Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
96 registered members (4WD, Ag76, 2015_PSD, 53' Stude, A310, 12 invisible), 1,920 guests, and 35 spiders.
Topics296,969
Posts4,962,611
Members67,009
Most Online2,821
Jan 21st, 2019
TPMS sensor bad #4670436
02/19/18 01:19 AM
02/19/18 01:19 AM
SE Ohio
MuzzleFlash40 Offline OP
SE Ohio
One of the sensors is bad on the Silverado. The "Service Tire pressure monitor system" message came across the message center.
I'm going to assume that it is best to replace all four since if one is bad then the others probably aren't to far behind.
Question is, is there a any good aftermarket brands for this vehicle. I'm finding prices ranging from $50 to $150 for a set of 4 online. Are all the brands able to be programmed by the local tire shop?
Thanks!
18 Sonata SEL 2.4-12k
Syntec 5w30 & OEM
16 Santa Fe Sport AWD 2.4-67k
PP 5w30 & OEM
09 Silverado LT 4x4 4.8-104k
ST HM 5w30 & Fram
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670438
02/19/18 02:05 AM
02/19/18 02:05 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Me personally would change all 4 like light bulbs when one fails the others are usually not far behind. if for nothing else to make it a one stop job not going back every time another one goes out, that gets old fast.
Yes the tire store should be able to activate the new ones on this but ask first.
Re: TPMS sensor bad [Re: Trav] #4670465
02/19/18 05:20 AM
02/19/18 05:20 AM
Grand Rapids, Michigan
Toto Offline
Toto  Offline
Try:
https://tpms247.com
I have been very happy with my purchase and the customer service also, I believe they are in Loveland, Ohio.
TOTO.
AMSOIL-OE 0W 20-XL 10W 30-AGL 80W 90
NAPA GOLD
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670538
02/19/18 07:54 AM
02/19/18 07:54 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
No TPMS sensor: GOOD
Re: TPMS sensor bad [Re: Ducked] #4670627
02/19/18 09:11 AM
02/19/18 09:11 AM
Michigan
khittner Offline
khittner  Offline
Michigan
RockAuto has them for your truck, various usual, reputable brands, from $25-$35: RockAuto TPMS Sensors for '09 Chevy Silverado
I'd probably default to Densos, myself.
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670647
02/19/18 09:26 AM
02/19/18 09:26 AM
WI
HoosierJeeper Offline
WI
I'd let the shop supply them. With as finicky as the system is, any issues you bring it back till it's right.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670786
02/19/18 11:33 AM
02/19/18 11:33 AM
Minnesota
bruckus Offline
bruckus  Offline
Minnesota
I've read that the batteries in them last about 6-7 years. On my 2009 honda i started getting the light occasionally especially when cold. I waited until I needed tires and then had discount tire replace them all. Just wanted to save the cost of dismount and mount/balance. They were competitive priced and it made sense to do it when i put on the new tires.
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670857
02/19/18 12:31 PM
02/19/18 12:31 PM
Washington
Dylan1303 Offline
Dylan1303  Offline
Washington
Walmart tle has them for 30$ a peice and there e-z- sensor brand
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: TPMS sensor bad [Re: MuzzleFlash40] #4670930
02/19/18 01:50 PM
02/19/18 01:50 PM
Canada
i_hate_autofraud Offline
Canada
Thanks!
I thought I'd replace all 4, but just replaced 1, 3 yrs ago and the rest are still OK, go figure - and on a '09 Impala
no less! I got a TPMS scanner that lets me check pressure, temperature and battery level before I switch winter to summer tires!
The GM dealer pricing on sensors is competitive so I buy there, the issue is other sellers can wind up buying older
stock from an overly long 'gray' supply/distribution chain and selling to you. GM dealers move a lot of these so you'll get a fresh one!
Re: TPMS sensor bad [Re: Dylan1303] #4674692
02/22/18 05:49 PM
02/22/18 05:49 PM
Florida
artificialist Offline
Florida
Does that include programming?
2010 Lancer Ralliart Sportback
Re: TPMS sensor bad [Re: MuzzleFlash40] #4674918
02/22/18 10:30 PM
02/22/18 10:30 PM
ON, Canada
yugrus Offline
yugrus  Offline
ON, Canada
Make sure you don't end up with metal stem sensor!
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: TPMS sensor bad [Re: Ducked] #4674958
02/22/18 11:44 PM
02/22/18 11:44 PM
Utah
CKN Offline
CKN  Offline
Utah
So you pick something up in your tire on the Interstate-and it starts a slow leak-the (pressure drops) TPMS comes on and tells you there is a problem-you inspect the tire and either head to the repair place or change to the spare. The tire is saved and not "run flat" requiring a new tire-depending on the vehicle (AWD) could even mean 4 tires.
How is the above NOT a good scenario for TPMS?
BTW-the above as happened to me and saved the tire from beyond repair.
Re: TPMS sensor bad [Re: MuzzleFlash40] #4676263
02/24/18 09:18 AM
02/24/18 09:18 AM
NH
supton Offline
supton  Offline
NH
How low can it get before you can tell the difference in ride feel and handling? It's not like a tire run at -10psi will be trashed inside of 1,000 miles--and one should probably be checking more often than that. Don't need a fancy sensor for that.
Of course, just because the light comes on doesn't mean one actually does anything about it. Wife noticed her TPMS light on--pulled out of the driveway--made it ten or fifteen feet before she realized it was dead flat. [One of my kids walked right past it, kids are oblivious!] Same car likes to trigger TPMS system faults while we are driving, so we ignore the light when it comes on.
I've pointed out to coworkers that they seem to have a low tire. "Oh yeah, I noticed the light, I figured I'd take it to a shop at lunchtime and see what is up." Most people are just going to motor on when the light flips on. Car is still running and moving--how bad can it be?
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 199k, his
Re: TPMS sensor bad [Re: MuzzleFlash40] #4676289
02/24/18 09:44 AM
02/24/18 09:44 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
People have been dealing with pneumatic tires for a century quite well without such nannyware.
Thick oil is better grin2
