Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
116 registered members (ArrestMeRedZ, 2012AccentSE, Arminius, albenjoseph, 55Test, addyguy, 14 invisible), 2,035 guests, and 63 spiders.
Topics286,147
Posts4,903,006
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric #4666039
02/14/18 05:42 PM
02/14/18 05:42 PM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
I got my oil analysis results from a 2016 Kawasaki Versys 650 after running my first batch of Amsoil 10W-40 Synthetic Metric. I was hoping some of you could take a look and make some further comments.The initial oil test was after about 3000 miles from when the 1st owner said they changed the oil but the type was unknown and exact mileage was unknown. The 2nd test all all known.
The results seem good to me at 5000 miles but I did notice a little bit harsher feel in the gear shifting in the last ~1000 miles. Or maybe it was a placebo effect after changing the oil. What would be the biggest contributor to this factor?
I usually run an oil 2 times to figure out a good interval and then let it be. This stuff was about $10 - $11 per quart and need 2. I seem to have less and less time to spend on maintenance so I'm hoping to extend the interval to good comfortable limit. I'm thinking 5k is it.
2011 Ram 2500 6.7L Cummins
2016 Kawasaki Versys 650 LT
1991 Mazda Miata SuperMiata
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666078
02/14/18 06:28 PM
02/14/18 06:28 PM
wv
krismoriah72 Offline
wv
15w40 Rotella would do just as well im thinking. Alot less than $40/gallon.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666146
02/14/18 08:14 PM
02/14/18 08:14 PM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
I just went down an internet rabbit hole reading about Rotella T4. I use Rotella T Triple 15W40 in my 6.7L Cummins and it took me a little while to connect the dots before I realized it is the new version. I'll throw it in on my next oil change and see how it holds up. I was pretty happy with the viscosity readings of the AMSOIL after 5k.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666163
02/14/18 08:33 PM
02/14/18 08:33 PM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Seems like lots of break-in metal. You could use the Rotella for the next 3 changes at 2K-3K miles to get the engine all cleaned up and well broken in. Then switch back to Amsoil and go 5K-6K.
The first UOA/oil sure didn't help things - sheared to SAE 20 range and added to the metal in this UOA.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666221
02/14/18 09:29 PM
02/14/18 09:29 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
+1 to Amsoil for making an oil that didn't shear out of grade after that many miles on a wet clutch bike.
And am I reading correctly that the Versys 650 sump only takes 2 quarts?!
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666331
02/14/18 11:31 PM
02/14/18 11:31 PM
indiana
Jimkobb Offline
Jimkobb  Offline
indiana
How would you compare the Kawasaki versys to other bikes? I`ve been considering one if I could get a good deal.
green_bay_packers_logo_small[1]
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: Pablo] #4666385
02/15/18 02:21 AM
02/15/18 02:21 AM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
I already put in Amsoil. Do you think the levels are high enough to merit doing a few short intervals?
Right now, I'm planning on running 5k miles on amsoil to determine repeatability and see the change in metals and then try a run with Rotella. If the break-in metals are still high on the next UOA, I might shorten the first Rotella run to 2k and then do a run to 2k or 5k depending on the following UOA. Maybe over thinking it and hopefully everything drops on the next sample.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: Reddy45] #4666386
02/15/18 02:25 AM
02/15/18 02:25 AM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
Owners manual actually states 1.9 quarts with filter change.
I think service manual states something like 2.3 or 2.4 quarts on a dry engine.
I really like Amsoil products in general. If the price wasn't so high, I would run it in everything. Their dominator racing grease has a great reputation in troublesome Miata front wheel hubs.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: Jimkobb] #4666393
02/15/18 02:35 AM
02/15/18 02:35 AM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
Depends on what you want from a bike. It's the best at nothing but good at everything. It's mainly a commuter bike for me and it's comfortable with a great engine. It has a good reputation for being a low maintenance, reliable bike and it's pretty sporty and fun on the twisty roads. I would definitely recommend it to a friend.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: Pablo] #4666434
02/15/18 06:58 AM
02/15/18 06:58 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
^^^ Agree ^^^
Much metal from first UOA so you dont really know a real number yet.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666453
02/15/18 07:45 AM
02/15/18 07:45 AM
Greece
Panos Offline
Panos  Offline
Greece
The metals should drop, and keep dropping at the following ocis. If they don't, running something else for 2k should not fix anything fixable by oil IMO.I think you are good for now using amsoil.
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Shell Advance Ultra 4T 10w40
Honda cbr600f Pc41 Motul 7100 10w30
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666516
02/15/18 09:08 AM
02/15/18 09:08 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Never ridden one myself but a friend who was a former racer with a wall full of trophies had one and really liked it. I think they are good all around bikes.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666528
02/15/18 09:18 AM
02/15/18 09:18 AM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
Curious if moly or boron would be better for a bike like this . (SR-T4 has 200ppm of boron now - http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html )
Valvoline Synthetic Motorcycle 4t oils also are loaded with boron now. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4351471/Re:_2001_Valkyrie:__Valvoline_
I just keep shaking my head when I think about 2 quarts going 4 thousand miles in a 'revvy' engine. It's impressive, and I'm envious.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: Brian553] #4666620
02/15/18 10:42 AM
02/15/18 10:42 AM
wv
wv
You can read on here for weeks and still come up with the same basic answer..
JASO MA is your friend.
You can find this rating in hundreds of different packaging.
After you read VOAs, UOAs you will see that most of them are heavy on the ZDDP.
In the end you should probably come to the conclusion that any 5w40 or 15w40 HDEO will do the job with flying colors.. (Even the Traveller Brand from TSC gets a big thumbs up).
However- if you are in the category that doesnt feel good about using a HDEO then you should look towards Motul, Maxima, Bel Ray.. Mobil 4T, Amsoil..and why not.. Redline.
Re: Kawasaki Versys 650 -Amsoil 10W-40 SyntheticMetric [Re: b3d3g1] #4666735
02/15/18 12:42 PM
02/15/18 12:42 PM
NorCal
b3d3g1 Offline OP
b3d3g1  Offline OP
NorCal
Thanks for all the input guys. I'll revisit this thread after my next UOA of 5k miles on Amsoil. I'll plan to try out Rotella T4 for a 5k interval after that just to do back to back comparison but I'm perfectly alright spending a few extra bucks on Amsoil. I actually bought a case on first order so I was probably already mentally decided unless something bad showed up. I hadn't seen much UOA on the Amsoil oil I used so I wanted to share my results with the bob brain trust.
Page 1 of 3 1 2 3
