Exhaust help
Kansas (316)
I hit a rock and damaged my resonator.So, I had it replaced with a bigger pipe 2". Its a bit raspy, could I have them make a 12 " H OR X pipe to help quiet the flow. Will send pics later of under carriage damage. It has a Borla rear axle exhaust attached. Thanks
Replace the pipe you made with a real resonator, an empty can in the form of a larger diameter pipe or more plumbing is not the answer. Either that or live with it.
What kind of Civic needs an H or X pipe?
Just put a universal resonator on. An exhaust shop should charge around $50 installed, or more if they actually use stainless steel like they should.
Originally Posted By: Marco620
Its a bit raspy, could I have them make a 12 "H OR X pipe" to help quiet the flow.
H or X ... Huh? What vehicle?
If it were me......... I'd install a Helmholtz exhaust resonator on it
