Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
33 registered members (BLND1, A_User55555, c502cid, anndel, bobcat67, 4 invisible), 967 guests, and 40 spiders.
Topics295,047
Posts4,926,736
Members66,672
Most Online2,553
Oct 27th, 2018
Discount Tire rim maintenance #4670415
02/18/18 11:53 PM
02/18/18 11:53 PM
Everett, Washington
oilboy123 Offline OP
Everett, Washington
Seems Discout tire is into grinding down the rim mount flange. Where it bolts to the rotor. This is supposed to remove corrosion on rims. I told them one time in the past not to do it, but they still did.
They use a fairly course 3M Roloc disc. I think they are trying to mitigate vibration from corrosion. I feel like they are going to cause run out over time from doing this. I left a tire/steel rim for a flat repair yesterday.
Then realized I forgot to tell them not to do it, and called and told them don't bother to grind it down because the rims are only about a 1 year old, and not corroded. He assured me they would not.
Picked up the rim put in in the back of my truck, then I thought I would check if they had ground it, and found they did. I'm about ready to not buy tires anymore from them. One location the guy who worked there told me they started doing the procedure, then stopped doing it, then started again. I guess for someone that has a lot of corrosion it would probably help. But are they doing the rotor flange as well?
I just look at it as they are mindlessly doing it whether it needs it or not. The rim they did yesterday was a painted steel rim. With maybe a spec of light rust. By the time they did their grinding I had about 6 sq inches of bare metal. So I just painted the bare metal when I go home. I bought this car new Dec 2017
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
Re: Discount Tire rim maintenance [Re: oilboy123] #4670421
02/19/18 12:12 AM
02/19/18 12:12 AM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
I think they're trying to prevent the rim from welding itself to the rotor or drum. Odd they would do it on a carry in flat repair steel rim.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Discount Tire rim maintenance [Re: oilboy123] #4670451
02/19/18 03:31 AM
02/19/18 03:31 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I don't think their disks are that course. You'll be fine.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Discount Tire rim maintenance [Re: oilboy123] #4670581
02/19/18 08:21 AM
02/19/18 08:21 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I don’t think they are grinding your rims, just cleaning them. Grinding implies a stream of flying sparks and considerable loss of steel. It’s probably company policy to do it, regardless of the need. A classic case of employees are not paid to think. I avoid such problems by avoiding chain stores and I have all my tire work done at a locally owned independent shop.
Re: Discount Tire rim maintenance [Re: oilboy123] #4670582
02/19/18 08:21 AM
02/19/18 08:21 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
In the future I plan to buy my tires from Discount Tire Direct but have someone else install them. Discount tire is fine if you are a normal person but if enjoy your car and like to keep it nice they are not for you.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Discount Tire rim maintenance [Re: oilboy123] #4670711
02/19/18 10:15 AM
02/19/18 10:15 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
DT did not do any grinding on my Suburban rim last time I was there installing new tires from DTD.
  • 2017 Toyota Sienna
Re: Discount Tire rim maintenance [Re: oilboy123] #4670832
02/19/18 12:07 PM
02/19/18 12:07 PM
IL
GimmeTorq Offline
GimmeTorq  Offline
IL
I use Permatex anti sieze lube on the contact areas between the wheel and the disk/drum and they leave it alone.
2017 Mazda CX-5 Touring AWD 2.5L
2014 Honda CTX700N
2012 Honda CR-V LX 2.4L
2010 Honda Fit 1.5L
2003 Honda Odyssey 3.5L - Traded-in
2002 Nissan Maxima 3.5L - Traded-in
Re: Discount Tire rim maintenance [Re: oilboy123] #4671414
02/19/18 09:19 PM
02/19/18 09:19 PM
Everett, Washington
Everett, Washington
OK I over exaggerated. They do remove some material, maybe it is only a thousandth or so of metal. But if you have different tires changed, then maybe a fair amount of flat repairs etc. Then it starts to add up.
I just don't like my rims being molested.....with metal removal. Also don't like the idea they sanded down the paint off about 6 sq inches of my rim. Because then how does it make sense to 3M disc the paint off in the name of a maybe a spec of rust. They then 3M disc all that paint so there is now a ton of bare metal exposed to the elements....and rust.
I'm anal about this, but I tell myself I'm getting better over the years...... smirk
― Mark Twain
Re: Discount Tire rim maintenance [Re: oilboy123] #4671444
02/19/18 10:29 PM
02/19/18 10:29 PM
Athens, GA
ctechbob Online content
ctechbob  Online Content
Athens, GA
The DT I use simply hits the mounting surfaces with a wire brush attached to the impact gun to clean off any rust or corrosion. I'd say a grand total of 5 seconds worth of spinning brush, I highly doubt it removes anything other than the corrosion, let alone metal from either surface.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 311k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: Discount Tire rim maintenance [Re: ctechbob] #4671475
02/19/18 11:53 PM
02/19/18 11:53 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Don't bet on it. I use brass wool and a product called BullFrog RustHunter which you can get online.
https://www.theruststore.com/RustHunter-Firearm-Cleaner-P31C22.aspx
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Discount Tire rim maintenance [Re: JohnnyJohnson] #4671524
02/20/18 03:09 AM
02/20/18 03:09 AM
Athens, GA
Athens, GA
I was more speaking to the people that thought they were removing large quantities from their wheels.
Re: Discount Tire rim maintenance [Re: ctechbob] #4671529
02/20/18 03:42 AM
02/20/18 03:42 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
This.
