I got my oil analysis results from a 2016 Kawasaki Versys 650 after running my first batch of Amsoil 10W-40 Synthetic Metric. I was hoping some of you could take a look and make some further comments.The initial oil test was after about 3000 miles from when the 1st owner said they changed the oil but the type was unknown and exact mileage was unknown. The 2nd test all all known.
The results seem good to me at 5000 miles but I did notice a little bit harsher feel in the gear shifting in the last ~1000 miles. Or maybe it was a placebo effect after changing the oil. What would be the biggest contributor to this factor?
I usually run an oil 2 times to figure out a good interval and then let it be. This stuff was about $10 - $11 per quart and need 2. I seem to have less and less time to spend on maintenance so I'm hoping to extend the interval to good comfortable limit. I'm thinking 5k is it.
