stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
106 registered members (AZjeff, 2015_PSD, anndel, ArrestMeRedZ, AndyB, 15 invisible), 1,907 guests, and 66 spiders.
Topics286,431
Posts4,908,112
Members67,622
Most Online2,967
Mar 10th, 2019
2007 Silverado - ABS Lite #4666723
02/15/18 12:30 PM
02/15/18 12:30 PM
Texas
WyrTwister Offline OP
Texas
Staying on about 1/2 the time . Brake reservoir is full .
What to check first ? Wheel sensors & wiring ?
Thanks , :-)
Wyr
God bless
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4666736
02/15/18 12:43 PM
02/15/18 12:43 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
In my experience, intermittent lights are often sensors going out. I'd hazard a guess that you have a wheel speed sensor on the way out.
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4666738
02/15/18 12:46 PM
02/15/18 12:46 PM
VA
Rhymingmechanic Offline
VA
Check for codes?
I got ABS and a bunch of other warning lights on my Vibe, and Advance Auto's scanner was able to pull ABS codes. The problem turned out to be a bad wheel sensor and harness.
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4666739
02/15/18 12:46 PM
02/15/18 12:46 PM
USA
mk378 Offline
mk378  Offline
USA
Read the code.
Re: 2007 Silverado - ABS Lite [Re: JustN89] #4666848
02/15/18 02:51 PM
02/15/18 02:51 PM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
Probably this. Every ABS light I have ever had was an indication that a wheel bearing was soon to follow.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4666854
02/15/18 02:59 PM
02/15/18 02:59 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
My neighbor just went through this with an '09 Silverado. The only thing that he could find that was marginal with the braking system was that the rear brake shoes were just about gone. He replaced the shoes, and the light has stayed off since.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4666891
02/15/18 03:41 PM
02/15/18 03:41 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
IIRC these use a separate ABS sensor, look for metal particles or other junk on the magnet. Many times rust from the brake shield collects on them and will cause an intermittent light.
Edit: Next time the light is on use an ABS scanner to determine the offending sensor, clean before replace.
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4667251
02/15/18 09:21 PM
02/15/18 09:21 PM
Texas
Texas
I have a scanner that may or may not read ABS codes . May try it in the next few days .
Just moved into this truck earlier in the week . Mine was totaled & this is / was the spare company truck .
Any idea if ABC codes are stored , after the ABS lite goes out ?
Thanks , :-)
Wyr
God bless
Wyr
God bless
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4667314
02/15/18 11:42 PM
02/15/18 11:42 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
The EBCM stores history codes, If you have a front WSS code.....I would start with jacking up the truck & checking for a loose wheel hub bearing. Corrosion isn't an issue in most parts of Texas.
2001 Chevy Camaro L92/4L80E
Re: 2007 Silverado - ABS Lite [Re: clinebarger] #4667512
02/16/18 08:58 AM
02/16/18 08:58 AM
Trav Offline
Trav  Offline
Yes why would the brake shield be rotten in Texas, not everybody lives with rusty rotten stuff like us poor basta.... LOL
Re: 2007 Silverado - ABS Lite [Re: clinebarger] #4667539
02/16/18 09:27 AM
02/16/18 09:27 AM
Texas
Texas
Do not hear / feel any bearing problems . For what that is worth .
In my youth , pickup wheel bearings , were the kind that you could take out and hand pack . Would a 2007 Chevy have that type or the sealed bearings ?
Wyr
God bless
Re: 2007 Silverado - ABS Lite [Re: Trav] #4667540
02/16/18 09:28 AM
02/16/18 09:28 AM
Texas
Texas
For that I am thankful !
Wyr
God bless
Re: 2007 Silverado - ABS Lite [Re: Trav] #4668376
02/17/18 12:22 AM
02/17/18 12:22 AM
Fort Worth, Texas
Fort Worth, Texas
I've seen some Northeast/Midwest cars roll through the shop over years.....[censored]!!! I applaud you mechanics that have to deal with that on every single vehicle.
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4668383
02/17/18 12:40 AM
02/17/18 12:40 AM
Fort Worth, Texas
Fort Worth, Texas
They can be loose enough to mess with the sensor air-gap but not make noise.....Yet.
Some bearings make a TON of noise & not have any slack.....Just last week I did a rear wheel bearing on a 2003 Sequoia that was raising [censored] with .003" axial end play & .001 radial end play.
GM has used sealed hub bearing in all light duty trucks since the introduction of the GMT-800 platform, And only 2wd GMT-400 trucks had seviceable tapered bearings.
Retrieve the Current & History DTC's out of the EBCM & proceed from there!
Re: 2007 Silverado - ABS Lite [Re: WyrTwister] #4668870
02/17/18 04:41 PM
02/17/18 04:41 PM
Florida
artificialist Offline
Florida
I am not sure if there are ABS sensors at both rear wheels, or if there is one sensor at the differential gear. I have been told that if you have an ABS sensor that reads the rear differential, the magnet may attract metal from the gear oil. The solution is to remove the sensor, clean it, and replace your gear oil.
2010 Lancer Ralliart Sportback
