The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
best way to buy a new vehicle?
by WhyMe. 01/15/19 11:07 PM
Cat Humor
by StevieC. 01/15/19 11:06 PM
Lightning McQueen (Humor)
by StevieC. 01/15/19 11:04 PM
Fastest Land Mammal (Humor)
by StevieC. 01/15/19 11:01 PM
Wifes says decorate the baby's room (Humor)
by StevieC. 01/15/19 11:00 PM
Taco Bell (Humor)
by StevieC. 01/15/19 10:57 PM
Van full of money (Humor)
by StevieC. 01/15/19 10:56 PM
Amazon Packaging (Humor)
by StevieC. 01/15/19 10:55 PM
Star Spangled Banner in school (Humor)
by StevieC. 01/15/19 10:52 PM
Maybe on to something? (Batman Humor)
by StevieC. 01/15/19 10:49 PM
Canadian Breakfast (Humor)
by StevieC. 01/15/19 10:48 PM
Tinder Anyone? (Humor)
by StevieC. 01/15/19 10:45 PM
(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
37 registered members (4WD, Astro14, billt460, alcyon, Black_Thunder, anndel, 3 invisible), 912 guests, and 37 spiders.
Topics296,627
Posts4,955,927
Members66,950
Most Online2,577
Jan 14th, 2019
Charging Battery - -Amps? #4665803
02/14/18 12:51 PM
02/14/18 12:51 PM
Chatham, Ontario, Canada
cb450sc Offline OP
cb450sc  Offline OP
I have a 2005 Civic and the battery has been struggling the past couple of weeks in the cold weather. I have only taken short trips with the car the past month. I have a smart charger which allows me to charge at 2, 4 or 6 amps. I am not in a rush. Is it any better to charge a battery at 2 or 6 amps in terms of battery reliability? What would you charge it at?
Re: Charging Battery - -Amps? [Re: cb450sc] #4665807
02/14/18 12:54 PM
02/14/18 12:54 PM
Great Lakes
Quattro Pete Offline
Great Lakes
I would set it to 6 amps. Smart charger will automatically reduce current as the battery nears full charge.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Charging Battery - -Amps? [Re: cb450sc] #4665812
02/14/18 01:02 PM
02/14/18 01:02 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I am absolutely not an expert on this but my smart charger will try settle in at 2 amps and then less as it charges, but if the battery was quite depleted it might start out at 6 amps. Take a look at what it is doing at the 6 amp setting and what it does at the two amp setting. If it starts at 6 and stays there, try 2 amps (if you have more time). The lower setting is probably better if you have the time.
If you want the job done right......do it yourself.
Re: Charging Battery - -Amps? [Re: cb450sc] #4665821
02/14/18 01:12 PM
02/14/18 01:12 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Anything under 10 amps should be fine. So 6 amps should be fine.
Re: Charging Battery - -Amps? [Re: Snagglefoot] #4665826
02/14/18 01:18 PM
02/14/18 01:18 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
My Ctek charges at 4.3 but I have no control over that. What charger do you have, I thought smart chargers adjusted all that for you.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Charging Battery - -Amps? [Re: cb450sc] #4665831
02/14/18 01:22 PM
02/14/18 01:22 PM
cb450sc Offline OP
cb450sc  Offline OP
The charger is a Motomaster Eliminator Intelligent charger.
Re: Charging Battery - -Amps? [Re: Duffyjr] #4665838
02/14/18 01:27 PM
02/14/18 01:27 PM
Great Lakes
Great Lakes
They do, but some of them also allow you to limit max current that can be pushed. For a small motorcycle/OPE battery you may want to limit current to 2A. For larger car batteries, 10A or more may be appropriate.
Re: Charging Battery - -Amps? [Re: cb450sc] #4665852
02/14/18 01:36 PM
02/14/18 01:36 PM
MN
tmorris1 Offline
tmorris1  Offline
MN
Lower amps will be a more complete charge but will take longer. Also easier on the battery.
Re: Charging Battery - -Amps? [Re: tmorris1] #4665875
02/14/18 01:55 PM
02/14/18 01:55 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
For a normal car battery 6 amps is pretty low IMO.
Re: Charging Battery - -Amps? [Re: cb450sc] #4665880
02/14/18 01:59 PM
02/14/18 01:59 PM
Wash, DC
circuitsmith Offline
Wash, DC
The initial current is not as important as charging long enough to fully charge the battery.
The charger maintains about 14V, then the charge current the battery accepts will fall
as the battery fills up.
A healthy battery of the size in a Civic (~50AH)will accept less than 2 amps when nearly full.
Example, recently charged the battery in my Matrix:
First, I do it every 3-6 months due to infrequent use (6K miles/yr) and short trips.
Battery rest voltage 12.5V. Temp ~60F
Using an adjustable supply (I like to be in control) set to 14V, initial charge current 2A (limit of supply).
Falls to 0.75A at 5 minutes, 0.65A at 2 hours, still 0.65A at 4 hours, 0.23A at 12 hours (overnight).
So you see the current reached a plateau that lasted for several hours.
It takes time to drive out sulfation on the plates.
My last battery was still going strong after 9 years of this routine when I swapped it.
Just didn't want to try for a 10th winter.
2017 Hyundai Tucson SE FWD, 5000mi/12mo OCI
Re: Charging Battery - -Amps? [Re: cb450sc] #4665888
02/14/18 02:08 PM
02/14/18 02:08 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Is getting a new car battery an option???
Re: Charging Battery - -Amps? [Re: cb450sc] #4665903
02/14/18 02:26 PM
02/14/18 02:26 PM
cb450sc Offline OP
cb450sc  Offline OP
If it won't charge up then yes I will be looking for a new battery. I am just trying to get whatever I can out of it.
Re: Charging Battery - -Amps? [Re: Rand] #4665918
02/14/18 02:41 PM
02/14/18 02:41 PM
Great Lakes
Great Lakes
Yup. For a 60 AH battery, 6A current is barely 0.1C. That should be well within what the battery can handle.
Re: Charging Battery - -Amps? [Re: cb450sc] #4666073
02/14/18 05:22 PM
02/14/18 05:22 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
How old is this battery?? Has it been maintenance charged regularly before this?? What type of battery is this?? AGM, flooded ?? If this battery is 6 years or older then you really should just buy a new one if possible.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Charging Battery - -Amps? [Re: cb450sc] #4666096
02/14/18 06:01 PM
02/14/18 06:01 PM
cb450sc Offline OP
cb450sc  Offline OP
The battery is four years old, flooded, it has been maintained by checking water level and charging at least a couple times a year.
