One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
39 registered (bbhero, BigJakeChevy, Atesz792, AVB, 2strokeNorthstar, Aero540T, 3 invisible), 980 Guests and 42 Spiders online.
65265 Members
67 Forums
285570 Topics
Page 1 of 3 1 2 3 >
#4669097 - 02/17/18 08:26 PM What F150 engine?
wallyuwl Offline
Loc: Wisconsin
Buying a new F-150 in the next week or two. I was sold on the 5.0 v8 because it is tried and true, and gets good mileage in MY18 trucks due to dual injection and 10 speed transmission. But after seeing pricing and options for towing packages with diffetent engines, I am thinking of looking into the 3.5L Ecoboost.
Starting MY18 the Ecoboost is dual injected so no worry about dirty valves. But I worry about the turbo reliability. I dont understand them well enough to be confident they are good or bad in terms of reliability.
Does the turbo portion need to be rebuilt after a while? Expensive to repair?
Any info on this engine or turbos in general appreciated. I plan to keep this truck a long time.
#4669117 - 02/17/18 08:54 PM Re: What F150 engine? [Re: wallyuwl]
BikeWhisperer Offline
Loc: Cascadia
The 5.0 is just a complex an engine as the 3.5 Eco-Boost, just minus the turbo chargers (dual overhead cams, 4 valve, variable valve timing, and dual injection). When I purchased my F150, I drove nearly identical (even the color) 2013 XLT's with each engine and the 3.5 Eco-Boost was clearly the better truck engine with strong pulling from low in the rpm's versus the 5.0 needing to wind up to get to the power (which was good once you got there). The turbo chargers are water cooled so you aren't going to have the issues that 1980's turbo engines have. Turbo chargers in diesel engines run many hundred thousand miles easily and there is no reason to believe these eco-boost turbochargers will not do the same.
2013 F150 XLT SCrew Eco-Boost
0w-40 Edge, Fram XG10575, Spectre Air Filter
2016 Ford Escape SE Eco-Boost 2.0L
5w-30 Edge EP, Fram XG3614
#4669130 - 02/17/18 09:08 PM Re: What F150 engine? [Re: wallyuwl]
KJSmith Offline
Loc: TX
Started MY 17.
Besides that, there was never a need to worry anyway.
A turbo is also nothing to worry about.
I have driven turbo engines exclusively since 2002.
Put 304k on one.
The Eco I just traded last May had 147K
#4669148 - 02/17/18 09:38 PM Re: What F150 engine? [Re: wallyuwl]
clinebarger Offline
Loc: Fort Worth, Texas
My knee jerk reaction is to recommend the 5.0L Coyote!!....Why would you want a jazzed up Duratech V6 in a truck?
Drive BOTH & make a decision. No need to worry about either engines reliability!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4669150 - 02/17/18 09:39 PM Re: What F150 engine? [Re: wallyuwl]
Danno Offline
Loc: Northern Ontario, Canada
If I were putting my money down on a new Ford F150, I would go with the 5.0L.
I wouldn't want to own the twin turbos after warranty is up.
This is after running 100s of Ford trucks in a very large fleet, gasoline and diesel.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
#4669157 - 02/17/18 09:49 PM Re: What F150 engine? [Re: wallyuwl]
maxdustington Offline
Loc: Toronna
Some people hate turbo lag, others do not mind it. I think the lag is cool and I like the sound turbos make.
03 Jetta AWP/09A 200k kms
TGMO 0W20 "Legend" & Hella Magnet Filter
#4669160 - 02/17/18 09:55 PM Re: What F150 engine? [Re: wallyuwl]
Cujet Offline
Loc: Jupiter, Florida
I have both a V8 and a 3.5 Ecoboost F150, the earlier body style. I can say, without a doubt, the V8 is far more pleasant to drive and live with. It's butter smooth, instantly responsive and does everything well.
The Ecoboost has considerably more vibration under some conditions. Other times, it's so quiet, you don't notice the engine at all. Weird. The EB has lag, and at times that's annoying. The EB is faster in real world driving. Pleasantly fast.
I am in the market for another new F150. I'm not going with the EB.
I'll say it like this, I drive both trucks from FL to NY from time to time. The V8 is just a better ride and is by far, my preference. The EB, while wonderfully powerful, is grating at times. You can blame that on the sound of a big V6, but I think it's more than just the sound, it's the vaunted NVH combo. (noise vibration harshness)
Edited by Cujet (02/17/18 09:56 PM)
#4669163 - 02/17/18 10:00 PM Re: What F150 engine? [Re: wallyuwl]
CT8 Offline
Loc: Idaho
Have you tried the different engines? The ecos if driven properly get better mpgs and the low end power at cruise is enjoyable. Will there be more problems ? if there are no turbos there will be no turbos to fail and under boost if bad happens it will be worst. I bought one without much stress. The V8 if I were a betting person would be the most reliable. I have two vehicles with turbos.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4669209 - 02/17/18 11:00 PM Re: What F150 engine? [Re: wallyuwl]
Arob Offline
Loc: Iowa
My brother-in-law has had a new pickup every year, through his business. He has been driving F150's for the past 4 years, started with a 3.5 ecoboost, then went to the 5.0, never went back to the 3.5, just liked the sound and power of the V8 for the past 3 years. Since retiring, he still buys a new truck every year but switched to Chevy, really loves his 6.2 LTZ Silverado. Says it has better power and fuel economy than the 5.0 Coyote. Yep, he has money.
