I've tested many off the shelf household cleaners and degreasers, Purple Power, Awesome, Mr. Clean, others. I like to use it for cleaning my bicycle but also to clean my hands when working on things. The best I ever found was liquid Commercial [censored] n Span sold by a janitorial supply house, which no longer is in business. Since, everything I've used is garbage compared to that. I used to own a janitorial business so I had the opportunity to use a lot of cleaners and test them out. What I got use to and came to expect, when you spray the cleaner on, the dirt and grease should dissolve and run so you can wipe it off without using a scrub pad or brush. It seems today, nothing I use is this way.I
What have you tried, failed, succeeded?
