like new. Original O2 sensors, mpg same as original. Maxlife ATF; changed every 30-40k miles, or if it starts to look darker.
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670619
02/19/18 10:04 AM
02/19/18 10:04 AM
Virginia
GlazeB Offline
GlazeB  Offline
Virginia
Looks great especially for the mileage! Still using the 5w20 spec? That's on my to do list soon along with the Timing chain tensioner smile
2006 Toyota Corolla 270k
2005 Toyota Tacoma 137k
2008 Honda Pilot 101k
1978 Jeep Cj7
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670640
02/19/18 10:22 AM
02/19/18 10:22 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
Does look great. Good for you & seems that your routine works really well with oil/filters.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (100K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: GlazeB] #4670656
02/19/18 10:30 AM
02/19/18 10:30 AM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
Thanks... Have always used 5w/30. That was spec'ed for this engine.
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670692
02/19/18 11:00 AM
02/19/18 11:00 AM
socal
barkingspider Offline
socal
Looks super clean for high mileage
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670713
02/19/18 11:16 AM
02/19/18 11:16 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Very nice..
God Bless Our Troops
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: demarpaint] #4670721
02/19/18 11:22 AM
02/19/18 11:22 AM
wv
krismoriah72 Offline
wv
What year is this one?
A matrix/vibe is on my radar for my next commuter car.. so since you have logged a bunch of miles..
Is it a comfortable ride? Is highway and road noise bad? Does it struggle on hills and mountains?
Maintenance easy? Transmission pan have a plug?
From what I remember when you hit 299999 on the odo you are stuck there right?
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670725
02/19/18 11:27 AM
02/19/18 11:27 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Engine looks great . Congrats on doing a great job maintaining your Vib ! :-)
You plan on driving it as long as possible ?
Wyr
God bless
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670741
02/19/18 11:47 AM
02/19/18 11:47 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
I was surprised at how brittle and plasticy that was on my wife's Corolla's 1ZZ-FE also. I wasn't ready for it and ended up having to carefully fish out some shrapnel.
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: krismoriah72] #4670753
02/19/18 12:02 PM
02/19/18 12:02 PM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
It's a 2004. I guess some of that is subjective. It's all I drive, so I'm use to it. Good tires help a lot with road noise. I think it has plenty of power, but I'm not afraid to put it to the floor if needed... grin
Maintenance couldn't be easier. Trans has a plug, and the pan can be dropped easily if needed. I replaced the filter around 200k, but probably didn't need to. Oil filter is right up front, and mounted vertically, super easy to remove.
I think odometer will stop at 299,999. Guess I'll use the trip odometer, and a pad of paper.. smile
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: WyrTwister] #4670754
02/19/18 12:02 PM
02/19/18 12:02 PM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
Thanks. Yeah, I plan on seeing how far it goes... We'll see
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670801
02/19/18 12:44 PM
02/19/18 12:44 PM
Southeast
meep Offline
meep  Offline
Southeast
you can't ask for better. at that age, any design flaws and maintenance flaws will have not only shone but usually send it to the crusher. I'll bet you've never even had to regap the valves? Fantastic.
2018 F150
2015 crv (wifey!)
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670815
02/19/18 12:58 PM
02/19/18 12:58 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
Great job!
...If this is what I have to look forward to....I welcome it.
I am 37K miles behind you and I will technically catch you at 299,999 miles. Other than oil & ATF and tire changes, I haven't had to do a thing to it....LOL I am still on my factory brakes and battery. Has had PP since 600 miles.
These cars are boringly, ridiculously, reliable.
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: MarkM66] #4670847
02/19/18 01:20 PM
02/19/18 01:20 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Looks awesome. Proper maintenance goes a long way.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Vibe; 1ZZ-FE, under vc, 265k miles [Re: ARB1977] #4670917
02/19/18 02:38 PM
02/19/18 02:38 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Absolutely
There's no replacement...'scosity for natural viscosity
