Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
21 registered members (Donald1953, Exhaustgases, BigShug681, billt460, ctechbob, CleverUserName, 1 invisible), 811 guests, and 37 spiders.
Topics294,961
Posts4,924,867
Members66,654
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
[Cut Open] Microgreen MG-101-7 1783mi #4670312
02/18/18 09:21 PM
02/18/18 09:21 PM
Atlanta
DuckRyder Offline OP
Atlanta
So the Acura came to visit today and I noted it was lower on oil than is typical for it to burn at this point.
Got it up on ramps and took a look, good bit of oil on engine/filter/pan. Oil hanging off filter and all around base.
Cleaned it up and let it run a bit, nothing immediately apparent but filter base near gasket shiny. Elected to change the filter.
Upon removal noted that O ring feels uneven though no obvious damage.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670320
02/18/18 09:27 PM
02/18/18 09:27 PM
CA
CharlieBauer Offline
CA
Looks very low quality and much older than 1783 miles.
Are the fibers on the "teflon" disk attached to the disk or shed from the regular filter material?
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670325
02/18/18 09:35 PM
02/18/18 09:35 PM
PimTac Offline
PimTac  Offline
The center is way off and the whole top and gasket look cattywumpus. Very poor build quality it seems judging from the pics.
Cannot see signatures any longer so it doesn’t matter.
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670335
02/18/18 09:43 PM
02/18/18 09:43 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
probably a serviceable filter.....
but I don't see any possibility for returns on investment.
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: PimTac] #4670337
02/18/18 09:46 PM
02/18/18 09:46 PM
CA
CA
It supports the claims of Norbert M Assion (one of the founders of the original filter), that microgreen have cheapened the filter and it no longer performs as originally claimed.
There is a review on Amazon from Dec 2017 with the same complaint of a leaking filter.
You can see Dr Assion's claims and the defective filter review here:
https://www.amazon.com/microGreen-MG-421-8-Oil-Filter/dp/B007USGLCQ#customerReviews
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: CharlieBauer] #4670363
02/18/18 10:16 PM
02/18/18 10:16 PM
PimTac Offline
PimTac  Offline
Looking at pic #3, I would suspect that the gasket was not sealing all the way on the mount due to the center thread being so off center. I have no experience with Microgreen filters but that one clearly failed quality control and was missed. If I had found that kind of shoddiness at the store when inspecting I wouldn’t buy it in the first place. I know stuff happens sometimes but that whole top is very poorly manufactured and assembled.
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670458
02/19/18 04:26 AM
02/19/18 04:26 AM
Atlanta
Atlanta
I forgot to say, The filter media assembly seems both shorter and smaller in diameter that the TG element I used for comparison. I will try to actually measure them today. A TG 7317 went back on it.
I also don’t know if this is current construction, UD said that the one he received recently were white with green writing (IIRC)
Aside from the filter element(s) and O ring the filter seemed to be well assembled. Nice Parker ADBV, heavy can, good spring, nice uniform and amply sized louvres.
I don’t care for the wide pleat or the media itself. I haven’t been able to get the 5 micron disk out yet.
The gasket is assembled into a stamped channel which is spot welded and presumably sealed to the tapping plate. This stamped channel seems poorly formed to me and I believe it was causing the gasket to be under uneven tension. Also there appear to be witness marks on the inner run of the stamped channel indicating contact with the sealing surface on the engine, which can’t be good.
ETA Charlie, the fibers appear to be part of the teflon disk.
Robert
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670467
02/19/18 05:28 AM
02/19/18 05:28 AM
Atlanta
Atlanta
Robert
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670539
02/19/18 07:56 AM
02/19/18 07:56 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Is that shiny area around 11:00 where it was rubbing on the mount?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4670618
02/19/18 09:01 AM
02/19/18 09:01 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Baseplate thread off perpendicular to base so filter gasket contacts more on one side?
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: goodtimes] #4670662
02/19/18 09:39 AM
02/19/18 09:39 AM
Atlanta
Atlanta
It has witness marks to varying degrees at each point there is a clamping swell in the channel.
I will try to check more closely but I think I would have noticed that during installation or removal
Robert
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4671052
02/19/18 03:56 PM
02/19/18 03:56 PM
Atlanta
Atlanta
Best I can tell the threads in the tapping plate are straight.
The media in the TG is 62mm tall and 61mm across the actual media at the widest point. The MG the entire media stack is 57mm, the primary media is 50mm and the widest point is 59mm at the widest point.
Robert
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4671306
02/19/18 07:22 PM
02/19/18 07:22 PM
PimTac Offline
PimTac  Offline
In that last pic the center hole doesn’t even look round. Is it the picture angle?
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: PimTac] #4671564
02/20/18 05:51 AM
02/20/18 05:51 AM
Atlanta
Atlanta
It must be the lighting and angle, though I don’t really see that in the picture. I used a socket to gauge it and the hole is as round as a socket (a good socket) smirk
I have another one of these, but do not think I will be using it. In many years of changing oil, including when I worked in a dealer I have never had a filter leak. I’m unimpressed with the media and the leak, though there are things I like about the construction, they don’t outweigh the leak and media. I also find the marketing a bit snake oilish...
I thought UD was going to cut open a virgin one of newer manufacture, but have not seen it.
Anyway...
Robert
  • 1972 Ford F100
Re: [Cut Open] Microgreen MG-101-7 1783mi [Re: DuckRyder] #4671702
02/20/18 09:18 AM
02/20/18 09:18 AM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
I cut it open and took a quick vid of it but didn't take the time to photo the individual pieces - it looks the same internally.
will post up later today.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Page 1 of 3 1 2 3
