Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
98 registered members (28oz, ABomb369, Armkb, asand1, 2015_PSD, 12 invisible), 1,676 guests, and 50 spiders.
Topics290,713
Posts4,848,872
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
More Elec. Cap Failures #4668798
02/17/18 03:31 PM
02/17/18 03:31 PM
Central Texas
sleddriver Offline OP
Central Texas
A day ago, the Pan. HD recorder failed to light. Opened the hood last night to find another case of cap failure. The first one I saw was on the far left edge of photo 1. Next I pulled the HD & cage and discovered the others below it:
Manuf. date is April 2004. Not all caps are showing signs of failure, however since the PS board feeds the unit + HD, I'll be recapping it to keep from having to do this again. Panasonic did a nice job here in their PS design by including a LC line filter and transient protection.
Time to warm up the iron.........
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: More Elec. Cap Failures [Re: sleddriver] #4668805
02/17/18 03:36 PM
02/17/18 03:36 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Can you explain to a dummy how to know what to look for?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: More Elec. Cap Failures [Re: Chris142] #4668813
02/17/18 03:42 PM
02/17/18 03:42 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
The bulged-top capacitors.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: More Elec. Cap Failures [Re: sleddriver] #4668817
02/17/18 03:46 PM
02/17/18 03:46 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
When the top part of capacitor is "bulging", that means it is bad, some may rupture also.
To OP, depends on the application, if you can find a higher voltage capacitor with the same capacitance, that may prevent you from re-capping in the future. Replace 10V with 16/20V or whatever is available at higher voltage?
  • 2017 Toyota Sienna
Re: More Elec. Cap Failures [Re: Chris142] #4668820
02/17/18 03:50 PM
02/17/18 03:50 PM
Central Texas
Central Texas
In photo 1, most caps appear to have evenly shiny tops. The bad ones have one quadrant that's dark grey. Reason is their top is no longer flat, thus not evenly reflecting light.
On the side shots you can see the 'bulge' easier, especially the one that's leaked meaning the top expanded enough to rupture the "curve" stamped into it. The manuf. does this to give it a place to expand. Also makes it more noticeable.
However even a smooth top cap can have a high ESR and/or the value can be too far out of spec. I'll cut a few open after getting this repaired.
For an internal view of a failed cap, see my other thread on "Parasound".
M1 10W-30 HM
Re: More Elec. Cap Failures [Re: JMJNet] #4668834
02/17/18 03:59 PM
02/17/18 03:59 PM
Central Texas
Central Texas
Yep. I did this on my post regarding the Parasound...replaced 65V caps with 80V.
Also on my fuel pump relay fix. Replaced 16V cap with 25V. (16 is way too low.....)
My line voltage here is about 125VAC. Some older equipment is designed around "110VAC". Higher V means increased thermal dissipation, which can shorten life. This was a HUGE problem in the HK Citation 7 I posted about here years ago. The heat badly damaged the ckt board, cooked several components and caused the thermal fuse in the main PS transformer to melt! It's being fed a lower VAC now and is given a hard off to shut the PS down when not in use. Otherwise the PS is on 24/7, dissipating lots of heat. That's bad design...
M1 10W-30 HM
Re: More Elec. Cap Failures [Re: sleddriver] #4668851
02/17/18 04:18 PM
02/17/18 04:18 PM
Idaho
CorvairGeek Offline
CorvairGeek  Offline
Idaho
I've changed so many I have lost count. I think they (the defective ones, https://en.wikipedia.org/wiki/Capacitor_plague ) were in the supply chain long after the supply was supposed to have been fixed. I see Wikipedia is now saying through 2007. My favorites have been TEAPO and CAPXON. They seem to always be failed in anything I open up. Never seen any repeat failures with quality replacements (assuming no design issue).
Jerry
Re: More Elec. Cap Failures [Re: sleddriver] #4668863
02/17/18 04:34 PM
02/17/18 04:34 PM
St.Cloud MN.
AndyB Offline
AndyB  Offline
St.Cloud MN.
Try to up the temp rating to 105* caps. There are a lot of cheap caps out there.
Re: More Elec. Cap Failures [Re: sleddriver] #4668919
02/17/18 05:49 PM
02/17/18 05:49 PM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
Years ago when I was in electronics I remember the SMPS circuits would get a leaky cap in the voltage regulation feedback circuit (usually a low value cap like a 1u or a .47u) and that allowed the voltage to creep up blowing other filter caps in the power supply.
When you change your caps be sure the output voltages of the power supply are correct.
2016 Dodge GC Deep Cherry
2013 SYM Wolf Classic 150
2011 Suzuki S40 650 Fox Orange Sold
2009 V-Star 250 Black Cherry
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: More Elec. Cap Failures [Re: sleddriver] #4668972
02/17/18 06:53 PM
02/17/18 06:53 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Never knew this was a recognized phenomenon. I was an IT tech back then and diagnosed many Dell Optiplex computers that had this problem.
Re: More Elec. Cap Failures [Re: sleddriver] #4668979
02/17/18 07:05 PM
02/17/18 07:05 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This is a real problem in all electronics across all but the highest-end lines.
Re: More Elec. Cap Failures [Re: sleddriver] #4668996
02/17/18 07:20 PM
02/17/18 07:20 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I was going to say... nature of the beast, no?
Will be looking forward to repair shots. Resoldering parts on boards is a great skill.
Re: More Elec. Cap Failures [Re: sleddriver] #4669022
02/17/18 08:01 PM
02/17/18 08:01 PM
Canada
i_hate_autofraud Offline
Canada
Manufacturers like Panasonic, Sony, etc, can pick electrolytic filter capacitors that have a specific life, ie, so they pop
in 3-4 yrs etc, thus you buy a new TV etc. Seen that. Cheap computer motherboards go that route a lot.
The PS board (power supply) is typically a high frequency "switch-mode" power supply that no longer uses a
heavy 60Hz line transformer. These caps see high switching frequencies and currents, so if you recap, look for
"Low ESR" caps, meaning "low effective series resistance" plus the voltage rating, capacitance value and temperature rating on them.
High switching currents in the cap generates heat that over time gases the electrolyte bulging the case at the top, you'll note
the cases have grooves on top, so they can 'burst' but not explode old-school. We're not talking a lot of heat here an extra 1/4 watt
will age a cap that should be stone cold. Electrolytic caps also have significant Inductance and Resistance that becomes a big
issue when ripple currents can be several Amps at 30 to 50 KHz!
Low ESR caps take more time to get, but will last way longer. Ebay will show some results if you search "low ESR cap", etc.
Re: More Elec. Cap Failures [Re: sleddriver] #4669024
02/17/18 08:04 PM
02/17/18 08:04 PM
Chris142 Offline
Chris142  Offline
Thanks I never knew about bulging caps
Re: More Elec. Cap Failures [Re: i_hate_autofraud] #4669058
02/17/18 08:52 PM
02/17/18 08:52 PM
Central Texas
Central Texas
The Panasonic PS used in this player isn't a switcher. Good old linear.
I've been buying parts from Mouser for decades now. Also from Digi-key. They only stock NEW parts. EB can be such a [censored] shoot. If I'm going to spend the time, I'll only use top grade, new parts, from a major supplier like Mouser or Digi-key.
M1 10W-30 HM
Page 1 of 4 1 2 3 4
