64806 Members
68 Forums
282100 Topics
#4669635 - 02/18/18 11:23 AM
335i noise: turbo-ish but not
Loc: Campbellsville, KY
Trying to locate a noise on an '07 BMW 335i. Twin turbo/DI N54 3.0L, 123K. I'd almost think it's some of the turbo piping come loose, but it doesn't fluctuate quite like I think the turbos should. Not directly related to engine, vehicle, or cooling fan speed, either - sounds like it's coming from toward the back of the engine. Car has decent power but seems to get gradually weaker above 2,500 RPM (I'd think the TT six should really be hauling tail about that time) and the limp mode light (symbol of an engine sliced in half) comes on when it gets up close to 4,000. No CEL. Ideas? https://youtu.be/Nf7Kugf9CxQhttps://youtu.be/uwu1ZYcwTnM
Edited by Alex_V (02/18/18 11:25 AM)
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 110K '85 GMC C3500, 454, 130K '82 Mercedes 300CD, OM617 turbo, 165K '67 Suburban, 350, 331K
#4669639 - 02/18/18 11:24 AM
Re: 335i noise: turbo-ish but not
[Re: Alex_V]
Loc: Lyndhurst NJ
Boost leak, wastegates failling or out of adjustment, vacuum lines going to vac canisters could be broken.
2002 VW Golf TDI-Mobil 1 5/40 TDT 2005 BMW M3 BMW Twin Power 10/60 1997 John Deere Gator 4x2 2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
#4669795 - 02/18/18 01:31 PM
[Re: Alex_V]
Loc: KY
Check for boost/vacuum leaks first, but I suspect it's a wastegate issue...
Mine: 2014 M235i 1999 Wrangler Sahara 1995 318ti Club Sport
Wife's: 2016 i3 REX 2009 Cooper Clubman
Son's 2009 328i
Buy what makes you smile...
#4669848 - 02/18/18 02:43 PM
[Re: Alex_V]
Loc: Florida
VW uses something called an "N75 Valve" so that the computer can open and close the wastegate or VNT nozzle with turbo boost pressure. I am sure you BMW uses something identical, but is named differently.
When the engine is off boost, spray carb cleaner around the intake manifold. If the intake gasket has failed, some of the carb cleaner will get sucked in and change the way the engine runs. It is a common problem on the Dodge SRT-4.
2010 Lancer Ralliart Sportback
#4669856 - 02/18/18 02:48 PM
[Re: Alex_V]
Loc: Lyndhurst NJ
There was a huge recall on these early ones for wastegate issues, Id check to make sure everything has been updated.
