Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
120 registered members (2015_PSD, 87sammy, 2010Civic, 3311, 01rangerxl, 7 invisible), 1,794 guests, and 55 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
New M1 0W-40 ESP dexos2 #4666899
02/15/18 03:46 PM
02/15/18 03:46 PM
Central Texas
AirBull Offline OP
AirBull  Offline OP
Central Texas
So GM is now using Mobil1's new 0w-40 ESP with dexos2 rating for all new 2019 Corvette's, and as you will see from a reply from Tadge Juechtner, Corvette Chief Engineer, he's recommending that all C7 Corvette's from 2014 onward switch from the previous 5w-30 recommendation to this new 0w-40 ESP formula. In fact, M1 says you can use it in all previous Corvette engines that called for a dexos approved oil.
Specs below are from M1. Interesting in how they compare. If GM is recommending this new 0w-40 for all of the LT1 GenV motors, than I'd probably want to run it over the 0w-20 oil they call for in the L86 6.2L in my Yukon Denalli, as it is essentially the same engine as the LT1 that comes in the C7 Corvette, (different exhaust manifolds and different intake manifold, but other otherwise identical.)
M1 0w-40 ESP dexos2 Product Data Sheet
Quote:
Tadge answered:
Yes, the new Mobil1 OW40 Dexos 2 oil (Mobil 1 ESP Formula 0W-40) is also the recommended oil for all C7's prior to 2019. This oil was specifically developed to meet all of GM's performance requirements during engine dyno testing, vehicle road testing and performance track testing including the 2014-2018 Corvettes (all models). The Multi-grade Mobil 1 ESP Formula 0W-40 synthetic motor oil has many benefits including exceptional fast oil flow at startup along with low temperature pump-ability and exceptional viscosity/performance characteristics at high-temperature and high-RPM operating conditions. We are still refining our recommendations for the LT5 in the upcoming ZR1, so they may differ.
Link
'15 BMW M5 (Ravenol VollSynth Turbo VST 5w-40)
'18 Buick Enclave Avenir (Ravenol DXG 5w30)
'17 GMC Yukon Denali 4x4 6.2L V8 (Mobil1 EP 0w20)
Re: New M1 0W-40 ESP dexos2 [Re: AirBull] #4666909
02/15/18 03:54 PM
02/15/18 03:54 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Why not just use the FS 0W-40 in a gasoline engine?
Higher HTHS, TBN, and SAPS.
"Zed's dead baby, Zed's dead."
Re: New M1 0W-40 ESP dexos2 [Re: rooflessVW] #4666920
02/15/18 04:04 PM
02/15/18 04:04 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Could GM be worried about LSPI?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: New M1 0W-40 ESP dexos2 [Re: rooflessVW] #4666930
02/15/18 04:17 PM
02/15/18 04:17 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
Yup, that last one may be key here. The PU 0w-40 SRT stuff is lower on the AW additives than the typical Euro oil.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: New M1 0W-40 ESP dexos2 [Re: AirBull] #4666946
02/15/18 04:38 PM
02/15/18 04:38 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Why not just make 0w40 the standard oil and forget the other stuff, every GM engine gas or diesel in Europe is dexos 2.
The fact they don't recommend a xw20 or xw30 makes it pretty evident that those oils don't protect the engine well enough. Today I only buy Mobil 1 or Castrol 0w40 and it goes in everything inc small engines.
You wont believe it, nothing blew up, ran poorly, wore out or failed to start in cold weather. Snow blower is 13 yrs old this Nov and has had 0w40 in it since the first hour, it now has over 150 hours on it and uses no oil, starts first pull and has never needed a valve adjustment since the initial on at 20 hrs.
That tells a lot right there! It means there is not enough wear on the cam, lifters or rocker arms to measure, if the top end is that good the bottom end is the same or even better.
