Saturn Vue with the Honda 3.5L V6. Doing a valve adjustment with requires removal of the plenum for access to the rear bank. The plenum has this red upper cover with a metal gasket.
and under the plenum there is this spacer with metal gaskets on both sides.
Can these metal gaskets be reused. 190,000 mile truck. $50 for gasket set I'd rather use for something else if they don't need to be replaced. My thinking is unlike rubber gaskets that get a set and harden with age, that shouldn't be an issue here.
