Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (Aero540T, 4WD, 69Torino, AdditiveOCD, 2015_PSD, 9 invisible), 1,710 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
VOA Hot Shot's Stiction Eliminator #4666810
02/15/18 01:11 PM
02/15/18 01:11 PM
NC
Vladiator Offline OP
NC
Hot Shot's Stiction Eliminator that is praised by many diesel fellas for bringing the injectors back to life. I guess they are really good about hiding secret elements here lol.
According to the manufacturers - it could be used for gasoline engines at a rate of 16oz per 5qts of oil. I got it in the oil now, don't know what it will do. But I like to test stuff out. Throw some theories into what will happen here. Got 1k miles so far, 4k to go.
Re: VOA Hot Shot's Stiction Eliminator [Re: Vladiator] #4666827
02/15/18 01:28 PM
02/15/18 01:28 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
So, it's got green food coloring, 200ppm Moly, some sand and literally nothing else, has the consistency of Mercon LV, and is only going to dilute the add pack of any oil??
Did I get it all? So why would I buy this?
It must just work on diluting coked oil and deposits in injectors smile Thanks for the info, Vlad!
Re: VOA Hot Shot's Stiction Eliminator [Re: Vladiator] #4666934
02/15/18 03:24 PM
02/15/18 03:24 PM
Kentucky
Fsharp Offline
Fsharp  Offline
Kentucky
I wonder if its an ester additive. Hot Shot Secret also sells their fr3 ester oil additive.
Re: VOA Hot Shot's Stiction Eliminator [Re: Vladiator] #4667019
02/15/18 04:50 PM
02/15/18 04:50 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
How is it going to unplug and injector if added to the oil?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: VOA Hot Shot's Stiction Eliminator [Re: Chris142] #4667195
02/15/18 07:26 PM
02/15/18 07:26 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
I think he is referring to the HUEI injectors on Powerstroke 7.3 and 6.0 that often have a static friction problem, aka stiction in the oil operated injectors, causing hard cold starts and rough idle until warmed up. I have a friend who owns a 1997 F250 7.3 and swears by the Rev-X additive for his engine. Another friend is using something called Arch 6.0, made by the same folks who make TurboMaxx, not to be confused with Archoil, another brand that sells a product that is supposed to help with stiction. The Arch 6.0 is specifically for the Powerstroke 6.0 or 7.3 and is similar to their main anti-wear, friction reducing product, called TurboMaxx. Both guys swear by what they are using and intend to keep using it every oil change, regardless of the added cost. It fixed whatever issues they were having with cold idle in cold weather.
Re: VOA Hot Shot's Stiction Eliminator [Re: Vladiator] #4667271
02/15/18 09:07 PM
02/15/18 09:07 PM
NC
NC
Yes, I was referring to the Ford (and other) diesel injectors that work through oil pressure. Forgive me diesel guys if I'm explaining this wrong... Never had a diesel, nor worked on one.
Re: VOA Hot Shot's Stiction Eliminator [Re: Chris142] #4667296
02/15/18 10:08 PM
02/15/18 10:08 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I'd suspect that it's going to thin the oil to help get a friction modifier someplace where stuff rests and sticks.
I wonder if the Si is to prevent foam?
Re: VOA Hot Shot's Stiction Eliminator [Re: JHZR2] #4667299
02/15/18 10:15 PM
02/15/18 10:15 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Sandblasts the injector orifice.
Cool.
Re: VOA Hot Shot's Stiction Eliminator [Re: Ducked] #4702828
03/22/18 07:26 AM
03/22/18 07:26 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Cool.
Anti foam.
2015 Ford F150 2.7
2018 Ford F350 6.2
