Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
107 registered members (AandPDan, Aero540T, ARCOgraphite, 1978elcamino, 13 invisible), 1,749 guests, and 56 spiders.
Topics286,228
Posts4,904,695
Members67,582
Most Online2,967
Mar 10th, 2019
Breaking in New old 4cyl. #4667320
02/15/18 11:52 PM
02/15/18 11:52 PM
AZ
junksta Offline OP
junksta  Offline OP
AZ
Just bought a 1990 Japanese 4x4 4cyl with 100k on the od. Have no idea of the history but was wondering what you thought the best way to break it as far as what oil to use. No drips but lower engine is oily/dirty. My idea is to flush it with cheap oil for 500 mi and then put in a good 10w30.
2012 Kia Sedona- QSUD
1990 Daihatsu Rocky
Re: Breaking in New old 4cyl. [Re: junksta] #4667324
02/15/18 11:58 PM
02/15/18 11:58 PM
New England
gathermewool Offline
New England
What's causing the oiliness? If it's the valve cover, replace the gasket. Take a peak inside valve-train and determine if there is any reason for concern (e.g., sludge.) if not, then run whatever oil you'd like and just drive it.
I'd also replace the differential oil and ATF/MTF, as applicable, as well as the brake fluid and coolant.
No such thing as breaking in a broken-in engine. Did you check compression and leak-down prior to purchase? What were the results?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Breaking in New old 4cyl. [Re: junksta] #4667327
02/16/18 12:00 AM
02/16/18 12:00 AM
out there
spasm3 Offline
spasm3  Offline
out there
Any good name brand conventional oil will do.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Breaking in New old 4cyl. [Re: junksta] #4667342
02/16/18 12:23 AM
02/16/18 12:23 AM
Texas
BalticBob Offline
BalticBob  Offline
Texas
A cheap oil to use for a flush is SuperTech from Wal-Mart, may want to do two 500 mile flushes. Then use a high quality name brand oil for 1000 miles to flush out the SuperTech. Then you are good to go for what OCI you choose. Change filter after every flush too.
Re: Breaking in New old 4cyl. [Re: junksta] #4667351
02/16/18 12:36 AM
02/16/18 12:36 AM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
If your new oil isn't too dark after 500 miles on conventional then you should be ok.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Breaking in New old 4cyl. [Re: junksta] #4667357
02/16/18 12:44 AM
02/16/18 12:44 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Best way to break it is leave the oil out, j/k. wink
Look in the oil fill cap with a good flashlight. If it looks pretty clean then no need for a flush. Just use a good oil and do regular OCIs.
Re: Breaking in New old 4cyl. [Re: junksta] #4667375
02/16/18 02:04 AM
02/16/18 02:04 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Never heard of a 1990 Japanese 4x4, I went to RockAuto to search for makes and models and it goes straight from Jaguar to Jeep with no "Japanese" between them.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Breaking in New old 4cyl. [Re: junksta] #4667376
02/16/18 02:08 AM
02/16/18 02:08 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Aha! I think he meant a 1990 Toyota!
Here it is, a 1990 Toyota Tercel 4x4 Wagon
Re: Breaking in New old 4cyl. [Re: junksta] #4667382
02/16/18 02:35 AM
02/16/18 02:35 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
In the '90's the Japanese made a AWD version of nearly every sedan they made...and then there are all the real 4X4's, most were 4 cyl.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Breaking in New old 4cyl. [Re: junksta] #4667433
02/16/18 07:27 AM
02/16/18 07:27 AM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
10w30 HDEO
Re: Breaking in New old 4cyl. [Re: junksta] #4667601
02/16/18 10:06 AM
02/16/18 10:06 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
That is a great car, any oil will do.
As suggested above, check why it is oily.
Also, your issue may be the fuel line since the lines are not made for Gasoline with Ethanol back then.
Of course, it depends on why the car only have such a low miles.
Sometimes, when a car is not driven regularly, the seals are all bad and that may cause the "oily" seen.
Most of the time, it is solved by driving it a lot and see which ones still need fixing after that.
  • 2017 Toyota Sienna
Re: Breaking in New old 4cyl. [Re: junksta] #4669928
02/18/18 04:37 PM
02/18/18 04:37 PM
AZ
junksta Offline OP
junksta  Offline OP
AZ
1990 Japanese vehicle. [img]http://[/img]
1990 Daihatsu Rocky
Re: Breaking in New old 4cyl. [Re: junksta] #4670095
02/18/18 07:34 PM
02/18/18 07:34 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
No need for all this flushing with cheap oil... What is that supposed to do? Accelerate wear for a short time ... Just put in good oil and a decent filter and drive it. Fix the leaks. 100,000 might be a candidate for a High Mileage (HM) oil.
At that mileage, it needs a major service. Change all the fluids. Tranny, diff's, brake fluid, etc. Remove and clean both ends of the battery cables, look over the brakes. FIX the leaks and lube the door hinges. Then just drive it smile
Re: Breaking in New old 4cyl. [Re: junksta] #4670810
02/19/18 12:52 PM
02/19/18 12:52 PM
AZ
junksta Offline OP
junksta  Offline OP
AZ
[img]http://https://photos.app.goo.glof/OxH7jLu5ewGa4Xg43[/img]
This is the 1990 Japanese vehicle. Done everything mentioned here, runs great.
1990 Daihatsu Rocky
