It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
72 registered (2009Edge, 2015_PSD, 63Marauder, badtlc, 10 invisible), 1187 Guests and 36 Spiders online.
65319 Members
67 Forums
285956 Topics
Page 1 of 2 1 2 >
#4666082 - 02/14/18 05:37 PM fram inlet holes
mobilaltima Offline
Loc: Golden Meadow, LA
Recently while I was at Wal Mart, I looked at the PH line of fram filters to see if any had the new silicone ADBV. The PH10060 had one, but I did notice the holes in the center tube seemed small, smaller than I remember seeing on Frams. The TG and XG 10060 were the same, small holes. Would this cause a flow problem? I looked at a few different Fram filters and the holes were all small, also.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4666086 - 02/14/18 05:41 PM Re: fram inlet holes [Re: mobilaltima]
MONKEYMAN Offline
Loc: St. Louis
I had the same concern and called Fram. Was told will flow fine. The holes were so tiny compared to the holes on the OEM Hyundai filter. It was the XG9688 Fram filter.
Truth alone triumphs, not untruth.
2017 Elantra SE
#4666087 - 02/14/18 05:42 PM Re: fram inlet holes [Re: mobilaltima]
ZeeOSix Offline
Loc: PNW
It's the total flow area of all those holes combined that matters.
#4666108 - 02/14/18 06:24 PM Re: fram inlet holes [Re: mobilaltima]
BlueOvalFitter Offline
Loc: Cajun Country, La.
HOLE E cow! crazy
#4666122 - 02/14/18 06:37 PM Re: fram inlet holes [Re: ZeeOSix]
Linctex Offline
Loc: Waco, TX
^^^ This, right here.
#4666124 - 02/14/18 06:37 PM Re: fram inlet holes [Re: mobilaltima]
Nyogtha Offline
Loc: San Antonio, TX
Edited by Nyogtha (02/14/18 06:40 PM)
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4666214 - 02/14/18 08:23 PM Re: fram inlet holes [Re: mobilaltima]
PimTac Offline
Loc: Soviet State of Washington
ZeeOSix and Linctex are correct. Smaller holes but more of them will mean even more flow. Same with louvers.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4666253 - 02/14/18 08:56 PM Re: fram inlet holes [Re: mobilaltima]
SubieRubyRoo Offline
Loc: Winchester, Indiana
Also remember that it's a liquid being forced thru the holes at a pretty significant pressure, not like you're trying to breathe through one of those holes. Like Zee said, put them all together and there's plenty of flow potential. Most car filters have no problems passing 8-10 GPM which you'd be hard pressed (as in never) to hit on any production car oil pump. It'd be a huge parasitic drag as well.
#4666334 - 02/14/18 10:35 PM Re: fram inlet holes [Re: SubieRubyRoo]
Are you saying that they make the louvers a precise cut to allow the oil to flow a certain psi? And, by the way they are arranged the oil can only flow through the precise cut louvers in this way to make said psi? Why do I need to know all of this? I should be able to just go into WM, pick the MC oil filter that fits my trucks engine, and go from there. Not worry about if the tube has louvers or round holes.
shrug
#4666343 - 02/14/18 10:53 PM Re: fram inlet holes [Re: BlueOvalFitter]
Linctex Offline
Loc: Waco, TX
Originally Posted By: BlueOvalFitter
Why do I need to know all of this? I should be able to just go into WM, pick the MC oil filter that fits my trucks engine, and go from there. Not worry about if the tube has louvers or round holes. shrug
Yes, you should do exactly that.
1) Buy a Motorcraft oil Filter.
2) Put it on.
3) Don't worry about how it's made grin2
#4666358 - 02/14/18 11:09 PM Re: fram inlet holes [Re: BlueOvalFitter]
ZeeOSix Offline
Loc: PNW
No and No.
If you use a filter with louvers, just make sure they are all opened up pretty good.
#4666396 - 02/15/18 01:45 AM Re: fram inlet holes [Re: mobilaltima]
goodtimes Offline
Loc: california
I looked at the new EG too, looked the same to me. The inlet baseplates come in two varieties of holes though. For unknown reason some of their small filters like the 4967 have larger inlet holes than the 3614. The center tube holes looked the same as before to me. It would be interesting to see the Fram racing filters center tube holes and baseplates to compare.
#4666469 - 02/15/18 07:16 AM Re: fram inlet holes [Re: goodtimes]
Kira Offline
Loc: Champlain/Hudson Valley
I love examination and explanation of details but all the noise about holes vs louvers escapes me.
We have recurring hole vs louver concerns but nearly no data on media filtering efficiency.
When we look at wet pleats and say conclusively, "That looks good" then howl about center tube holes......
Anybody ever measure the total open area of holes vs louvers? ....didn't think so.
I suppose I should don my flame suit.
#4666496 - 02/15/18 07:44 AM Re: fram inlet holes [Re: Linctex]
2) Put it on.
Thank You! Someone else that sees it my way.
#4666499 - 02/15/18 07:46 AM Re: fram inlet holes [Re: mobilaltima]
Why not use triangles, squares, or even octagons? shrug
Page 1 of 2 1 2 >
