better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
45 registered (bradepb, bbhero, 77GrandPrix, BoiseBound, CleverUserName, Char Baby, 7 invisible), 878 Guests and 38 Spiders online.
65265 Members
67 Forums
285578 Topics
#4667135 - 02/15/18 06:36 PM Factory catalytic converters -VS- Magnaflow cats?
lawnguy Offline
Loc: Florida
Is there any difference in sound and performance between factory cats on a 2000 F150 , compared to the Magnaflow catalytic converters?
#4667156 - 02/15/18 06:52 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
Nick1994 Offline
Loc: Phoenix, AZ
Nope. I put a Magnaflow high-flow cat on my Jeep last summer. Made no difference at all. My original cat was broken inside from off-roading and smashing it. Nice and quiet too.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4667168 - 02/15/18 07:05 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
lawnguy Offline
Loc: Florida
If both diff. cats have that screen it will slow down air flow no matter what. I'm curious if its a absolute 100% fact that having no cats on a 2000 f150 v8 it will decrease in horsepower? I wish I could find an actual dyno demo video showing this test.
#4667169 - 02/15/18 07:05 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
bdcardinal Offline
Loc: Santa Barbara, CA
Probably the Magnaflow ones are available while the OEM replacement cats are most likely obsolete.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4667199 - 02/15/18 07:30 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
14Accent Offline
Loc: MN
No cats? Yes, it's 100% proven that bone stock Modular motors like to have a little back pressure in the exhaust, regardless of 4.6/5.4/6.8 or the chassis it's installed in.
You have 4 cats on that 2000. Only the front two are monitored by the PCM. Have an exhaust shop cut out and straight pipe the rear two cats. No check engine light, and a decent "seat of the pants" gain in power.
Google/youtube "F150 rear cat delete" or "Crown vic rear cat delete". You'll see.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4667212 - 02/15/18 07:40 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
slacktide_bitog Offline
Loc: USA
The sound level should be the same. Remember, the mufflers and resonators have much more of an effect on the sound than the cats do smile
#4667274 - 02/15/18 09:10 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: slacktide_bitog]
bdcardinal Offline
You would be surprised. I swapped in an offroad X pipe on my 98 Mustang GT replacing the factory 6 cat H pipe and it was substantially louder.
#4667363 - 02/16/18 12:07 AM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
OneEyeJack Offline
Loc: S California
There is a bit of buzz involving Ford cats recently.
Ford's Catalytic Converter Eliminates Use of Platinum
LINK
#4667365 - 02/16/18 12:22 AM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: 14Accent]
lawnguy Offline
Loc: Florida
Where are the 02 sensors located at in relation to the front or rear cats?
#4667477 - 02/16/18 07:23 AM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
JHZR2 Offline
Loc: New Jersey
If you have emissions testing (or even if not, nobody anywhere likes to sit behind an obnoxiously stinky vehicle), you should at minimum ensure you find a cat with a CARB rating.
My 91 BMW was having issues with high NOx emissions. Everything ran perfect, so it was resolved to be a catalyst issue. IIRC failing was around 1200ppm, and my OE cat was on the cusp. Swapped in a manga flow and I barely passed. Somewhere in the 1170s, as I recall. Two years later, failed again.
Bit the bullet and got an OE converter, I passed with 14ppm.
So the OE converter was around 100x better.
#4667516 - 02/16/18 08:03 AM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: JHZR2]
Trav Offline
Loc: MA, Mittelfranken.de
There is a lot more wash coat on OE and they don't rust like aftermarket.
#4667738 - 02/16/18 10:58 AM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: JHZR2]
andyd Offline
Loc: Marshfield , MA
The BMWs Boysen exhaust weighed about twice what My jeep's system weighed. About 275 K miles it failed emissions for NOx, I replaced the original O2 sensor and treated the fuel with some pink glop that was designed to help jet liners burn cleaner. It worked and I got another 3 yrs out of the cat. Your experience with after mkt cats exactly meshes with tales from the E 28 forum.
Thick oil is better grin2
#4667821 - 02/16/18 12:28 PM Re: Factory catalytic converters -VS- Magnaflow cats? [Re: lawnguy]
nthach Offline
Loc: California
OE cats are made to CARB standards(more precious metal in the washcoat) - and they flow better. Aftermarket cats might not flow as well and don't last as long. I had 2 Walker CARB-compliant cats welded in after my OEM Futaba ones died due to misfires and while the car did pass smog I noticed a huge drop off in performance. The Walkers were much smaller than the OEM Toyota cats. The inlet/outlet were the same but the catalytic substrate was much smaller.
Edited by nthach (02/16/18 12:29 PM)
