Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
OEM Plugs for Lexus? #4667463
02/16/18 08:06 AM
02/16/18 08:06 AM
Albany, NY
ford46guy Offline OP
Albany, NY
The Lexus below is at 90k and never had plugs, rides ok but I can tell it needs them. Lexus said it can go till 120K but the manual says 60k. It is a DI engine.
The OEM plug(FK20HBR11) is expensive no matter where you buy it. The best price for a set of six out the door with discounts is about $83. Dealer quoted $35+tx(EACH!) but I think the retail is $18.
Denso also makes a compatible TT Iridium plug. It is $32 out the door for a set of 6 w/discounts. This has a .4 electrode vs the .6 or so in the OEM. I read in some cases they last till 100K but I also read 30K. I have them in my Explorer and it really cleaned up the idle, it idles better than the Lexus now.
Denso plugs are heavily counterfeited and there are many on ebay that are priced too good be true (especially the OEM, and they are in Toyota boxes).
I also see copper plugs for a buck a piece, I'm tempted, can change them out at 20-30K.
I don't know if DI needs that finewire electrode though. Seems those TT plugs create a very precise spark, the thinner the better!
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667465
02/16/18 08:11 AM
02/16/18 08:11 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Use OE, the last thing you need on that car are cat damaging misfires.
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667476
02/16/18 08:23 AM
02/16/18 08:23 AM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
$83 every 90K?
That is 3 tanks of gas.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667479
02/16/18 08:24 AM
02/16/18 08:24 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Use OE only
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667480
02/16/18 08:27 AM
02/16/18 08:27 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Driving a Lexus and cheaping out on plugs? Spend the money and you wont need to worry for 60k plus miles. You are overthinking it smile
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667491
02/16/18 08:41 AM
02/16/18 08:41 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
OE plugs only.
I'm more inclined to mess around on older cars, but not something so new and with DI. If an aftermarket fine wire iridium plug was available with the correct gap I might give it a try, but it doesn't appear that there is.
"Zed's dead baby, Zed's dead."
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667492
02/16/18 08:42 AM
02/16/18 08:42 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I've used Denso, NGK, and even the new Bosch in Toyota/Lexus with no issues. Use which ever is cheaper, your car will not know or care.
yup
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667519
02/16/18 09:05 AM
02/16/18 09:05 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
Sometimes you are okay with non oem and sometimes you are not.
How hard is it to get to the plugs?
If the the back 3 require removing the intake, then you may want to replace the coils on plugs too.
For that matter, be prepared to clean intake valves while the cover is off.
Just a thought.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667525
02/16/18 09:09 AM
02/16/18 09:09 AM
Albany, NY
Albany, NY
Rockauto has the OEMs for $67 shipped with discounts, problem solved there. The OEMs are a "Long Life Series" from Denso. The TTs are thinner.
I guess Rockauto wouldn't be a place for counterfeits.
Re: OEM Plugs for Lexus? [Re: Iowegian] #4667527
02/16/18 09:11 AM
02/16/18 09:11 AM
Albany, NY
Albany, NY
Just a thought.
It is a RWD layout, maybe a bit more work than the Grand Marquis. Easy job, the dealer soaks you for 2.2hrs of labor.
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667571
02/16/18 09:46 AM
02/16/18 09:46 AM
USA
HowAboutThis Offline
USA
I've always been a Denso or NGK guy. The top of the line are usually the 100k+ plugs. For 4 in my previous cars usually about $50-60. That price seems reasonable. $80-90 every 100-120k is cheap. Same reason I buy a good 80-90k tire instead of a 40-50k. Better value but more up front.
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667595
02/16/18 10:01 AM
02/16/18 10:01 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
The 3 on the back are kind of difficult to do so you don't want to put Copper Plugs in there.
I usually use NGK or Denso for Toyota/Lexus.
Their long life version is about $9, unless the price has gone up.
Sometimes, if you wait, Amazon may have a coupon that you can use with Prime (assuming you have Prime).
  • 2017 Toyota Sienna
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667625
02/16/18 10:33 AM
02/16/18 10:33 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Denso TT is identical to the oem fyi. Have them in currently, rock auto had them cheap at the time. Check there.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667711
02/16/18 11:38 AM
02/16/18 11:38 AM
Michigan
researcher Offline
researcher  Offline
Michigan
actually I remember some people getting some questionable things from rockauto, but rockauto took care of it, no problem.
also, on my scion tC (toyota 2az-fe engine) it came from the factory with NGK plugs instead of denso. Some came with Denso, some came with NGK. I prefer NGK. have you looked at the NGK equivalent?? on mine they're called Laser Iridium and have the fatter/wider center electrode. Might be cheaper..
I got mine at my local NAPA. Wasn't much different in price from online prices.
Re: OEM Plugs for Lexus? [Re: ford46guy] #4667767
02/16/18 12:39 PM
02/16/18 12:39 PM
California
nthach Offline
nthach  Offline
California
OE only. Don't cheap out with these.
