Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
120 registered members (555, 2015_PSD, albenjoseph, 97f150, 69Torino, 2012AccentSE, 17 invisible), 2,122 guests, and 62 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
Rear driver side rotor gets hot #4665882
02/14/18 03:01 PM
02/14/18 03:01 PM
Virginia
qingcong Offline OP
qingcong  Offline OP
Virginia
My car is a 13 Civic Si. 2 weeks ago I noticed a burning smell from the rear driver side and soon after a rumbling sound from that area as I released the brake pedal. I took it to the mechanic and he says the caliper was sticking. He replaced the caliper, but the problem of the rotor getting hotter than the others persisted. I took it back, he replaced the caliper again and the rotor was still getting hot. This morning after my drive in to work I took a temp gun to measure the rotors. The other three were at 40-44C and the hot one was at 70C.
Seeing as how I've been through 2 calipers, I'm guessing the caliper is not the issue. What else could it be, slide pins, brake hoses, master cylinder, proportioning valve?
Re: Rear driver side rotor gets hot [Re: qingcong] #4665896
02/14/18 03:16 PM
02/14/18 03:16 PM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
Slide pins, rusty caliper bracket, or brake hose.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Rear driver side rotor gets hot [Re: qingcong] #4665931
02/14/18 03:57 PM
02/14/18 03:57 PM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Brake hose. They fail internally and don't allow the fluid to return to the master...Acting like a one way valve.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Rear driver side rotor gets hot [Re: qingcong] #4665942
02/14/18 04:13 PM
02/14/18 04:13 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Your 'mechanic' should be actually diagnosing the problem, not throwing parts at it. I can see one caliper, maybe, but not two.
Re: Rear driver side rotor gets hot [Re: Bottom_Feeder] #4665949
02/14/18 04:20 PM
02/14/18 04:20 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
This.
Also check the parking brake cable.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Rear driver side rotor gets hot [Re: Bottom_Feeder] #4665951
02/14/18 04:23 PM
02/14/18 04:23 PM
Virginia
qingcong Offline OP
qingcong  Offline OP
Virginia
You don't have tell to me. The guy's a well reviewed Honda/Acura specialist, somehow.
Re: Rear driver side rotor gets hot [Re: mightymousetech] #4665952
02/14/18 04:24 PM
02/14/18 04:24 PM
Virginia
qingcong Offline OP
qingcong  Offline OP
Virginia
This.
I thought about that, but the brake pad was worn out for that side, and it is only on that side. I think a parking brake issue would not wear the pad out.
Re: Rear driver side rotor gets hot [Re: qingcong] #4665998
02/14/18 05:08 PM
02/14/18 05:08 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
A stuck cable on that side will cause what you describe with this style caliper. The mechanic should have seen that though.
Re: Rear driver side rotor gets hot [Re: qingcong] #4666009
02/14/18 05:19 PM
02/14/18 05:19 PM
USA
mk378 Offline
mk378  Offline
USA
If you're saying that on the same caliper, one brake pad was worn out while the other one had plenty of material left, that means the slide pins are not working.
You really don't need to go to a supposed Honda expert here, this particular system is pretty much the same on all cars.
Re: Rear driver side rotor gets hot [Re: qingcong] #4666165
02/14/18 08:33 PM
02/14/18 08:33 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If the pad is not down to steel, then all you need is a repaired caliper and a set of pads. Wait and you''ll need a rotor too. The car isn't old enough for a bad hose
Thick oil is better grin2
Re: Rear driver side rotor gets hot [Re: qingcong] #4666209
02/14/18 09:18 PM
02/14/18 09:18 PM
Iowa
Aichiguy Offline
Aichiguy  Offline
Iowa
Brake hose me guesses
2017 Toyota Camry 2.5
2011 Toyota Camry 2.5 75k
2003 Toyota Camry 2.4 201 k
1999 Ford F150 4.6 70k
Re: Rear driver side rotor gets hot [Re: qingcong] #4666254
02/14/18 09:57 PM
02/14/18 09:57 PM
Trav Offline
Trav  Offline
The more I think about this it may be a bad caliper, if he bought Cardone or other parts store remans it would be no surprise. If he got it with the bracket it came with new pins.
I have seen 3 or 4 bad ones in a row on these integrated e brake calipers. It could be a hose but I would be surprised if an original factory one deteriorated internally in 5 years, worth a look though.
Re: Rear driver side rotor gets hot [Re: Trav] #4666571
02/15/18 10:01 AM
02/15/18 10:01 AM
Virginia
qingcong Offline OP
qingcong  Offline OP
Virginia
He did use a Cardone for the first caliper. The second one was a Nissin.
If it was a hose issue, would the brake caliper eventually release, assuming it wasn't completely clogged? Also, couldn't it just as easily not allow fluid towards the caliper as it would not allow the fluid to return from the caliper?
I have been through some salt and there is a portion of the highway on my daily commute where the pavement is loose so it's always shooting up little pebbles and I hear the clink clanging, so I wouldn't be surprised if there was some damage there.
Re: Rear driver side rotor gets hot [Re: mightymousetech] #4666602
02/15/18 10:24 AM
02/15/18 10:24 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
This.
Parking brake / emergency brake was what I was thinking , also .
Wyr
God bless
Re: Rear driver side rotor gets hot [Re: WyrTwister] #4666625
02/15/18 10:45 AM
02/15/18 10:45 AM
Virginia
qingcong Offline OP
qingcong  Offline OP
Virginia
Does the parking brake on the Civic Si use the pad?