Re: New M1 0W-40 ESP dexos2 [Re: Trav] #4666950
02/15/18 04:43 PM
02/15/18 04:43 PM
Great Lakes
Great Lakes
Because in the US we have CAFE. 40 grades are therefore evil. smile
Not well enough on the track, but it may be just barely enough on the street. smile
Re: New M1 0W-40 ESP dexos2 [Re: Quattro Pete] #4666952
02/15/18 04:45 PM
02/15/18 04:45 PM
Trav Offline
Trav  Offline
True enough I guess where people drive slower than geriatric sex.
Re: New M1 0W-40 ESP dexos2 [Re: Quattro Pete] #4666974
02/15/18 05:03 PM
02/15/18 05:03 PM
Central Texas
AirBull Offline OP
AirBull  Offline OP
Central Texas
The GM GenV LT engines have direct injection and therefore I believe one of the ways to combat carbon buildup is to require low SAPS. The new GenV LT5 motor in the new ZR1 is GM's first engine to offer both Port and Direct Injection, just like what Ford is doing with the Gen2 EcoBoost motors.
Re: New M1 0W-40 ESP dexos2 [Re: AirBull] #4666994
02/15/18 05:28 PM
02/15/18 05:28 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Interesting-thought Dexos 2 oils were too low in TBN for our high sulfur gasoline? Did our gasoline become low sulfur now? Or are the oils going to have short usable lifespans because of it? I do see it has an 8.5 TBN, that's not really low at all compared to most SN oils. Now they just have to get it into WM to get the price down...
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: New M1 0W-40 ESP dexos2 [Re: bullwinkle] #4667009
02/15/18 05:43 PM
02/15/18 05:43 PM
Great Lakes
Great Lakes
We are getting there. There is already a mandate to require a 10ppm sulfur national average. Unfortunately, for now it's still just an average.
Based on what Patman wrote earlier, the OLM in these new Vettes is calibrated in a way where you are unlikely to see very long OCI so the 8.5 TBN should be sufficient.
Re: New M1 0W-40 ESP dexos2 [Re: Quattro Pete] #4667041
02/15/18 06:16 PM
02/15/18 06:16 PM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
It's true, most people with Corvettes will hit the one year mark before they put any significant miles on the oil, and the OLM in the C7 Corvette always hits 0% by the one year anniversary of the last reset, even if you don't start the engine at all. But for those that do drive their cars daily, it seems like the OLM counts down to zero around 6 or 7k. So only someone doing pure highway driving on a new Corvette would ever see a 10k interval or higher I suspect.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: New M1 0W-40 ESP dexos2 [Re: Trav] #4667055
02/15/18 06:26 PM
02/15/18 06:26 PM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
I'm not disagreeing with you but Dexos 2 comes in 5w30 regularly. Possibly in 0w30 too, albeit I'm unsure about that. Dynamic viscosity is what counts.
SAE grades are just for marketing purposes in ACEA world and Dexos 2 is just a C3 based oil in the end.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: New M1 0W-40 ESP dexos2 [Re: Quattro Pete] #4667075
02/15/18 06:41 PM
02/15/18 06:41 PM
Great Lakes
Great Lakes
Quote:
Based on what Patman wrote earlier, the OLM in these new Vettes is calibrated in a way where you are unlikely to see very long OCI so the 8.5 TBN should be insufficient.
That should have said 'sufficient'. Too late to edit.
Re: New M1 0W-40 ESP dexos2 [Re: bullwinkle] #4667112
02/15/18 07:16 PM
02/15/18 07:16 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Watch the OCI, and it shouldn't be a problem. Given the usage pattern of Vettes, if people are following the "time" aspect of the intervals and maintenance minder, it shouldn't be a problem.
Plain, simple Garak.
Re: New M1 0W-40 ESP dexos2 [Re: chrisri] #4667116
02/15/18 07:20 PM
02/15/18 07:20 PM
Trav Offline
Trav  Offline
Your right I should have said high HTHS oil my bad.
