1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
47 registered members (anndel, billpace1956, carloz, Brad_C, Ammofirst, BikeWhisperer, 4 invisible), 1,094 guests, and 30 spiders.
Topics296,903
Posts4,961,300
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
Smog Pump Question - 82 Mustang 200 I6 #4667636
02/16/18 09:46 AM
02/16/18 09:46 AM
Texas, USA
WylieCoyote Offline OP
Texas, USA
Hey guys, looking for someone with experience in deleting the smog equipment from these older engines. It's probably not much of a power draw on the engine, but it sure would be handy to have out of the way.
Is it as simple as removing the pump & hoses, and capping the joints in this picture?
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667694
02/16/18 10:28 AM
02/16/18 10:28 AM
Michigan
researcher Offline
researcher  Offline
Michigan
I used to have that exact engine! I remember disconnecting the smog pump and the EGR got plugged up, notice that the hole you're referring to has the EGR next to it? The car carbon-ed up and it was a very long process to clean up the intake. Sure there was a power gain when all that was disconnected but over time it clogged up.
Sorry to say. But hey at least I could tell ya it was done before with my 200 I-6.. One other thing, you just can't kill that engine! The body of my 82 fox body rusted out before that engine ever gave up!
Maybe others have a better way, but I never found one back then.
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667719
02/16/18 10:46 AM
02/16/18 10:46 AM
Texas, USA
Texas, USA
Thanks for the input. Don't need an EGR issue (although I really don't know if it's functioning or not), so it stays.
What are the symptoms of a bad / clogged EGR?
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667755
02/16/18 11:21 AM
02/16/18 11:21 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If the pump hasn't frozen up, don't take it out. Find a vacuum diagram for the car on line. Push comes to shove plug stuff up with golf tees, but the car will never run right. I replaced every bit of vacuum hose and used the best stuff from 2 parts cars. Plus a new EGR valve on a '88 jeep 360 V8. With everything working it passed MA roller smog by good margin. It was a major PITA. You can do a little searching and prolly find all sorts of info on the interweb. Where's the carb?
Thick oil is better grin2
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667761
02/16/18 11:33 AM
02/16/18 11:33 AM
Michigan
researcher Offline
researcher  Offline
Michigan
let me remember.. car was running very rich, would have dieseling (run on) because of carbon build up in the chamber, lack of power, lower mpgs, hard to start when cold, had a burnt out catalytic (probably because it was running rich).. I think that's all I can remember, might've been one other thing but you get the idea.
I wasn't the one who disconnected the emissions stuff, it was some shop that did it. Claimed to a teenager that "oh you'll have more power". I didn't realize how dumb it was. I'm not one that always follows the rules, but how that spaghetti of vacuum lines, emission stuff is interwoven into that engine, either play by the rules or don't play at all. lol.
but as I learned about cars, I ended up learning how to fix things the RIGHT way and that's when I began to fix all that emissions stuff.
glad I could help ya! Never thought that years later I'd be giving advice about my ol' 200ci I-6! It's a reliable engine if a little slow. And that auto trans was bullet proof! I think it was a c-6 or c-3.
and as andyd said, inspect all the vacuum lines. If you have the original hood, the vacuum diagram is under there, I would definitely take a picture, never know how long that printing will be there before it fades!
I think its a 1 barrel carb. Oh that's what I wanted to tell you. Gas with ethanol in it will eat the rubber diaphram of the accelerator pump on the carb. Dries it out, then of course good luck trying to go! If you can try and use non-ethanol gas, if you can find it.. pure-gas.org is a good website to use.
Or just keep re-building the carb every couple years (on ethanol 10% gas) if ya have any other questions just ask! I know that engine very well.
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667853
02/16/18 01:05 PM
02/16/18 01:05 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Smog Wheezer
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667860
02/16/18 01:18 PM
02/16/18 01:18 PM
Texas, USA
Texas, USA
Thanks, researcher. The good news is it fires off right away when stone cold, and will happily climb to around 2200 rpms on the choke as it 'wakes up'. Not sure how fast or slow it should feel, as I don't have anything to compare it to, but if any engine could benefit from more cogs in the transmission, it's this one. It really catches it stride on the highway and has no trouble keeping up at 75mph, but it is turning 3000 rpm. It doesn't seem too perky in town and refuses to kick down until you stab it hard. (Probably a kick-down rod adjustment needed here).
It certainly sucks the gas, but nothing unexpected considering the comments I've read about this engine, such as "puts out the power of the 2.3, sucks gas like the 5.0". It doesn't care for being prodded before it's totally warmed up. Try to get too much out of it before it's hot, and it dies out for a moment before catching its breath. But every carbureted car I've ever driven did that. Is this a symptom of a bad EGR? I put on a new cap, rotor, plugs, wires, and fuel & air filters, but that behavior remains.
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667863
02/16/18 01:24 PM
02/16/18 01:24 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
That's a very tough engine. I had an ex girlfriend that drove one with a blown hose across the desert till it quit. A passer by taped up the hose,filled it with water and it ran for years after that.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667867
02/16/18 01:29 PM
02/16/18 01:29 PM
Texas, USA
Texas, USA
Yeah, a couple of guys on the Mustang forums say they've tried to kill one, but it outlasted the rest of the car.
Didn't it originate as a truck engine, that Ford used as a stopgap in the Mustang when they ran short of the 2.8 V6?
