Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
51 registered members (alarmguy, 2015_PSD, AndyB, bbhero, Bambam, 5 invisible), 922 guests, and 31 spiders.
Topics290,968
Posts4,853,533
Members66,063
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
Guesses? Severe piston slap = high wear metals? #4669257
02/18/18 03:57 AM
02/18/18 03:57 AM
PA
Gasbuggy Offline OP
Gasbuggy  Offline OP
PA
My 2002 Yukon XL has thee worst cold piston slap of any 5.3 I've ever heard. And I've owned and drove many. Random citizens with likely no car knowledge whatsoever turn and stare when I fire it up and drive off. I'm sure the neighbors are confused because my driveway looks like James Bond lives here but half the time I'm rolling out in something that sounds like it's about to blow up. It has the charm of a rod knock but it is merely piston slap. Piston slap so bad it throws the knock sensors off for the first 30 seconds if it's below freezing. I bought it in the summer so I didn't get fully acquainted with the severity until this winter.
I changed the clean Jiffy Lube oil when I bought it and put in MaxLife 10w30. It hardly has burned a drop of oil in 5000 miles, burns rubber though. I'll probably change it at 7k. No complaints for a $1500 beater that was maintained and had newer tires, brakes, and cooling system.
Anyone want to throw a guess on if wear metals will be higher with this condition? I can't see how it wouldn't. I mean, something is smashing into something every time I cold start it. You can still lightly hear it when it's fully warmed up.
CTS-V+Recaros 5w30 Magnatec
Volvo P1800 5w30 Euro L
Land Rover Series 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 MaxLife
95 Accord - 386k. Mobil 2 RIP
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669260
02/18/18 04:53 AM
02/18/18 04:53 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
As an engineer, piston slap tells me that things aren't operating correctly.
Things that should be happening in a slappy engine are:
* Higher, irregular loading of points on the piston skirts (more wear)
* higher scyclic loading including impact on the skirts (high cycle fatigue)
* cocking of the piston rings (reduced seal and wear).
But the things seem to typically live lives that see out the chassis and running gear, so like the other compromises that OEMs make "not ideal" is not the same as "about to blow up.
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669263
02/18/18 05:12 AM
02/18/18 05:12 AM
Texas
4WD Offline
4WD  Offline
Texas
I thought guys like short skirts. The worst I had was a 2004 Yukon … about 10 seconds after start up and done= after we put 130k trouble free on the unit … saw it around town for a few years after. BiL put 400k on his and the motor never failed … it did it …Some have called the polymer coating a band aid … but they are not wearing out prematurely …
My 2010 has a tiny amount at start up … the 2017 is just a very quiet motor, period.
You could experiment with various oils and see what happens …
http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap/
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669275
02/18/18 05:51 AM
02/18/18 05:51 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
10W-40 MaxLife would probably be better. It'd give you more film thickness on the cylinder wall. More film thickness might offer a better cushion between the piston and cylinder wall.
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669316
02/18/18 08:09 AM
02/18/18 08:09 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
I wouldn't do 7K OCIs using semi-synthetic on a 16 year-old vehicle. Many semi-synthetics only have around 25-30% synthetic oil in the jug.
She's the only sister-in-law I have. But she's not my favorite.
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669350
02/18/18 08:57 AM
02/18/18 08:57 AM
Southeast Texas
gfh77665 Offline
gfh77665  Offline
Southeast Texas
SAE 30wt. in winter, SAE 40wt. rest of the year.
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669370
02/18/18 09:12 AM
02/18/18 09:12 AM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
I don't think I have ever heard or read of piston slap killing an engine. I know my previous Accord slapped from the time I got it at 97K miles to when I traded around 140K. I know its not the same miles as yours but again, no issues with mine.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Guesses? Severe piston slap = high wear metals? [Re: gregk24] #4669378
02/18/18 09:18 AM
02/18/18 09:18 AM
Texas
4WD Offline
4WD  Offline
Texas
Internet is full of things
https://m.youtube.com/watch?v=fwe7qxu10sU
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669415
02/18/18 09:40 AM
02/18/18 09:40 AM
Wishin' I was in Wi
mjk Offline
mjk  Offline
Wishin' I was in Wi
Since it really owes you nothing, and the 5.3 will outlast the body, throw in a quart of Lucas and see if that quiets it.
coffee coffee
Re: Guesses? Severe piston slap = high wear metals? [Re: mjk] #4669420
02/18/18 09:44 AM
02/18/18 09:44 AM
Texas
4WD Offline
4WD  Offline
Texas
coffee coffee
No ~ Slick 50 dude
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669428
02/18/18 09:48 AM
02/18/18 09:48 AM
Naperville, IL
wwillson Offline
Administrator
wwillson  Offline
Administrator
Naperville, IL
My 5.3L 2002 Suburban had loud piston slap for the first couple minutes after startup. I did several oil samples, which are posted here, and the wear metals were always low. The piston slap didn't seem to cause accelerated wear, just the annoying knocking.
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669437
02/18/18 09:53 AM
02/18/18 09:53 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
We have had many GM V8 "slappers" over the years. Never any issues other than some annoyance.
Our worst slapper was sold with over 500k miles on it, doesn't seem to hurt longevity at all...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Guesses? Severe piston slap = high wear metals? [Re: wwillson] #4669450
02/18/18 10:02 AM
02/18/18 10:02 AM
Texas
4WD Offline
4WD  Offline
Texas
Didn’t you run like a 15w40 Delvac ? I’m finding on that or Delvac 1 5w40 there is really little difference at startup
Re: Guesses? Severe piston slap = high wear metals? [Re: Gasbuggy] #4669532
02/18/18 11:13 AM
02/18/18 11:13 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
20% oil capacity with Lucas Oil "stabilizer"
Yes, it's thick snake oil - but it will help quite a bit.
Re: Guesses? Severe piston slap = high wear metals? [Re: SteveSRT8] #4669535
02/18/18 11:16 AM
02/18/18 11:16 AM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Yep, we sold our 2010 5.3 v-8 plow truck Chevy 2500 reg cab 4x4 with 279,xxx on it and it had this piston slap and nothing but Safety Kleen 5w30 DEXOS oil
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Page 1 of 4 1 2 3 4
