2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (alphadog, Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,422 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Dex VI in heavy truck steering? #4668083
02/16/18 06:41 PM
02/16/18 06:41 PM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
TRW calls for TES389/TES295 fluid for their THP 60 steering box. Truck is a 2006 Freightliner M2
https://www.trwaftermarket.com/globalass...1-june-2016.pdf
I am currently using Mobil Multi Vehicle ATF
https://mobiloil.com/en/automatic-transmission-fluid/multi-vehicle-atf
It meets Dex III, which is what was originally specified for this box
Mobil Dex VI does not list TES389 as a spec it meets.
https://mobiloil.com/en/automatic-transmission-fluid/dexron-vi-atf
Can Dex VI be used? Is it any way superior to the Multi Vehicle ATF, which is also a synthetic blend? Is there an issue with viton seal compatibility?
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Dex VI in heavy truck steering? [Re: George7941] #4668269
02/16/18 09:38 PM
02/16/18 09:38 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Mobil Delvac 1 ATF meets these specs. Just google TES 295.
If you want the job done right......do it yourself.
Re: Dex VI in heavy truck steering? [Re: George7941] #4668313
02/16/18 10:39 PM
02/16/18 10:39 PM
Toronto, Canada
Toronto, Canada
Yes, I am well aware of that and that is what I use in Allison transmissions. My question was specifically about Dex VI. I was looking for less expensive alternatives to the Mobil Delvac 1 ATF since the power steering system is a less severe environment than an auto tranny. Is Dex VI better than the Mobil Multi Vehicle ATF that I am currently using?
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Dex VI in heavy truck steering? [Re: George7941] #4668389
02/17/18 01:01 AM
02/17/18 01:01 AM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
You can run a Dexron/Mercon with a Allison C-4 approval (C-4 & TES-389 are basically the same spec).
2001 Chevy Camaro L92/4L80E
Re: Dex VI in heavy truck steering? [Re: George7941] #4668394
02/17/18 01:13 AM
02/17/18 01:13 AM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
You might get away with it in a TRW box (never use ATF in a Sheppard)...but I'd stick with the Delvac 1 ATF...it's not like you change it often or it's a big sump. IMO...Dex VI is too thin for a big steering box.
HDEO in Diesel Engines. No spark plugs here.
Re: Dex VI in heavy truck steering? [Re: George7941] #4668490
02/17/18 08:11 AM
02/17/18 08:11 AM
Snagglefoot Offline
Snagglefoot  Offline
According to Mobil, Mobil Muli Vehile ATF is not a replacement for Dex 6, just Dex 3 and some other manufacturer’s recommended ATF. Sort of muddles up the logic of all this.
Re: Dex VI in heavy truck steering? [Re: George7941] #4670523
02/19/18 08:42 AM
02/19/18 08:42 AM
Southeast
meep Offline
meep  Offline
Southeast
Agreed with Piper - Dex VI is a little thinner - I don't think I'd use it here.
2018 F150
2015 crv (wifey!)
