Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
37 registered members (53' Stude, Bailes1992, AutoCoil, CB900F2, 92saturnsl2, bmod305, 5 invisible), 870 guests, and 44 spiders.
Topics295,047
Posts4,926,786
Members66,672
Most Online2,553
Oct 27th, 2018
GM oil drain plug #4669216
02/17/18 11:17 PM
02/17/18 11:17 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
https://www.oreillyauto.com/shop/filters...500?q=oil+drain
https://www.oreillyauto.com/shop/filters...=oil+drain+plug
On most GM vehicles, they use the M12-1.75 thread drain plug. I never change the gasket on that particular plug when doing oil changes, but it got me thinking, is it recommended by GM or even necessary to change the gasket every oil change? I've never had leaks. I do change copper crush washers and aluminum flat washers every time when servicing other vehicles.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: GM oil drain plug [Re: mobilaltima] #4669273
02/18/18 04:44 AM
02/18/18 04:44 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I used to change the gasket every time and they still leaked; that's with the no-name China gasket from NAPA. I noticed they offered an alternate part number in the FEL-PRO brand. No more leaks and I don't have to change it every time.
Re: GM oil drain plug [Re: das_peikko] #4669296
02/18/18 06:10 AM
02/18/18 06:10 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Ya know, I had the same oil dripping issue when I changed to a plastic/nylon gasket on the oil pan drain plug at every OCI. So, I stopped doing it. Hmmm, go figure!
When I leave the OE metal drain plug gasket in place on the drain plug, it'll last for 15 years without a single drip. Hmmm, go figure! smirk
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: GM oil drain plug [Re: mobilaltima] #4669302
02/18/18 06:34 AM
02/18/18 06:34 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
There are quite a few uses in the original but every 3-4 times I would change it. OE plugs and sealing rings are best for these so get one from the dealer.
Re: GM oil drain plug [Re: mobilaltima] #4669312
02/18/18 06:57 AM
02/18/18 06:57 AM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
If this is the same plug as what's on my truck, I've always had issues with these.
I have drippage after a new gasket and torqued to spec. Dorman makes replacement gaskets, but I am not sure about them. Fel Pro and AC Delco have them too.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: GM oil drain plug [Re: Char Baby] #4669314
02/18/18 07:03 AM
02/18/18 07:03 AM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
That has been my experience as well
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: GM oil drain plug [Re: Papa Bear] #4669321
02/18/18 07:20 AM
02/18/18 07:20 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Same here. I don't ever recall changing the factory drain plug gasket on anything I have ever owned? Numerous dirt bikes, atvs, boats, vehicles, you name it. Always found it odd when I read about these new gaskets and the recommendation to change them out.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: GM oil drain plug [Re: irv] #4669330
02/18/18 07:28 AM
02/18/18 07:28 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
We've read this thread before.
1) Isn't the GM "metal gasket" actually a metal based washer with neoprene added to it? Those ARE good gaskets but they do wear out.
2) Used tons of copper gaskets. No problem except when you use (for example) a 15mm where a 14mm is called for.
Also, I think the copper prompts some people to overtighten.
3) The aluminum ones are great as you can feel 'em "crush" (deform) as you tighten.
4) WHAT'S WITH those cheap pale blue, hard plastic ones which often come with replacement drain plugs? Completely wrong.
Same goes for the translucent white nylon ones.
Re: GM oil drain plug [Re: mobilaltima] #4669334
02/18/18 07:39 AM
02/18/18 07:39 AM
Indiana
Indiana
Re: GM oil drain plug [Re: Kira] #4669342
02/18/18 07:50 AM
02/18/18 07:50 AM
Trav Offline
Trav  Offline
Changing them is insurance, they usually hold up for multiple uses but when one does leak its a bit of a PITA. The hacks either wrench them tighter or leave it. You can use a shop vac but that's another story.
I hate the nylon ones.
Re: GM oil drain plug [Re: Trav] #4669421
02/18/18 08:45 AM
02/18/18 08:45 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
+1.
The one on my 98 chevy truck started to weep after like 12+ years...
Feel-pro never worked the same. OE is best.
Re: GM oil drain plug [Re: Char Baby] #4669468
02/18/18 09:18 AM
02/18/18 09:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Same here.
My OE gasket isn't metal, but I never change the gasket EVER unless it needs it.
Re: GM oil drain plug [Re: Linctex] #4670446
02/19/18 03:17 AM
02/19/18 03:17 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Same here.
Exactly! I've gotten rid of the cars before I've changed the gasket. And I've kept vehicles for as long as 18 yrs. Even the Firebird FORMULA in my signature still has the OE metal gasket after 38 yrs.
"Retired"
'15 Honda Civic LX
