Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
45 registered members (DaHen, 2013ecof150, d00df00d, 69Torino, Cujet, alarmguy, 6 invisible), 997 guests, and 42 spiders.
Topics290,622
Posts4,847,619
Members66,011
Most Online3,590
Jan 24th, 2017
Generator is gonna sit for a year: which oil? #4669166
02/17/18 11:10 PM
02/17/18 11:10 PM
SD
HighwayRanger Offline OP
SD
So I use my pair of Honda eu2000i generators for a few weeks each year powering my RV. I usually put about 100 hours on them during that time. I change the oil before and after I use them, and usually once in the middle. Then they go into storage until the next year. Given that pattern, does it matter whether or not the oil is synthetic? Does dino oil deteriorate in storage more than synthetic?
'15 GMC Sierra 3500HD Denali Dually
16 DRV Mobile Suite Fifth Wheel
(2) Honda eu2000i Generators
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669176
02/17/18 11:29 PM
02/17/18 11:29 PM
ME
eljefino Offline
eljefino  Offline
ME
You'll be fine under any scenario. Pay attention to the fuel system if anything.
Even used oil under any reasonable use or abuse has enough TBN to prevent off-season corrosion.
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669236
02/18/18 01:11 AM
02/18/18 01:11 AM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
oil is not important in this case (so long as there's some oil in the crankcase so that you don't start your genny dry).
Most importantly, drain your carb bowl dry and if possible, drain the fuel tank also.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669285
02/18/18 06:37 AM
02/18/18 06:37 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The oil will not deteriorate while in storage for a year. I run my generator once a year for 15 minutes to make sure all is well. I last changed it three years ago.
The "thinking" man's friend.
Re: Generator is gonna sit for a year: which oil? [Re: Quest] #4669328
02/18/18 08:27 AM
02/18/18 08:27 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Q.
This^
I would also recommend to run some SeaFoam through the gas first and let it run for 10 minutes or so. Drain the gas and put it in your vehicle.
I would also recommend either fogging the engine around the 10 minute mark or at least pull the spark plug and give it a couple squirts in there, then pull it over a few times to spread it around.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum for all 3.
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669404
02/18/18 09:35 AM
02/18/18 09:35 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
You put 100 hours per year and change oil midway? Is that consistent with the owner's manual?
After the first cold start, generators have a pretty consistent operation for a decent long time.
I'd look into the delo 15w-30 and the various 10w-30 HDEOs myself. Amsoil ACD is another good option IMO.
But I think once a year with that use is fine... I agree that fuel system care is much more important.
Re: Generator is gonna sit for a year: which oil? [Re: Lubener] #4669466
02/18/18 10:17 AM
02/18/18 10:17 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
^^ This ^^
I run cheap 15W-40 in one of mine, and Mobil 1 10W-40 in my EU2000 (just because it was one clearance, and for no other reason)
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669471
02/18/18 10:20 AM
02/18/18 10:20 AM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
We have a Honda EU3000iS at work.
It sat in storage for 4 years with Mobil 1 10W-30.
Has had no issues .
Currently running Rotella T6 5W-40.
I'd worry more about the fuel, we treat ours with mechanic in a bottle.
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline HM 10W-30, PH3593A
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669560
02/18/18 11:29 AM
02/18/18 11:29 AM
SD
SD
I overdo the maintenance on my Hondas, because I enjoy babying them, and appreciate their quality. I have the pre-storage fuel system maintenance routine wired, too. I always overthink the oil topic (which qualifies me to participate in BITOG) and like to change the oil as a hobby since it takes less than half a quart. I am currently running M1 10w30, but Im considering trying some 30 weight HD dino oil to see if they run differently (and were in warm weather.)
I appreciate the input.
Roy
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4669608
02/18/18 12:07 PM
02/18/18 12:07 PM
SD
SD
Upon further review.........Im interested in trying Amsoil ACD 15w40. I could change the oil every day with a 1-gallon jug! cool
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4670380
02/18/18 11:36 PM
02/18/18 11:36 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
ACD is a SAE30/10w30 heavy duty engine oil (typical diesel use) and does work well in small engines.
Amsoil also makes a line of specialty small engine oil in 10w30(ASE) and 10w40(ASF) They are both available in quarts, gallons or 5 gallon pails.
Honda recommends an oil change every 100 hours on an Eu2000i, and a good quality synthetic like Amsoil will handle that easily.
The Eu2000i calls for 10w30 according to the online manual from Honda, so the Amsoil 10w30 ASE would fit your needs well.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4670397
02/19/18 12:15 AM
02/19/18 12:15 AM
KS
red7404 Offline
red7404  Offline
KS
in the old days. the guys with a race car. would put some hoter heat range plugs in. then put the RPM up a few 100 and pour oil in and flood it till it dies. but cant remember what they do when they fire it up in the spring. of course now days i would use Marvel Mystery Oil. i have by accident run 3-4 times of MMO than i should. and no bad side effects.
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4670718
02/19/18 11:18 AM
02/19/18 11:18 AM
SD
SD
One more question: I run Rotella T6 5w40 in my Duramax. Any objection to me using it in the generators too?
Roy
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4670908
02/19/18 02:29 PM
02/19/18 02:29 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Use it with confidence...its HDEO oil...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Generator is gonna sit for a year: which oil? [Re: HighwayRanger] #4670954
02/19/18 03:12 PM
02/19/18 03:12 PM
Midwest
Rab6715 Offline
Rab6715  Offline
Midwest
I have one eu2000i that I put 20-30 hours on in the Fall. I generally change to 10w30 synthetic in the spring [May] and change to 5-30w synthetic in the late fall, like November/early December. No real changes in between because not enough hours accumulate. I'm using Quaker State UD full synthetic 5 or 10w30.
