Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
123 registered members (addyguy, albenjoseph, 1978elcamino, 2015_PSD, 69Torino, 2K2AcuraTL, 14 invisible), 1,966 guests, and 59 spiders.
Topics286,146
Posts4,902,972
Members67,565
Most Online2,967
Mar 10th, 2019
Load Range Index - Higher= better tires? #4667254
02/15/18 09:29 PM
02/15/18 09:29 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Hi all, I am looking at two identical tires (Nokian WRG3) in 195-65-15 size and I have 2 options:
195/65R15 XL 95H Weight of tire: 17.20 pounds
AND
195/65R15 XL 92H Weight of tire: 15.11 pounds
The weight of the tire is off a tire website, so unsure of its accuracy. Am I correct to assume the tire will be more durable if I buy the 95H model?
Difference in price is about 4$ per tire to have the 95H vs 92H. I am just curious to know how the tire is different. What does that 2 pounds go to? Sidewall strength/more plies?
The OEM tires have a load index of 86S or 89S, so either one of the above Nokians exceeds the OEM requirements. And yes for car in signature!
Thanks in advance!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667257
02/15/18 09:37 PM
02/15/18 09:37 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I have some Nokian eNTYRES, 205/55r16s with a 94H load rating. The side wall is very stiff so next time I would want a lower number but at or slightly above the oem rating. Both tires have the XL rating also. In your case I'd go for the lower one so you don't feel like you're riding around in a truck.
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667258
02/15/18 09:37 PM
02/15/18 09:37 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
More durable, more load carrying capacity, may have a higher sidewall PSI.
However if the size of the tire is similar to OEM then you should still run the door jamb PSI under normal conditions.
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667278
02/15/18 10:16 PM
02/15/18 10:16 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Yes, better reinforced sidewalls/carcass.
Whether that's better for your particular application, I don't know. As the other poster noted, you might find them less comfortable to ride on if the sidewalls are stiffer.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Load Range Index - Higher= better tires? [Re: Reddy45] #4667279
02/15/18 10:17 PM
02/15/18 10:17 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
There are also 3 other factors in the tire rating. A's are better than B's or C's. I typically won't buy any daily driver passenger car tire with under 400 AB.
The UTQG rating system originated in the US as a way to help consumers make more informed tire-buying decisions. Tire manufacturers give their own tires a grade for treadwear, traction and temperature. Together, these numbers makes up a tire's UTQG rating—a three-digit number plus two letters. For example, 500 A A.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667323
02/15/18 11:57 PM
02/15/18 11:57 PM
PA
faramir9 Offline
faramir9  Offline
PA
2005 Corolla LE, 1.8L
QSGB 5w-30
Continental TrueContact 195/65R15
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667411
02/16/18 06:48 AM
02/16/18 06:48 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
My OE Michelin MXV4(215-55-17 load 93V) also come in 215-55-17 load 94V. I will probably stay with the 93V for comfort. I guess it depends on what you want!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Load Range Index - Higher= better tires? [Re: faramir9] #4667475
02/16/18 08:22 AM
02/16/18 08:22 AM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Originally Posted By: faramir9
You sure one of them is not 185/65R15?
https://www.nokiantires.com/all-weather-tires/nokian-wrg3/
Hmm..tire website listed 2 195 options..but they may have made a mistake, seems logical for 185 to have lower index.
PP 0w20 & ST 4967
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667490
02/16/18 08:40 AM
02/16/18 08:40 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Why would you go with an XL tire? I suspect they ride a bit closer to an LT tire and they are rough compared to a Passenger tire on our vans at work.
Also if they behave like LT tires, if your run them at lower pressures you lose mileage as well.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4667520
02/16/18 09:06 AM
02/16/18 09:06 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
May be I need to clear up a few things:
The difference between an SL (Standard Load) and an XL (Extra Load) is basically the ability to withstand the extra inflation pressure and extra load. While the body plies and the steel wire belts will be a bit stronger, operating an XL under SL conditions doesn't appreciably change the way the tire performs.
HOWEVER, changing from an XL to Load Range C (or D or E), does - but not because of the difference in Load Range, but because LT tires use different formulations of rubber - in order to withstand the additional load.
Ya' see, rubber has a property called compression set - it is permanently deformed under excessive load. So rubber formulated for an LT tire has to have greater resistance to compression set than rubber for P type tires.
In theory, a P type tire could be made out of the same rubber used for LT tires - and the difference in performance would be virtually undetectable.
So to answer the OP's original question - assuming the weight difference is due to the difference between an SL and an XL (and not the difference is size), then there is no advantage to be gained by using an XL tire in place of an SL - and, Yes!, that weight difference would be in slightly stronger plies and belts.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Load Range Index - Higher= better tires? [Re: faramir9] #4667583
02/16/18 09:53 AM
02/16/18 09:53 AM
Great Lakes
Great Lakes
Good catch!
It would not make sense for Nokian to make two different XL-rated 195/65/15 tires.
Here is one dealer offering:
https://www.tiresbyweb.com/p-11103-nokian-wr-g3-tire.aspx
I am only seeing one 195/65/15 tire.
Re: Load Range Index - Higher= better tires? [Re: Rolla07] #4668285
02/16/18 09:55 PM
02/16/18 09:55 PM
ME
eljefino Offline
eljefino  Offline
ME
For whatever reason, the Champiro snow tires I bought in 195/65/15 are XL rated.
This was the only way they'd legally replace the 205s on my camry. Much cheaper, a super common size if I need a replacement, and 10mm skinnier to dig through the snow.
195/65/15 is or was one of the most common sizes out there.
I'd buy the XL tires because you'll also be running them in pothole season.
