Acclaim radiator ?
by urrlord
2 minutes 8 seconds ago
Understanding Idle Control Circuit
by artbuc
50 minutes 9 seconds ago
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Yesterday at 07:08 PM
Wheel says 50 mph max
by pda1122
Yesterday at 06:54 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
86 registered (ARCOgraphite, andyd, A310, 2004tdigls, ArrestMeRedZ, 04sierrashortbed, 9 invisible), 1304 Guests and 45 Spiders online.
65284 Members
67 Forums
285689 Topics
#4666060 - 02/14/18 05:06 PM Some new gear in the home lab!
OVERKILL Online   content
Loc: Ontario, Canada
For the last while my home setup has comprised primarily of an ASA 5506W-X that I purchased on an NFR. This unit had integrated FirePower, which is Cisco's advanced IPS suite, and an integrated WAP/SAP702i access point, which supports AC. It was paired with a cheap Cisco SG200-18 gigabit switch. That setup replaced a previous ISR config with a 2960, which had replaced an ASA 5510. TLDR: I go through network gear regularly.
I just "upgraded" again, this time to a 2951 ISR G2 and another 2960 switch, which is actually a gigabit 48-port 2960S w/PoE, overkill in the port department, but I got a sweet deal on it. Wireless is now provided by an HP Aruba "Instant" AP, which I've become quite fond of, as they seem to be less finicky than the Cisco Aironet products.
So, some initial observations:
- The 2951 is no quieter than the 2921, of which I have a ton in service. They draw air through the back and blow it out the front and they aren't quiet in doing so, even on "low". Despite this, the unit only uses around 50W, so it isn't power hungry.
- The 2960S is massively quieter than the 2951, but louder than the SG200 it replaced which was passively cooled wink duh Luckily, both of these units are installed in the basement, so the noise is really of no consequence.
- The HP Aruba AP has better range and better throughput than the SAP/WAP702i. This is readily apparent, and it also imposes less latency. I would say, at a similar price point, it is by far the superior offering.
This isn't a demanding setup, three VLAN's, three subnets, all isolated (no inter-VLAN routing), no SIP or IP Phone traffic, no VRF's, primarily just your typical home stuff. Kids are on a more locked-down SSID.
So far, I'd say this is the most responsive setup I've had in the house.
Plans are, presently, to try and obtain a Cisco Compute Engine, which is basically a small server that goes into the ISR as a module, which can be loaded with a FirePower VM to give me back the Advanced IPS functionality I'm now lacking. They are expensive, so hoping to score one on E-Bay or an environment pull.
Fun times!
2016 Durango Limited
2016 Grand Cherokee SRT
#4666248 - 02/14/18 08:51 PM Re: Some new gear in the home lab! [Re: OVERKILL]
SubieRubyRoo Offline
Loc: Winchester, Indiana
Hmm, what's that sound? Oh yeah, you just made the NSA's watchlist with this post LOL smile
#4666488 - 02/15/18 07:39 AM Re: Some new gear in the home lab! [Re: OVERKILL]
IndyIan Offline
Sounds good! (I have no idea what you are talking about)
I played war thunder last night!
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4666534 - 02/15/18 08:22 AM Re: Some new gear in the home lab! [Re: OVERKILL]
redhat Online   content
Loc: Anywhere, USA
I was going to ask you in that other post if you had all of this in a rack or closet, but now I see basement. Makes sense as I bet no one would be a fan of hearing those switches run away.
The separate VLAN for kids is a good idea, really keep the junk filtered which is good. Nice setup. Going to be doing the following come spring when Dad builds his garage out back.
Already have a Ubiquiti EdgeRouter X in service, house has residential cable ISP, should be 60 down 5 up or maybe even 100 down once Spectrum takes away Analog TV. EdgeRouter X -> UniFi 8 Port switch w/4 POE. UniFi Long Range AP on first and 2nd floors of the house. Direct burial Cat6 in conduit from the house to the Garage to another UniFi 8 Power switch with/4 POE, Long Range AP in the ceiling of the garage and probably an indoor/outdoor AP mounted outside to blanket the backyard between the house and garage.
May change equipment down the road but that is the rough plans.
I have a simple TP-Link AC router but an 8Port Gigabit Netgear ProSafe that does 802.3ad which is crucial for my NAS. Especially with two Macs doing TimeMachine backups.
09 Accord Sedan 5MT - Travellers 15W-40, XG7317, 142k
14 Civic EX Coupe - NAPA Syn. 0W-20, WIX 57356, 54k
#4666658 - 02/15/18 10:08 AM Re: Some new gear in the home lab! [Re: OVERKILL]
thumbsup
#4667993 - 02/16/18 03:52 PM Re: Some new gear in the home lab! [Re: OVERKILL]
Y_K Offline
Loc: WA (USA)
48-port Sisco with PoE for home? We are talking some serious therapy here smile
This beats my dumpster diving for SGI boxes
#4668253 - 02/16/18 08:29 PM Re: Some new gear in the home lab! [Re: Y_K]
It was a real score, so I can't complain. I guess i have a lot of room for expansion? LMAO! grin
#4668258 - 02/16/18 08:32 PM Re: Some new gear in the home lab! [Re: OVERKILL]
Subdued Offline
Loc: Youngstown, NY
Username checks out
2015 Jeep Cherokee 18k
2008 Chrysler Town & Country Touring 149k
2007 Toyota Yaris S 170k
#4670684 - 02/19/18 09:52 AM Re: Some new gear in the home lab! [Re: Subdued]
pandus13 Online   content
Loc: Chicago,IL,USA
Originally Posted By: Subdued
Username checks out
Oh, come on,
the guy just wanted more airflow in his basement....
The added number of ports and better net capacity is a double cherry on the cake :-P
P.S. the preferred method of cleaning the switches from oil+dust bunnies at my place is to restart them couple times. Don't be near the output.....
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4672141 - 02/20/18 04:21 PM Re: Some new gear in the home lab! [Re: OVERKILL]
Quattro Pete Offline
Loc: Great Lakes
Speaking of overkill, I just picked up a 140mm USB fan and placed it under my router. It dropped the CPU temp by about 15 degrees C. Not that it was really necessary. More of a "feel good" type mod.
Yeah, yeah... rat's nest in the back. It's a temporary setup... smile
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4672182 - 02/20/18 04:52 PM Re: Some new gear in the home lab! [Re: OVERKILL]
I"m not judging, LOL! My cabling is a disaster presently.
#4673205 - 02/21/18 12:37 PM Re: Some new gear in the home lab! [Re: OVERKILL]
Nick R Offline
Loc: Albany, NY
Here I am still running a pfsense box on a Celeron G1610, a TrendNet 16 port gigabit switch, and a TP-Link Archer C8, and I thought my setup was overkill.
2013 Ford Focus SE 2.0L/100,000mi/Pennzoil Platinum 0W-20/Fram Extendedguard