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667897
02/16/18 02:16 PM
02/16/18 02:16 PM
Michigan
researcher Offline
researcher  Offline
Michigan
you have described that engine perfectly! 2200rpms is about right for the cold idle. Yes you should probably adjust the kickdown linkage. I do remember entering the "kickdown" a lot on that engine, but it could take that and never complain. Yes at highway speed it cruises without a problem. I think that engine came with very tall gears in the axle hence the better highway driving. They did it for fuel economy! Also, the best mpg's that I ever achieved was 22.5mpg. I dont think I could ever hit 23 or 24. If you're around there, it's tuned up as good as it gets. I think it was 3.73 gears I had, and it was 3000rpms at 75mph+, these cars had speedometers that stopped at 85. Then the needle would just bounce.. lol..
Yup I had to find out. Cop stopped me and said "son.. do you know how fast you were going?" yup called me son, I knew I was in for a ticket! I said "no sir".. He said "you don't know how fast you were going??" I said again "no sir".. cop said "does your speedometer work, son?" I said "yes sir".. He said "so then how do you NOT know your speed?" I said "Well sir.. the speedometer only goes to 85 and the needle was just bouncing" He smiled at me.. trying not to laugh! I said "I have to know, how fast was I going?!" He said "clocked you at 89mph".. I thought "awesome".. yeah until I got that ticket, and that was the beginning of me buying a radar detector!
Oh it doesn't like to be asked to do anything when its cold. There is one thing that helps it warm up, there was a heat riser by the exhaust manifold that connected directly to the air cleaner housing. It helped things warm up quicker. My heat rise rusted off, so I just mounted some metal flex tubing down towards the manifold. It really did help. Once I got the accelerator pump diaphragm fixed, it didn't bog down too much at all when cold. Might want to check the carb make sure it's not eroded from ethanol-gas.
I believe it is similar to the truck series engine, but this one was from the Falcon and from what I remember it has its roots in the 60's. Lima, Ohio is the engine plant. It also, if you can believe it, shares some heritage with the 460, which shares a heritage with the 429 cobra. Crazy but true. One more piece of trivia. The lima plant needed something to make Ford keep them open and they chopped two cylinders off this 200ci engine, added a high-swirl combustion chamber, ohc.. it then became a 2.3L engine, put into use under the hood of the Ford Tempo/Mercury Topaz!
You just can't kill this thing! It will outlast the rest of the car (if it rusts). It's probably why this car is still around and the others like the 3.8 V-6 are in a junkyard somewhere.
The power I believe was 88-90hp, but the real nice part is the torque! 160 ft/lb at like 1600rpms. That's its saving grace! The torque! If someone has the exact specs, please speak up. But this is what I remember.
hope that helps!
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4667979
02/16/18 03:31 PM
02/16/18 03:31 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Wow - I had a 2.3L Mustang with a 4 speed stick. It got the mileage of the 5.0 and the power of a Briggs and Stratton. I didn't realize hoe bad it was until I bought a 97 Cobra with the DOHC 32V 4.6 and it got nearly the same mileage.
Seriously though - on my 2.3, the emissions stuff started dying off. Being the poor college student and no emissions it got removed. The pump went away and was capped although the cat was still there. Still ran as good as ever. The 2.3 was another gutless tough as nails engine!
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4668021
02/16/18 04:26 PM
02/16/18 04:26 PM
Texas, USA
Texas, USA
Thanks, guys. My sister had an identical car to this one, but was a base, with the 2.3. It was using some oil by 65,000 miles, but my sister quite literally thought cars were just something you put gas in and drove. It wasn't smoking, but it definitely needed a top-up between oil changes before she sold it. She tried her best to destroy that sweet little car between 1979 and 1985.
It's good to hear that at least I likely won't be having any trouble out of this engine. It's in the shop right now getting a brand new A/C, and we're struggling to find the correct steering rack for it. Cardone apparently has a slew of mis-boxed 22203F racks, box labeled 22203T (the one I need). We're on the 3rd one, and it's wrong too.
Once I finally get it back (2 weeks now), she's getting all new weatherstripping, and shocks & struts. Brakes come after that. I'll probably take it somewhere and have the carb gone through.
I tried my hand at carb work with a few of my past motorcycles, and I just don't have a talent for it.
Wish me luck!
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4668112
02/16/18 06:21 PM
02/16/18 06:21 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
IMO, take the belt off and and leave all your smog equipment in place.
Who knows, some day you might need it all in place if you get rid of the car.
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: WylieCoyote] #4668200
02/16/18 07:29 PM
02/16/18 07:29 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
... Didn't it originate as a truck engine, that Ford used as a stopgap in the Mustang when they ran short of the 2.8 V6?
Originated circa 1964 in the Falcon (and Mustang) as an upgrade from the older 144 and 170 cubic inch, 4-main-bearing Falcon engines. Later expanded to a 250 for Ford intermediates.
2011 Toyota Prius now at 95K
Re: Smog Pump Question - 82 Mustang 200 I6 [Re: andyd] #4668213
02/16/18 07:43 PM
02/16/18 07:43 PM
Texas, USA
Texas, USA
That's not my actual engine, but the picture (from the net) was exactly what I needed for my original question. My car is sitting in a shop with no steering rack in it.
Page 1 of 3 1 2 3