https://www.youtube.com/watch?v=DznZdp0RpFw&t=24s
#4669214 - 02/17/18 11:07 PM Re: What F150 engine? [Re: wallyuwl]
eyeofthetiger Offline
Loc: South Carolina
I really like the new 5.0, but I also like the Ecoboost. Tough choice. I guess if I was buying a new F-150, I would have to go with the Raptor, and that happens to have a High Output 3.5L Ecoboost.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4669217 - 02/17/18 11:19 PM Re: What F150 engine? [Re: wallyuwl]
BrocLuno Offline
Loc: Kalifornia Kollective
I have owned a number of Turbo cars, albeit Euro models. No turbo issues other than an old air cooled Volvo turbo finally dropping speed at 148,000 IIRC. The replacement liquid cooled unit went 200,000 and was still spooling up to 13 PSI when I got rid of the car. Modern OEM turbos are very reliable smile
I have driven over the road trucks and tractors with turbos since the 1970's and they almost never fail in LOTS of miles/hours smile
Edited by BrocLuno (02/17/18 11:20 PM)
#4669223 - 02/17/18 11:30 PM Re: What F150 engine? [Re: wallyuwl]
SubieRubyRoo Offline
Loc: Winchester, Indiana
I just drove a 17 Expedition with the 3.5EB. While at heart I will always be a V8 guy since I was raised on Fox-body Mustangs and moved onto my all-time favorite, a G8 GXP with the LS3... all I can say is that I am seriously impressed with the 3.5. I also drove a friend's F150 CC with the EB as well, and that thing was quite impressive. If you are going to be towing or loading the bed down with heavy stuff, it will be hard to beat the usability of all the TT torque.
Ford has definitely done a great job with the 5.0, but the way I see it, HP and torque follow the same saying as championship sports teams... offense wins games, defense wins championships. Torque is defense!
Put a good synthetic in the EB, change it at 5-6k and it will live every bit as long as the 5.0.
#4669230 - 02/17/18 11:53 PM Re: What F150 engine? [Re: wallyuwl]
wallyuwl Offline
Loc: Wisconsin
Thanks for all the comments. Sounds like most who have owned both like the 5.0. I won't do a lot of towing, but will do some in the summer (though not heavy, at most 4000 lbs).
I drove the 5.0 and liked it except for the power really coming at the higher RPMs. That said, it had a nice feel to it driving around town. It was responsive and really smooth even if I'd have liked the power to come a little sooner in the power band. I have not driven the 3.5, maybe will on Monday. I did look under the hood and it would be a lot harder to even do basic things like change spark plugs, clean the throttle body, etc. For a modern engine compartment, the 5.0 has a lot of room.
I drove a RAM with the 5.7 HEMI and didn't like the sound of it, or the characteristics of the 8 speed in it. Won't consider GM because they no longer have the Vortec engines, they are all Ecotec3 since 2014. They are direct injected (not dual injected like the Fords), and I'm not going to get the valves cleaned every 20k miles. DI is a deal breaker for me.
#4669318 - 02/18/18 07:16 AM Re: What F150 engine? [Re: wallyuwl]
A_Harman Offline
Loc: Michigan
The Ecoboost has been in production since 2011, and turbos with water-cooled bearing housings have been in production since the mid-1980's. It's a mature technology. The Ecoboost makes better low-end torque than the 5.0, and that's where it matters in a truck application.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#4669320 - 02/18/18 07:17 AM Re: What F150 engine? [Re: wallyuwl]
itguy08 Offline
Loc: Somewhere
I own 2 EB 3.5s, one in a car and 1 in the F150. Both the original version with high miles (123k and 83k) and no issues to report with either. Just tons of power thanks to the turbos and a wide power band.
If you like the sound of a V8 get the 5.0. It sounds wonderful. It's got great power, good economy and did I mention sounds great?
If you're going to tow or haul heavy loads, get the EB 3.5. We tow a 9900lb camper with ours and the power is very good towing that load. Up the mountains and down the mountains it just does really really well. Holds speed well and returns decent fuel economy when towing and not towing (we have max tow so it has the "worse"gears). On my 2011 F150 it's very easy to change the plugs, clean the throttle body, etc. Not sure how the engine compartment changed over the years but I imagine it's still about the same dimensions.
In the end I don't think you can go wrong with either engine choice.
Page 1 of 3 1 2 3 >
