The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
29 registered members (Agnosto, Bailes1992, carlprop, c502cid, chance, 4 invisible), 634 guests, and 62 spiders.
Topics286,097
Posts4,902,471
Members67,560
Most Online2,967
Mar 10th, 2019
Hydrodynamic lubrication and journal finish #4666734
02/15/18 12:42 PM
02/15/18 12:42 PM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
What part does journal finish play in the creation of hydrodynamic lubrication. Specifically can a bearing surface be too highly polished to drag the oil around and produce the wedge. If a mirror finish is not desirable what would the optimum surface finish be.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4666743
02/15/18 12:50 PM
02/15/18 12:50 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I never heard of a surface being too highly polished for hydrodynamic lubrication. I believe it can be a factor in low-speed applications, where you sometimes want to create mini reservoirs for oil lubrication. But not for hydrodynamic lubrication.
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4666751
02/15/18 12:59 PM
02/15/18 12:59 PM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
Thanks.
I've never seen a mirror finished crank journal from the factory or re-grinder but someone has mirror polished one by hand and I was wondering if that was a wise thing to do.
Barry
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4666774
02/15/18 01:33 PM
02/15/18 01:33 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Want to see some nice cranks check these out. BTW that's not chrome its micro polished to less than 1 Ra.
http://winbergcrankshafts.com/
Re: Hydrodynamic lubrication and journal finish [Re: Kestas] #4666929
02/15/18 04:16 PM
02/15/18 04:16 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
My thoughts as well, since in fully hydrodynamic lubrication there is total separation of the journal and the bearing due to the oil wedge, which is caused by the relative motion of the journal wrt bearing.
In the cylinder bore you want cross-hatching or laser dot depressions for mini oil reservoirs.
I would think there is point of diminishing returns in terms of journal finish verses oil entrainement.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4666979
02/15/18 05:08 PM
02/15/18 05:08 PM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
Thanks guys. Highly polishing a journal is fine then.
Barry
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4666996
02/15/18 05:29 PM
02/15/18 05:29 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
If you are grinding and polishing journals on a ductile iron crankshaft, the direction of finish is critical. If done in the wrong direction, it can wipe out a bearing.
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4667050
02/15/18 06:24 PM
02/15/18 06:24 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Well, what is the advantage in polishing down to the n-th finish?
Quote:
...The results are reduced parasitic losses, reduced oil foaming and increased oil shedding...
Someone in Marketing has a wild imagination. shocked2
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4667198
02/15/18 08:30 PM
02/15/18 08:30 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Perhaps some slight increase in startup wear after long stand, if "overpolished"?
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4668144
02/16/18 07:55 PM
02/16/18 07:55 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
You can't polish metal to the point that the oil won't "stick" to the surfaces and create the oil wedge.
The polishing reduces the height of the asperities, and means that for a given geometry and urface speed lower viscosity oils (smaller MOFT) can be satisfactory.
Not sure what the slight reduction in MOFT (opening up clearances decreases MOFT) versus the reduction in Asperite height means 'though...is that the realm of diminishing returns.
Re: Hydrodynamic lubrication and journal finish [Re: barryh] #4708861
03/27/18 07:58 PM
03/27/18 07:58 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
To be picky, this is a fairly interesting question, but its in "Technical and White Papers", and there doesn't seem to be one.
