Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
89 registered members (53' Stude, andyd, Astro14, alphadog, 2dogs, 2015_PSD, 13 invisible), 1,895 guests, and 25 spiders.
Topics287,853
Posts4,935,596
Members67,865
Most Online2,967
Mar 10th, 2019
Peracetic acid for de-leading gun barrels #4666363
02/15/18 12:27 AM
02/15/18 12:27 AM
Where the wind comes sweepin'
Reddy45 Offline OP
Reddy45  Offline OP
This stuff works so good it should be illegal. LOL.
You plug the end of the barrel, and then pour in a 50/50 mixture of hydrogen peroxide and vinegar. The chemical reaction literally breaks the lead into chunks that fall off.
YES the byproduct is lead acetate and is hazardous!
YES you should only do this if you are capable of being responsible about it and disposing of it properly.
YES this is not recommended for blued firearms or any collectible with a delicate finish.
YES it works better than anything I've tried to get out stubborn lead from shooting moly reloads.
Luckily, I only needed it after I shot the last of my cast lead bullets. I'm sticking with FMJ from now on.
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666375
02/15/18 01:08 AM
02/15/18 01:08 AM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
Do you know what caused the barrel leading?
What type of firearm was it?
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666378
02/15/18 01:18 AM
02/15/18 01:18 AM
Reddy45 Offline OP
Reddy45  Offline OP
Probably my choice of powder. 8.0 grains of Alliant Power Pistol behind a 185gr SWC cast lead with a moly coat.
Pretty hot load on top of this combo not being recommended, but it shot fine, and was VERY accurate.
Gun was a S&W M&P 45.
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666508
02/15/18 08:58 AM
02/15/18 08:58 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I think I heard of this method . From what I remember , it is very aggressive and can permanently damage the barrel if used incorrectly . ( For instance , leaving the mix in the barrel too long . )
When I shoot a cast bullet , I try for at least .002" over groove size . Helps a lot .
A cousin powder coats his cast bullets & has made great progress .
If your barrel is leading , I recommend a brass bush , Hoppies & elbow grease .
Wyr
God bless
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666522
02/15/18 09:12 AM
02/15/18 09:12 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Isn't this something similar to what the old Outers "Foul Out", reverse plating gizmo was based on? I know the original 110 Volt powered unit they first put on the market was responsible for trashing several barrels, by transferring barrel steel to the provided anode you put in the barrel if you left it plugged in too long. They later came out with a battery powered unit that was less powerful. They had separate chemicals you had to buy, depending if you wanted to remove lead or copper fouling.
The whole thing used a lot of expensive chemicals that were messy, and leaked everywhere. It ended up to be far more trouble than it was worth. I believe the only way to acquire one now is at a garage sale.
Re: Peracetic acid for de-leading gun barrels [Re: WyrTwister] #4666564
02/15/18 09:56 AM
02/15/18 09:56 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
If your barrel is leading you're shooting an alloy that is too soft. I've shot cast for years and never had a leading issue. Stick at brindle hardness 15 (Lyman number 2 Alloy) or higher and if you plan on shooting over 1000 fps go to gas checked bullets. Your sizing lube also comes into some play here.
Years ago when I started casting I tested some cast bullets I had bought with my BH tester some of them were BH 9 and 10. They hadn't given me issues but were used for target loads at 800 fps and slower.
2004 Corolla 130880
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666805
02/15/18 02:05 PM
02/15/18 02:05 PM
Canada
i_hate_autofraud Offline
Canada
How strong does the hydrogen peroxide have to be?
If it's from a drug store it's only 5% concentration..
Would it still work?
Re: Peracetic acid for de-leading gun barrels [Re: Reddy45] #4666922
02/15/18 04:07 PM
02/15/18 04:07 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
You can get 30% acetic acid and 35% hydrogen peroxide off Amazon or ebay.
We use to use these strengths to completely dissolve lead. Will not harm steel.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Peracetic acid for de-leading gun barrels [Re: i_hate_autofraud] #4666928
02/15/18 04:16 PM
02/15/18 04:16 PM
Reddy45 Offline OP
Reddy45  Offline OP
Yup I used the consumer grade brown bottle -- so around 5%. Vinegar was white cooking vinegar by Heinz.
If the leading is visibly built up, I'd leave the solution soaking for 10..maybe 15 minutes before dumping it and flushing with water.
